Question about Samsung PCL545R 54" Rear Projection Television
Color convergence off and bowing effect on top and bottom of picture
Hi ,
My tv's focus of colors was off and it looked that the picture had what I would describe as a bowing effect to it. I replaced the convergence IC's believing that would be the answer to all my prayers. Not even close. Now the problem is even worse. I've tried the manual convergence from the menu settings and I can't get anything to move. Is there anything else that it could be? The fact that it's now worse makes me worry that I've done something wrong in the IC change out but everything seemed to go fine. Also read something about possible resistors blown ?????
Any and all help would be appreciated.
    Scholar:
  • 198 Answers
Most of the samsung hdtv and lcd customers are facing the problem of the display.. either ther will be blends of colours on the screen or ther wil be no focus of colours...the exact reason for thiis cant be told until it is spot checked.... the best solution for this you should take it to a professional electrician and get it checked... it will be very gud if you stil have the warranty for this tv
Posted on Jun 01, 2008
    President:
  • 2,712 Answers
Yes, if you have replaced the IC's correctly (and used the correct IC specifications) then the issue could be with faulty resistors and / or capacitors.
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    An easier option would be to replace the whole board. You can get one for about $85 here:
    http://www.partstore.com/Part/Samsung/Sa...
    Cheaper than a repair, and peace of mind :)
  • Swilin Sampson
    Probably this link also could be useful..its a step by step guide with pics on how to replace the IC's:
    http://home.earthlink.net/~oleg.filippov...
    Also make sure that you do not use cheap clones of the IC's. They could be the cause for the issue as well. Try PANASONIC or SANYO STK392-110 chips instead..A bit more expensive, but worth it..
    PS..If you find that the information I provided was useful and helped you in any way, please take a moment to "Accept" my solution. Many thanks..
My rear projection television is showing a double picture with the blue out of allignment. It also shows a bow on the top and a bow on the bottom.
The tv have a problems known as a convergence problems,tv convergence board it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it is dead.Must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv picture convergence problems.The tv shop,will cost u like $300-350 for parts and labors.
Apr 24, 2011 | Zenith IQC50H95W 50" Rear Projection...
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Top and bottom of picture in center of screen dips like a bow tie
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board reqiured changes it 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board problems to solved the tv picture convergence picture problems.The shop,will cost like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi WS-65908 TV
My samsung pcl6215r is having problems with the green screen. The red and blue colors are fine but the green wont line up with them and its making it out of focus badly. It doesn't appear to be dim or...
brent hardin,
Your description of the problem sounds like a convergence issue. You more than likely have lost the convergence ICs. They will need to be replaced and the convergence will have to be set. The green beam should not move. It is the standard which the red and green are moved to overlap. Since you have bow at the top and bottom I would replace the convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to replace the parts and where to get the replacement parts.
Thanks for using FixYa and for the great rating. Great ratings will keep the experts helping to solve problems. Thank you.
hardrocko
Nov 17, 2010 | Samsung PCL6215R 62" Rear Projection...
How do you make a pincushion adjustment. Picture is OK in center but out of focus as it spreads out in all direction with a bow shape at bottom. All colors appear to be present. Can you help?
This is not adjustable,have dead parts.The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment anywhere in the pictures,have colors pictures shadows or 3D pictures look alike?The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts,must replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 23, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
Screen is bowed on top and bottom.
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
Jul 13, 2009 | Samsung PCL5415R TV
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
Have a 53" Hitachi HDTV that bows at the top and the bottom. I was told one of the transitors or transformes blew. I also do not have the regular magic focus just the static focus now. I tried to alli
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 03, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Picture Problem , Sony Projection TV
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Oct 01, 2007 | JVC AV-56WP84 56" Rear Projection...
Samsung PCL545R 54" Rear Projection Television Logo
76 people viewed this question
Henry  Thomas
Henry Thomas
