Question about ASK Proxima C160 Multimedia Projector
I have a c160 and the ribbon cable that is soddered between the top case contoll and the main board is ripped off, where can i find a replacement?
    Sergeant:
    Champion:
  • 387 Answers
If you want to replace the cable you need to know how to soddered
if you do know i have cables that might fit in the machine
let me know if you want to buy the cable or if you can do it yourself
I can fix this
ecrdn@yahoo.com
Jack
Posted on Oct 12, 2010
My screen has vertical coloured lines on the screen. which part should i replace?
Replace the D board! That is the 5x5 board behind the main board with all your jacks on it. Be very careful disconnecting the LVDS cable from the top of the board and the ribbon cable that is on the left side. The connector for the ribbon cable is very delicate, so be careful. UN_PLUG THE SET FIRST
Apr 13, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
Hi i had problems with the touchpad keys and keys not working, tuch pad did work for a while so know it was not driver problem and as my friend gave me this EEE PC 900 as its screen was broken which i...
the keyboards break real easy they are easy to change there is 2 or 3 tiny clips along the top of the keyboard you have to push them back with a small screwdriver and lift the keyboard away and disconnect ribbon from the main unit, the touch pad is built into the case and connected to the main board with a tiny ribbon connector, check the ribbon is connected correctly, be carefull its easy to break off if the case is opened, if it looks connected ok but still not working check the driver is correct, the drivers are available from the asus website
Jan 14, 2011 | ASUS Eee PC 900 Notebook
The screen is broken no take pitchure
Remove the battery. Remove the case screws and pull the case apart. Where the flat ribbon cables connect to the main board, carefully release the clamps on the board end plugs. The plugs don't come off, the ribbon just comes out of them. Carefully remove the screen. It has double stick foam in a few spots. Put the new screen in, reconnect the ribbon cables and put the case back together. 30 minutes max.
Apr 01, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
How to disassemble an InFocus LP640
remove the top case, carefully unplug the ribbon cable from the main board, remove the 5 screws holding the board on, remove the 2 screws from the back (where the audio plugs are), and remove the 6 spacers from the vga/computer connectors. unplug all the plugs (be very careful unplugging the 3 ribbon cables in the middle. unlock the socket first by lifting up on the tab, then pull out the ribbon cables). remove the emi shield from the edge (metal clip with 5 fingers). remove the board!
Oct 30, 2009 | InFocus LP640 Multimedia Projector
How do I change the LCD screen please?
Very easy.
Remove the batery. Remove the case screws and pull the case apart. Where the flat ribbon cables connect to the main board, carefully release the clamps on the board end plugs. The plugs don't come off, the ribbon just comes out of them. Carefully remove the screen. It has double stick foam in a few spots. Put the new screen in, reconnect the ribbon cables and put the case back together. 30 minutes max.
Sep 30, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
My TV changes colors! It tints everything yellow or green or blue and etc.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ..
Mar 08, 2017 | Vizio VX32L Television
Replacing a panel control board on my LG RU42PZ61...
If they are the flat ribbons that seem like thin plastic or cardboard, typically they are hard to pull out. The ribbons on the logic board have press snaps, but those on the top boards are just tough to pull out. The key is not to bend them, but apply pressure with your thumb and index near the connector base and pull straight up. Here are some images from my unit:
Top Board Ribbons (Tight ribbon slots)
Lower Controller Boards (All those shiny dark ribbons have pressure snaps, much easier to deal with, but make sure they're secure and tight after you put them back in place)
Sep 18, 2008 | Televison & Video
No video on Ibm Thinkpad T23
hi
i also have a t23, and i have messed around with the display a lot...
there are several things to consider:
1) your operating system. i would assume you are using windows xp, and that you dont get video even before the OS starts up in the first place, but its just something to consider: i have heard of some video bugs with the t23 under linux
2) you should check to see if the laptop display and the video out problems are related in the first place. to be honest, i dont know why they would or would not be related. the display not work because a) its just plain broken (although in this case there are usually some somewhat obvious cracks) b) the ribbon cable from the display to the motherboard could have ripped (they do so very easily). if the ribbon cable is ripped in its usual place, you MIGHT just not have a backlight. make sure that there is nothing on the screen, not just a normal display extremely dark. if theres definitely no picture, then you have to take the laptop most of the way apart, but you can start with just the screen casing. its fairly easy to figure out how to take apart, but you might want to look it up. behind the screen casing you can see the ribbon cable and whether or not its ripped. oh, but before you do that, try turning the led light on thats built into the top of the screen. its also part of the ribbon cable. you can do this by pressing the fn key and page down or something next to the brightness buttons. if that doesnt work then your ribbon cable is either ripped, or of course it could just be a motherboard problem in which case all of what ive said is fairly useless information. if you want you can also take off the keyboard and top casing from the screws in the bottom and look at where the ribbon cable (and maybe the video out too) meets the motherboard, just in case theres an obvious problem or disconnect. it probably wont be very obvious. however, if you do discover fairly surely that it is the ribbon cable, then you can get them for very cheap. search "ibm thinkpad lcd video cable t23"
hope i could be of some help
Mar 17, 2008 | IBM ThinkPad T23 2647 Notebook
Mobile Display
sounds like you need a new ribbon cable 1st buy ribbon cable from ebay here are the instructions to change your ribbon cable remove battery/sim card undo 4scews tiny cross heads they are slide phone open ans at the bottom of the phone theres 2 more scews to undo these are under little plastic covers once removed starting from the bottom of the phone insert a thin wedge i use my fingernail just get it inbetween the bottom of the casing and slowly move it round the phone open the casing a little but not 2 faras you have 2 slide the casing off the tophalf of the phone once you detached the casing there will be a plug(loud speaker)just unplug this now you should be a stage where you have removed the back casing,we continue carefully prize out the main baord this will be attached to a ribbon cable so be careful remember to first remove the button and then run your fingernail where the buttons are affixed (there stuck to the casing) ok you have the main board free now turn it over so as you dont damage the cable remove the green sticker which covers the cable then you need a soldering iron to free the cable as its attached to the main board flip up the holding strip and remove the ribbon cable from the main board ok next there are another 6 tiny little screws which attach the sliding chassis remove them and remove the slidehousing ok now you need to undo 4 more screws 2 are in plain view the other 2 are hidden under the top plastic covers once they are removed the slide mech comes away freely and you can see where the the other end of the ribbon is attached again remove green sticker and desolder the pionts lift up plastic retainer and remove the ribbon replace with new ribbon and put back together the same way you undid it sound a bit tricky but its quite simple really. well i hope this helps mrjazon
Aug 20, 2007 | Samsung SGH-E900 Cellular Phone
Samsung sgh-d807
I just finished disassembly and it wasn't that bad. Take off all four screws around the battery, then carefully but forcefully take the plastic casing off. Then, take the 2 screws on the main circuit board. That will reveal one connection for the ribbon cable, take that off. Under that is the backplate sliding mechanism of the phone. There will be 6 screws on this assembly, one of them under cable the connects to the keyboarb (bottom right). You will have to take off a green tape and also a gold padding to get to this final screw. After that is off, you will see the other half of the ribbon. Take that one off also, just yank it off. Install the new ribbon tape, make sure you don't rip it, and you're set. good luck. EE
Aug 09, 2007 | Samsung SGH-d807 Cellular Phone
ASK Proxima C160 Multimedia Projector Logo
53 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
240cpa
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
