Question about Refrigerators
Freezer compressor condensor tubes were blockd, while declogging lot of oil is found inside. service man said that the compressor is throwing the oil in its discharge pipe and it may further clog the tube. is there any possibility for this and what should i do
  • 828 Answers
Under normal circumstances 10% of the oil from compressor circulates with the refrigerant. Conditions which can cause excess oil to leave the compressor is starting from a shut down condition where oil is dissolved into the compressor oil. On startup the pressure is suddenly dropped in the compressor and the oil will boil out as the refrigerant leaves the crank case. In most cases the oil will return to the compressor as the system continues to operate.
If the compressor is in a continuous operation the problem can be the compressor itself that is causing the excess oil carryover. Other items that may cause a blockage is the WRONG oil being used in the system. In 48 years of refrigeration service I have never run into such a problem as you are describing.
Posted on Jun 02, 2008
Should the condensor coils be warm or cold
The condensor should always be blowing warm air. When warm air comes from the condensor this is the Freon being used to take warm temperatures from inside the refrigerator. If the air coming off the condensor is the same as room temperature it would indicate that the compressor is not running, If you have other questions please let me know, Thanks Sea Breeze
How a Refrigerator Works
Jun 27, 2012 | Amana Refrigerators
Tip
Moving a refrigerator, freezer, or a combined refrigerator/freezer
Many people often stress over laying a refrigerator or freezer down in the back of a truck in order to move it. It has happened many, many, times that one of these appliances is laid down in order to move it, only to find that the compressor is ruined within a few hours after having plugged the unit back in.
By the same token, it is hard to just dead lift one of these appliances into the back of the truck without tipping the unit on it's side.
The purpose of this trick, or tip, is to avail anyone of what to look for should they need to move one of these unit's.
The reason the compressors fail is lack of oil in the compressor, caused when the compressor is oriented where the oil can go run into the disharge tube which is headed to the condensor coil. Most all modern domestic refrigeration compressors are built as where the enclosure is at the condensing pressure, which is why they get real hot when they run. The high pressure gas is easily pushed into the condensor as the compressor runs. But, if the appliance that the refrigerator is in is tipped over where that tube is on the bottom, then the oil runs in there as well. And when the appliance is stood back up, the piping usually does not allow all the oil to run back into the compressor. If the compressor is started before the oil has a chance to run back, then it get's pushed by the hot refrigerant further into the condensor coil, and on to the evaporator where it becomes cold and thick, to the point that it doesn't want to return to the compressor. This makes the compressor run on low oil, and after doing this for a few hours, it seizes up.
So, in order to lay the unit down, all you need to do is look at the compressor tubing. THere will be three pipes or tubes coming out of the compressor. On eis short, and crimped, then soldered closed. That is the service tubing where the unit is charged at the factory. One is the suction tubing that is the tube returning from inside the refrigerator. And the last is the hot gas discharge tubing, going to the condensor coil. In most all deomestic refrigerators, the suction and discharge tubes come off the same side of the compressor, which is the right hand side of the compressor as you stand at the back of the refrigerator looking at the compressor. That means if you lay the appliance on the left hand side, when standing in the same position, that oil will not have any place to run to, and will stay inside the compressor. You can lay or tilt the appliance on that side all you want, aadn never have any issues when starting the unit up after moving. And you can start tyhe unit up immediatley. You don't have to wait for 8 hours or anything.
Now, if you find you did an oops and laid the applicance the wrong way, then be concerned, there is a way to save the unit. Stand the unit up and wait for 6 hours or so before pluggin the unit in. Plug it in, and allow to run for 2-3 minutes. Unplug, and let it sit for 5-10 minutes. Repeat this for 8-10 times, then allow it to run for 30 minutes or so. DO this a couple of times, and you should be good to go.
on Feb 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a sub zero 361rfd. The freezer portion is no longer cooling, however the fan still runs. Also, The refrigerator is set to the coolest temperature but I suspect it's not sufficiently cold....
Check the temperature setting Assure that there is enough room for air flow in the freezer or freezer Check for air flow restrictions in vents Test the temperature control Clean the condensor coils Check the door seals Test the door switch Test defrost heater Test defrost timer Test evaporator fan Check for a clogged drain tube Check for refrigerant leak Freezer is too cold
Check the temperature setting Test the temperature control Freezer is noisy
Hissing and popping is normal, it is the defrost heater. Check that the freezer is level Check the drain pan Check the condensor fan Check the evaporator fan Inspect the compressor mounts Freezer runs continuously
Defrost the freezer Clean the condensor coils Check the door seals Freezer starts and stops frequently
Clean the condensor coils Check the outlet voltage Test the condensor fan Test the compressor relay Test the overload protector Test the compressor motor Freezer does not defrost automatically
Test the defrost timer Test the defrost heater Test the defrost thermostat Freezer has an unpleasant odor
Remove spoiled food Clean freezer interior with a solution of h Clean freezer interior with a solution of hot water and baking soda Clean the door seals Remove breaker strips and check for wet insulation Water on floor outside of freezer
Check the drain pan If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve Water inside the freezer
Check for a clogged drain tube If you have an ice-maker, check freezer and ice-maker for level
Hoping that this will help to solve the problem....
Aug 18, 2011 | Refrigerators
I have a magic chef refrigerator model # mcbr415sf. The top freezer part does not get cold enough to keep ice cream cold, but when you turn the temp up -- there is only one temp control and that controls...
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
You can fix this by yourself and do take care in solving the problem......
May 12, 2011 | Refrigerators
Kenmore 253. 9287413 Can't get the freezer to get cold enough. Freezer alarm keeps turning on and the temperature is only 25 degrees inside. Temperature alarm light stays on all the time. Quick freeze...
You can fix this, just follow the procedure given to enable get back your refrigerator going,
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
I hope this will help in solving the problem......
May 10, 2011 | Refrigerators
MY FREEZE WILL NOT GET COLD OR FREEZE ANYTHING
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
If you have an ice-maker, check freezer and ice-maker for level.
With all this it helps to solve the problem....
May 04, 2011 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Freezer not cold.
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
Hope this will help in solving the problem.....
Oct 07, 2010 | Frigidaire Refrigerators
The freezer side is not keeping food frozen. Every three minutes I hear something turn on and it runs for about xx seconds. The model number is ASD2626HES. The refrigerator side seems fine.
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
Hope this solved the problem, Take care....
Sep 19, 2010 | Amana ASD2626HE Stainless Steel Side by...
Freezer isn't getting completely cold the everything is running the copper tubing that runs through the inside of the freezer for the shelves and such only about the first two feet from where it comes into...
If your condensor is clean, and your condensor fan motor is running,(some freezers do not have a condensor fan), then you have a freon system problem. Usually a bad compressor, but can be a leak or restriction. Not worth repair unless it still has a system warranty on it. Usually 5 years for most brands. Good Luck, Appliance Specialists
Dec 31, 2009 | Freezers
Fridge compressor hot. inside of fridge/freezer is not. compressor humming(assumed to be running).Whats an indicator of low freon and can it be refilled? Thanks!
low refrigerant may be indicated by outside tubing at room temp (or at least most of tubing) when compressor running. can be confirmed by pressure checks on system. Refrigerant can only be checked or recharged by qualified (card carrying) appliance tech or refrigeration tech. be sure to clean condensor (outside) tubing and make sure fan next to compressor is running if there is one.
Jun 20, 2008 | Refrigerators
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
