Question about Kodak EasyShare DX6490 Digital Camera
DX6490 won't work on battery only
I hope someone can help please. Some time ago, my Kodak DX6490 stopped working on the battery. The battery wouldn't charge either so I got a new one. Now with the new battery it still won't switch on. It works fine when on mains though.
Thanks in advance for any help:)
  • 1 more comment
  • Skiprat1 Jun 01, 2008
    Hi Zarn,
    When I got the new battery, I charged it in the external Rapid Charger. I left it on charge for several hours after the light turned green. Then put it in the camera to try. Nothing happened.
    I then put the camera, complete with new battery in the dock. Three green bars for a few minutes, then they changed to flashing red. When I plug the power supply ( that normally stays with the dock ) into the side of the camera, it works fine, with or without any battery in the camera.
    Thanks again
    Thanks again Zarn. I'll try cleaning the contacts, but I'm reluctant to try opening it up. Most of the pics I take with this camera can be done while it's plugged in anyway. I've had it for a few years and like it a lot. The only thing that I know ( besides this problem ) is a tiny screw missing that secures the tripod mount. There does seem to be something that rattles around inside too.
    I know that it will cost probably as much as it's worth to take it in for repair, so unless there was some kind of 'reset' button, I guess I'll have to live with it.
    Thanks again for the very quick replies :)
  • Jason Adlard May 11, 2010
    When you say on mains, are you using the dock/printer or the socket on the side of the camera?
    Are you charging the battery in the camera, on the dock or with the external fast charger?
    Novelist:
  • 153 Answers
I presume the camera is out of warranty?
There are many possible problems..
would the old battery charge on the fast charger at all or did it do strange things (dont do it now to try), If the battery was shorted, and you tried to charge it on the dock it may have damaged the cameras internal power supply, which is quite a complicated device, there are fuses but they are absolutely tiny and you need special equipment to fit them properly.
Also the flash capacitor lives on the power board which can keep its charge for quite some time at up to 300v at a substantial current and will make you drop the camera (at least) if it bites you.. :) so from the safety angle if you don't have at least some electronic training I cant recommend opening the camera..
The only possible suggestion that is a relitively easy fix is that the battery contacts may be bent or dirty.
Beyond that as I currently don't have my test dx6490 (used for checking voltages with units in for repair etc..) .. the next try is the dc socket, it may be damaged, or contaminated. try inserting and removing quite a few times and maybe using a VERY small amount of electrical switch cleaner.
Unfortunately to get to the socket if it is broken requires the whole camera be striped down as its just about the first board you fit when re assembling.
If you are adventurous, probably the easiest route to getting a camera back up would be to buy a faulty one from ebay. One with a broken screen or mode switch would be the easiest fix as you only need to remove the back and disconect and reconnect three ribbon cables.
Next would be a lens swap for one with a broken lens but requires quite a significant amount more work.
although the most difficult bit in both procedures is getting the diopter knob (eyepiece focus) on and off which in most cases means a small amount of damage will be done to the eye piece but nothing really bad, just cosmetic (kodak would replace the bit)...
If i can be any more help drop me a line....
best of luck
Posted on Jun 01, 2008
How tocharge my kodak model6490
You can charge the battery with the charger that came with the camera. Or you can charge the battery with the camera dock. For that to work, you should switch off the camera. While the charging is stopped as soon as you switch on the camera.
If you don't have a dock nor a charger, you could buy a new universal battery charger. Several brands do have universal camera battery chargers. Those new chargers sense what voltage your battery needs and will give no more.
Nov 05, 2013 | Kodak EasyShare DX6490 Digital Camera
Kodak easyshare dx6490 charger indicator light is on but battery wont charge
Sounds to me that if you bought 2 chargers then you have a bad battery. what are the odds that you have 2 bad chargers ? Time to buy a new battery.
Jan 25, 2013 | Kodak EasyShare DX6490 Digital Camera
My Kodak Easy Share DX6490 will not turn on. When I place it on the charging dock, the lights flash like it is transferring photos to my computer and the flashing won't stop even if I remove the camera...
Hello, sounds like you have a faulty battery,if the battery is several years old it will lose the capacity to boot the camera and the dock is trying to charge a defective battery,if you get a new battery, charge it for at least 6 hours or more.Hope this solves your problem.
Regards,Russell
Aug 16, 2010 | Kodak EasyShare DX6490 Digital Camera
Kodak dx6490 Powers up and shuts itself off.Battery is charged!
Hello, Sounds like you may have a battery problem. The DX6490 battery loses it's capacity over time, If the battery is a couple years old they are known to fail. May not be any problem with camera, try a new battery and let it charge completely before installing it.
Best Regards, Russell
Dec 01, 2008 | Kodak EasyShare DX6490 Digital Camera
Kodak DX6490
Hi: This is a long shot, but I had a similar. It would start up, but lense would not extend. Secret was that it wanted the date re-loaded. They have a small internal battery to keep the clock going when you remove the main battery to change it. Many people never do this, just set it on the dock and recharge it. But IF you remove the main battery, and IF the camera is...elderly...the small battery has died and the clock has stopped and the camera has to know what time it is to run. Once you tell the camera what day it is (look in the viewfinder- it's asking for it) she'll fire right up.
I hope this works. These cameras are great. I cna change batteries in about 5 seconds now- practice. If you're fast enough, it won't lose its memory. Joe
Aug 25, 2008 | Kodak EasyShare DX6490 Digital Camera
Kodak DX6490 Error L-02
Got the same problem....get a new one.
Jul 06, 2008 | Kodak EasyShare One Digital Camera
I got the kodak dx6490 from a friend
Hello Jonboy, Well it sounds like you are out nothing but the cost of the new battery !!!!!The lens being stuck out part way is normally a drive system malfunction and the reason you are getting the DREADED BLUE SCREEN.This model due to age is not worth the repair cost.Sell it on E-Bay for parts.
Hope this helps.
May 28, 2008 | Kodak EasyShare DX6490 Digital Camera
Kodak DX6490
A repair will cost a lot- Go for a new camera
Sep 04, 2007 | Kodak EasyShare DX6490 Digital Camera
Flash won't work - possible bulb failure?
Check Kodak for repair quotes likely hood not economical though
Aug 07, 2007 | Kodak EasyShare DX6490 Digital Camera
Kodak EasyShare DX6490 Digital Camera Logo
124 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
