Question about HP ScanJet 5370C Flatbed Scanner
Scanning problems I have a epson flat bed scanner which I use daily to scan in drawings usually on a white background,recently the white backgrounds of the images are getting darker almost blue,does this mean the scanner is worn out
R 105 from my HP 5370 has burnt out. Replaced it with a 30E but it becomes very hot in a few seconds.
Read somewhere to remove C118, is this the besst solution?
Thanks in advance for answering.
Posted on Jun 02, 2008
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
My Epson scanner TX111 is not scanning properly but is scanning with a blue background for white blanlk paper.
your printer's black ink is empty already you need to change the cartridge or refill the black ink.
Jul 04, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
I'm having trouble scanning B&W documents with my Epson V300. The edges of the letters in the text are jagged and hard to read and there is what appears to be a crease or fold in the document when the...
You have two options for scanning text. You may explore both of them and see which is better for you. Either way, you will have to make friends with manually changing the scanning settings, because simple presets often are not suited for every case.
First is to use Grayscale mode, and a minimum resolution of 200dpi. This should give you satisfactory text quality. If you want to print the text afterwards, 300dpi would be even better. You may want to increase contrast, to get the letters more defined and eliminate most of the background toning.
Second is to use Black and White (monochrome) mode, but in this case you need to set the resolution higher, preferrably to 600dpi. Also in this case you will have to play with the Black/White threshold in order to eliminate background "dirt" appearing as black artefacts.
If you scan the documents in order to process them with OCR software, usually the OCR application will give you suggestions on how to set the scanning parameters to obtain good results.
Jan 24, 2010 | Epson Perfection V300 Film Flatbed Scanner
When we scan a drawing, we get a green background.
Try scanning with different software, such as MSOffice Photo Editor. It could be the scanner TWAIN settings or the app that you are scanning with.
Aug 31, 2009 | Hawking Contex HAWK-EYE Cx Scanner
Scanning 35mm negs on my Epson Stylus PHOTO RX620
Try using a slightly off-white background sheet behind the negative (glass-negative-sheet-scanner lid) first, or a "frame" around the negative that is anything but white... some scanners have an auto-detect feature that may be skewed for one reason or another.
Another trick, from a photographer friend, is to take saran wrap or another transparent but non-reflective material and place as a filter between the negative and glass, thus reducing glare. The sharpness may be lessened, but the glare is also lessened...
Hope this helps!
-- RT
Aug 28, 2009 | Epson Perfection 4490 Office Flatbed...
Grayblue Background on scans
A color scan will give real output as it is. If the background is grey, the output will also be grey. If you select 256 Color output, there may be small change in color, as compared to the original. If you select grey output, all colors will be converted to Grey. If these files are converted to PDF, it will be same, except in ODF format.
If you select B&W you can save the file in TIFF format. Unlike grey or color, each pixel can be either black or white only. To scan in black and white you must select right brightness. By doing os you can eliminate background (technically noise) and capture foreground(data)
S. Mohan
Oct 19, 2007 | Canon DR-1210C Scanner
When printing a scanned object, paper is all gray
Whatever scanning utility you are using, set it to Black and white, not grayscale nor colour! regards, babb
May 05, 2007 | Umax Astra 610P Flatbed Scanner
HP ScanJet 5370C Flatbed Scanner Logo
143 people viewed this question
Seeker5211
Seeker5211
