Question about GE JGBS07PEAWW Gas Kitchen Range
I have a GE jgbs23wea3ww that the oven is not gettin any lp gas out of. the igonitor is coming on .do you think is the safety valve on the unit or any thing else.i don't think it's the thermostat because the ignitor comes on and off with the knob controll.
catriver
  • 878 Answers
SOURCE: ge oven jpbp90
Ted, you probably have a bad ignitor. If you have a meter, you can do some checks to rule out the board. Take the back top panel off and on the board you will see four wires..from left to right they should read L1, neutral, broil and bake on the board. Broil and bake will be marked as BR and BA. Set the oven to 350 and press bake, you should have 120V from BA to Nuetral. If so your board is ok. You should also hear a click after pressing bake. 90% of the time it's the ignitor, part number WB13K0004. Be care when testing with live power. Catriver..post back.
Posted on Oct 15, 2006
ginko
  • 19396 Answers
SOURCE: GE XL 44 GAS OVEN
The valve is probably faulty, even if the gas comes out it probably doesnt have right pressure. the owen as it is may be dangerous, I suggest having it checked by a qualified technician.
Regards
Posted on May 16, 2008
jumptrout51
  • 3361 Answers
SOURCE: flame too high in oven
Take a 1/2 inch open end wrench and adjust the orifice on the gas valve, also adjust the air shutter on the venturi tube.
Posted on Mar 24, 2009
  • 949 Answers
SOURCE: How do I tell if the thermostat is bad or the
The way to tell for sure is to take an ohm reading on both and a current reading on the ignitor. The thermostat should read 0 ohms when calling for heat. The ignitor should read some resistance but not an open circuit. The current draw through the ignitor should be about 3.2 Amps, any less means it is too weak to open the gas valve.
If you do not have meters try these checks.
If the ignitor glows at all then the thermostat is good. If the ignitor does not glow at all it could be either the thermostat or the ignitor,
If you can see the ignitor close up sometimes you can see a white spot on it or a crack, this means the ignitor is bad.
If you have to guess which one the smart money is on the ignitor being bad
Posted on May 10, 2010
Testimonial: "Thank you. I appreciate the opportunity to save a lot of money and fix it myself. We are not in a position to pay for a service person. God bless, Curt"
heatman101
  • 43501 Answers
SOURCE: oven ignitor won't ignite GE RANGE : JGBP28DED1CT
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Jul 16, 2010
Magic Chef 9112XUB Gas 24 In. Single Wall Oven wont light
Is this a new oven and, if so, how long was the old one disconnected?
Spiders can spin webs very fast in pipes, tubing and regulators. It has happened to me, so this is a possibility for low gas flow.
Also, could there be any other restrictions or changes, such as going from LP to natural gas?
Nov 17, 2012 | Ovens
GE Range - oven flames too high after regulator replacement and self clean
You need a Gas tech/plumber there urgently!!!!
If the gas jets in your oven had not been changed to accomodate LP gas then the orifice on your existing jets are still to large in diameter. In other words your using Natural Gas jets ( lower pressure jets) for Lp which has a much higher pressure than Nat. gas, this can be extremely dangerous, & could cause major problems.
Again I strongly suggest you contact a Gas tech/Plumber & do not use your oven until it has beeen checked by a professional.Good luck
Aug 18, 2012 | GE 30" Free Standing Electric Range
The oven temperature on my GE XL44 propane range is inconsistent. I set it at 350, and then I'll check the inside thermometer a half hour later and it will read 450. Drives my wife crazy. Some days it...
Hello. One question has your range burner jets been changed to LP (liquid propane). If you are using natural gas jets for the burners and ovens this make the heat and flam fluctuate in temperature and the same for the oven. Natural gas jets are larger. One more thing here! There is a control valve spring with cap in the stove gas regulator that has to be taken out and turn around.
Search the operation manual on how to changes jets from natural gas to LP. In back of the stove behind one of the panels is a small cloth bag contain these LP jest and also there should be set of instruction in a bunch of languages.
If you are going to do this yourself--- DIY. Read those instruction ever carefully. There a bass ball valve that hook to the gas line before the flex stainless line behind you stove. Turn the nob to where it perpendicular to the gas line. Open the windows in the house and turn off all electric equipment such as, fans, toasters, don't be clicking the light switches off and on. Just a precaution for you and your family safety.
Check with your city zoning ordnance about home owner changing their gas jets in the range. Some cities and states won't allow you to due this. Then you will need a technician to preform this operation. I wish you and family well being and you safety first... GB you...stewbison
Aug 22, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE Spectra XL44, model #JGBP40BEC4WH gas oven. The 4 burners on top work but the oven will not. I replaced the oven safety valve (dual type 1), thinking that it was stuck and not directing gas to...
Most likely, you're oven igniter is not getting hot enough to open the gas valve to ignite the burner. It glows like normal, but does not reach the temperature required to open the gas valve. Replace the igniter. Before you replace that, make sure that the small shutoff lever on the appliance regulator was not accidentally closed, which would turn off the gas to the oven, while still allowing gas to the stovetop. The silver lever should be sticking straight out or up. Douglas
Sep 12, 2010 | GE JGRP17 Gas Single Oven
Can this gas range be converted to lp gas maytag performa
moz-screenshot.pngmoz-screenshot-1.pngTurn off the gas supply.
Locate the gas valve regulator. Unscrew the top cap on the regulator,turn it over and re-install it.It should be marked NAT. LP.When correctly converted you will be able to read LP.
On the Performa all the conversion parts should just be adjustments. Remove the oven racks,remove the oven base pan,remove the oven flame spreader pan to access the safety valve. Take a 1/2 inch open end wrench and tighten the orifice on top of the gas safety valve. Tighten it until it is snug.Remove the top burners and raise the top to access the surface gas valves.Tighten the valve spuds until snug. Re-assemble all parts.Turn the gas back on and lite the burners. Turn them high and low to make sure they stay lit. If any burner is not right tighten or loosen the orifice spud for that burner only. All air shutter adjustments should be full open,
Dec 02, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Replaced gas safety valve, burner flame now too hot
Take a 1/2 inch open end wrench and tighten the orifice on top of the safety valve.Probably about 2 turns. Then adjust the air shutter to mostly open.
Mar 26, 2009 | GE Ovens
Oven
Dont Mess with it if you bought it second hand and Gas is a bad thing.. It may have been an LP/ (Liquified Petroleum) gas unit prior and now its hooked to a lower Natural Gas pressure home system or vise -versa. Turn it off and call a local contractor please. "PLEASE" Shut the Gas valve off until you do so..
(Bad things can happen if you try to do this Modification yourself)..
Just food for thought..
Jan 15, 2008 | Tappan TGF320 Gas Kitchen Range
Oven does not stay lit.....
HI thanks for your question. yes the igniter stays on all the time the flame is on, it keeps the safety valve open to give you gas. and yes the new igniter will work. thanks
Oct 15, 2007 | GE Profile JGSP48 Gas Kitchen Range
GE JGBS07PEAWW Gas Kitchen Range Logo
76 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
