Question about Garden
MY WATER PUMP IN MY SMALL POND HAS BEEN WORKING FOR ABOUT 5 YEARS. ALL OF SUDDEN IT STOPPED. WE TRIED TO LOCATE IT AND IT APPEARS TO BE UNDER THE PLASTIC BOTTOM OF THE POND. WHAT SHOULD I DO NEXT BEFORE MY FISH DIE.?
  • 990 Answers
Find your main suction line and be sure it is clear. Also be sure their is no false rocks or sumps to hide the pump. When you get to the pump if it is under water make sure it is clear and not air locked. If under the pond be sure it is clear of dirt and you will need to take apart to check the impeller. Before you do these things check all power in and out of switches or clocks and be sure the motor is running. If it is a submersible pump you will probably change the whole thing if the motor is out. If it is outside the pond just the motor and seals should do the job. Good luck.
Posted on Oct 14, 2010
My Aqualisa Quartz shower stopped working suddenly. Pump is on, but no water
can offer no information on this but to call a local plumber .sounds like you possibly need a new pump
Aug 01, 2016 | Home
Pump stopped working after 6months running can it be rebuilt
Has it exceeded the manufacturer's warranty? Don't try to compromise the water tight housing where the electro-magnet is located, as this could result in a nasty electric shock (or worse). Try cleaning the impeller and the impeller housing. Perhaps try a replacement impeller.
Sep 04, 2011 | Tetra Pond Pump Dynamag 750
It stopped pumpin water, doesnt turn on. its a well pump for my house water
This pump turn to go death all of the sudden, the coil inside the engine get fried all of the sudden. How old is it?
Thanks
Jun 23, 2011 | Sta Rite Sta-rite .75 HP Shallow Well Jet...
I have a vornado 733 floor fan that has suddenly stopped working after my 2-year old shoved some small, soft toys into it. fan blades spin freely when moved by hand, but the unit appears to be completely...
I would check the line fuse to see if it is blown. It is located in the plug under the sliding access cover. Slide it towards the cord to open. If the fuse is good and you have it less than 5 years, you might be able to get the company to fix it for free since it has a 5 year warranty. 1800 234 0604. Hope this helps you.
Apr 13, 2011 | Dryers
Water on the floor under the freezer side of unit
It happens to all those old refrigerators. There is a shield separating the drip container and freezer through a small hole. Check if it is blocked. This won't do much of the work and may not be stopped even if you do something. If you can, have a new refrigerator.
Apr 21, 2010 | Amana 22.6 cu. ft. Side-By-Side...
De-icer must have a short
The best solution to ice in garden ponds is to keep the water moving as moving water will not freeze. Depending upon the size of your garden pond you may try adding a fountain. All major pump brands carry small fountain pumps that include various fountain spray nozzles/heads or you can buy the pump and then purchase a Fountain Head Kit separately. The fountain will provide 1 - movement of water at the surface, 2- aeration for the pond, 3- pleasing sounds year round, not to mention the 4- aesthetic value. The added bonus is that you will not have to worry too much about shorts if you use a submersible pump. So try dumping the deicer and go for a fountain.
Dec 29, 2008 | Beckett Water Gardening Water Garden...
Pond pump not working
Well first thing is to locate pump and then check to see if the screen is plugged. turn power off and check inlet tub of pump for sticks, rocks,or leaves in it that can plug the suction on it
Nov 21, 2008 | Garden
Pump goes on and off
Does the pump have thermall protection? It sounds like its getting hot and tripping the thermal protection switch in the pump windings.
Oct 06, 2008 | Sunterra 450gph Pond Pump
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
