Question about Lenovo 3000 N200 T7100 1.8G 1GB 160GB SYSTDVDRW 15.4-WXGA WL BFP XPP PC Notebook
My laptop wont start!
When i turn on the power botton it start with lights on and the screen are black it suddenly stoped running and i heard some beep 3 times..
  • 114 Answers
3 beeps, You could have the following.
1. Memory Problem.
2. CPU problem
3. BIOS error
4. CMOS battery dead
If you don't know how to diagnose this, there is only one place to bring the laptop. Your local Computer shop for diagnose, and repairs.
Posted on Jun 11, 2008
    Sergeant:
  • 324 Answers
The 3 beeps that you hear is a post code that is telling you the following: You most probably have a memory problem, but it could be a bad system board.
Try removing the memory card(s). Reseat one memory card and try applying power to the laptop. If that worked and you only have one memory card, the laptop is fixed. If that worked and you have a 2nd memory card, power down and reseat the second card in the second memory slot and power up again. If that works, you are back in business.
If reseating the first memory card does not correct the problem, and you have a 2nd card, remove the first and try the second one in it's place.
If this information doesn't get you up and running, let me know and I'll give you some more ideas to work with.
Ron
Posted on Jun 02, 2008
    Problem Solver:
  • 6 Answers
The monitor has gone dead, see good, for eventually picture, if it is pic, the lumiator has gone defect!
The luminator do light up the TFT, and make you see the picture.
It happens some time, that luminator do stop working!
Asus 501j just stopped working and went black screen
are you getting any lights on?saying its on.
sounds like it over heated,can you hear if the fan is trying to run?
if so try cleaning it all out.
Apr 08, 2014 | ASUS K Computers & Internet
No screen on starting laptop
remove the battery from bottom, plug into ac power pack, and try it that way
Jun 01, 2008 | HP Compaq Presario V2000 Notebook
My hp compaq nc600 laptop wont turn on just an ornage light comes on, black screen and fan for 10 seconds then dies?
In the first instance you need to check your power lead. Exchange it for another one that you know works.
Apr 09, 2013 | HP Compaq nc6000 Notebook
My usb overheated and now wont light up and let me see my files
This is WORKED FOR ME!--->I turned off my computer than unplugged cable and took out battery, held down power button for 1-2mins and than put everything back in (battery and charger) and tried to start it...the screen was still black. I than turned it off again, than pressed ESC, while holding down ESC I pressed and held power button until it briefly turned on and back off. Than I let go of both the buttons and pressed power back on and VOILA the screen came back on. Make sure your charger isn't loose, and than you're aren't surging too much power through the outlets-sometimes these can make the screen black too.
Hope this helps others out there, I have an old Toshiba Satellite running on Windows Vista
Jul 27, 2012 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
My laptop wont turn on, the green light apears when I press the on botton and it sounds asif it's starting up, but then nothing happens, the screen stays black ?
If you have a desktop computer ,try connecting monitor cable to laptop,u may get the display.
It sounds like ur lcd or the inverter board has a problem.
Nov 05, 2010 | Acer Aspire 5500 5570-2609 Laptop
I have a dell inspiration 1100 and last night I was reinstalling Windows XP and all the drivers after installing the system drivers I got a diag>: I didn't know what promt to put in here so I shut the...
Since you have power on your laptop. I have this questions you need to answer: 1. have you seen Dell logo after turning on the computer? 2. After turning on the computer heard beeps? If all no do this
1. Turn off laptop remove batt and use ac adapter
2. While laptop is off press Fn key + Power button to run test check if you see display test in progress. If no, wait for 5 minutes to listen to beep codes. Once heard beeps keep pressing hold on N key. If fails turn off laptop
3. While laptop is off, press hold D key + power button. Check if you will see colors display whole screen. If no this will need to replace LCD call Dell.
If see colors whole screen replace motherboard call dell.
Oct 01, 2009 | Dell Inspiron 1100 Notebook
Toshiba A200 black screen after bios upgrade failled
Download the bios update, and try the diskette based BIOS update installation options.
Dec 09, 2008 | Toshiba Satellite A135-S2276 Notebook
Screen goes black
I fixed this same problem using a registry scanner. Here's a link to a good free one:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hope this helps.
Jul 17, 2008 | Toshiba Satellite A215-S7422 Notebook
Sony KLV-S23A10 takes approx 30 minutes to warm up
OFF YOUR TV WITH POWER BOTTON, THEN PRESS IN REMORE CONTROL DISPLAY BOTTON # 5 BOTTONVOL + BOTTON AND POWER BOTTON.( DISPLAY--5--VOL+--POWER)
May 04, 2008 | Sony KLV-S23A10 23 in. LCD HDTV
Lenovo 3000 N200 T7100 1.8G 1GB 160GB SYSTDVDRW 15.4-WXGA WL BFP XPP PC Notebook Logo
192 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
