Question about Emerson EWC19T4 19 in. TV/VCR/DVD Combo
The picture on my EWC19T4 has a green tint. It is the same on all functions. I have tried adjusting the tint and color but makes no difference
  • kami2477 Oct 19, 2010
    Yes, when I move color all the way to left to shut it off I have black
  • kami2477 Oct 20, 2010
    Is the CRT Board a replacable item? Or is it more than the TV is worth?
  • Emerson Master
  • 5,138 Answers
When you turn Color OFF ,Do you have a Black and white picture?
Posted on Oct 19, 2010
  • ladywinn
    ladywinn Oct 19, 2010
    Problem maybe in the CRT Board,it connects on to end of picture tube or Video IC.
  • ladywinn
    ladywinn Oct 21, 2010
    Here is a list of companys who may have CRT board Mats 1-800-628-1118
    Encompasss Parts 1-800-638-3328
    Partstore.com 1-866-925-7278
I own a Quasar SP-3235 32" TV. It has a slight green tint after 10 years of use. How can I adjust the color screens on this set? Is it a function of the remote like Sony TVs or do I need to remove
I would open it first and look, a lot of those had both the screen and drive controls on the PCB at the end of the picture tube, at least look there first.
You are dead on in looking for the screen controls, if you find one it should only be a tiny adjustment due to age and the Crt changing a bit.
Dec 13, 2012 | Quasar SP-3235 32" TV
Green tint on picture 60in mitsubishi
Turn the color all the way off---examine the screen to see if black and white or screen green in areas or whole screen.
The other possible issue is tint will not vary enough from green to purple when adjusted.
Two different issues--which do you seem to have?
May 31, 2012 | Mitsubishi WD-60737 60 in. HDTV
Green picture
Possible needs color tracking adjustment done by shop.
Apr 18, 2010 | Samsung HLN437W 43" Rear Projection HDTV
Bluish green tint to television picture
Find out what board and circuit is responsible for the color and you have your answer.
Mar 12, 2017 | Panasonic PT-52LCX66 Projection Television
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Picture has green tint
use menu on remote adjust tint to center
Mar 23, 2008 | Philips 9P5034C 50" Rear Projection...
Color Problems 60PP9352 60" Rear Projection
Check to make sure the green is lit up! You will need to remove back and look inside to tell.
Jan 06, 2008 | Philips 60PP9352 60" Rear Projection...
Emerson EWC19T4 19 in. TV/VCR/DVD Combo Logo
75 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
