Question about Garden
I have a Delta Shopmaster Battery Powered Drill. The Charger has failed Details are Model CL144C, Input 120V AC Hz: 60 Output: 14.4 V DC - 2.0A Watt: 65 Type 1 Serial No. 062356 R3002 Resistor R2 has overheated and come loose. I wish to replace that resistor but cannot read the bands there-on. Please provide me with the resistance value of R2 in the charger.
  • 248 Answers
SOURCE: I have a craftsman drill
The problem could be either the result of a defective charger or a defective battery; however, I would put my money on the battery being defective.
Posted on Jan 09, 2011
DCSE
  • 191 Answers
SOURCE: Charger Voltage and Watt Differences
it hardly matters if u are using a 90 watt adapter instead of a 65watt
it will charger the battery much more faster
so you can use it
it should power on your system without the battery.... just check that first
Posted on Jun 07, 2008
SOURCE: What is the replacement fuse for a Ryobi 18v charger?
The fuse in mine said 4 amp. I have also used. You can use a 4 amp or lower to replace the original one that blew.
Good Luck
Posted on Mar 22, 2009
SOURCE: was given a Coleman power drill, model CMD8189. The charger is inoperable. The two resisters on the charger internal circuit board have been fried. The resistor codes have been burnt off, so I cannot
I need the same, but found a Makita multi-voltage charger and have been able to use it. The package says It is for Makita batteries only. HItachi also makes a universal battery charger. I found both at my local Lowe's. The Makita was originally $69, but was marked down to $25. The Hitachi was around $70. You can find either one for good prices on Ebay or Amazon.
Posted on Jul 05, 2009
SOURCE: charger died.
It is usually a current limiting resistor anyway... so I would think that about 100 Ohms should be all good, you generally need about 250 - 300mA to charge ya batteries. It is simple Ohms law calculation.
Posted on Feb 04, 2010
In moving I am unable to find the AC charger and plug cord for my Electric Houdini. This is brand new - never used !
What voltage is the AC ? 120V 60 Hz ??
Found this but it is for 120V 60 HZ
http://www.rabbitwine.com/replacement-parts/adapter-6-volt-2925-series-647771.html
however if your AC power is 240 volts 50Hz you need to keep looking !
What is an electric houndi - is it a electric cord screw ? this is my guess ?
Important note the 6v DC and the 80mA current rating on power AC- DC pack. If there is any marking on your Houdini similar make sure voltage is 6v DC and current is 80mA or less .
suggest you contact rabbit wine if your ac is 240 Volts and is not 120v 60 hz on the www,rabbitwine.com web site contact link or if DC voltage does not match. Or for advise on if it matches your device.
Feb 02, 2018 | The Computers & Internet
Where can i buy a battery for mcculloh drill md7d0010
The charger for my McCulloch 18V drill (Model 7488) has these specs: 18V Adaptor
Input: 120VAC, 60 Hz
Output: 18VDC, 400 mA
Model: TEAD-48-180400U
I hope this info helps you source a charger from other outlets.
Fred
Jan 16, 2013 | McCulloch Md7d0010 - 18v Cordless Driver...
Ming an ac/ac adapter model mao-122300
Are you %100 sure it's not 12v DC on the ouput side?
Jun 06, 2012 | Computers & Internet
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
Whats the volts a battery charger should put out on a toshiba satellite l305d-5394
Hi,please visit the URL below...The website has this
http://www.toshibadirect.com/td/b2c/adet...
"Power: 120V-240V/ 50-60Hz Frequency (Universal) input voltage, 19V x 6.3A output" or
Input : AC 100-240V - 2.5A 50/60 Hz - Output : DC 19V, 4.7A, 90W
both are for it...just one is bigger from " watt " point of view..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jun 26, 2011 | Toshiba Satellite L305D-S5934 Notebook
What type of ac adaptor do i need to a proform gl 125 interactive trainer
Hi
Mine says on back - Plug in class 2 Transfromer -
Input:AC 120v - 60 Hz 150mA Output:DC 9V -1A
Hope this helps
Dixie
Feb 21, 2010 | Proform GT 85 x Upright Bike at GNC
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Need Charger for Trutech PVS12701
Take it to Radio Shack2_bing.gif...they have a full line of replacement AC adapters. You may find one that matches or a multi-selectable model. You may have to order.
My PVS12701 adapter has:
Input 100-120V 50 60 Hz 0.40A
Output 9.0V DC 1500 mA
tip has + center, - outer
Jun 22, 2009 | TruTech PVS12701 Portable DVD Player
I need a battery charger for Singer Journeyman cordless drill model SJD 480. Charger P-356035. What else could I use?
The Singer Journeyman 3/8" Cordless Drill/Driver Model SJD 480 uses Singer charger model P-356035 which has the following specs:
Input: 120V 60Hz 6W
Output: DC 6V 350mA
Positive-----o)-----Negative
Mar 13, 2009 | Drills
Garden Logo
207 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
