Samsung SGH-D900 Cellular Phone Logo
cha k Posted on Oct 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a D900 and his sound is not loud how can i make it loud volume is on level 5 but his sound is not loud
Anonymous
Level 2:
Sergeant:
  • Expert 172 Answers
  • Posted on Oct 12, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
172
Questions
0
Helped
20180
Points
548
You must replace your phone speaker
1helpful
2answers
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How can I increase the loudness of the CDs burned on the internal CD-RW drive?
You can use a free software audio editing and recording program called Audacity. Using this program load your stereo track(s) into Audacity, then look in the effects menu and select normalize. Make sure to set highest loudness level to 0 db, which is the maximum digital volume level. You can hear the difference in volume when you use the test button. If you can't still get enough over all volume level with the normalize feature then you will need to compress and limit the stereo track, but I don't suggest getting your over all loudness levels that high because it ruins and lowers the dynamics of your music. Another words when you compress and boost the over all loudness of your album then all your music is at the same highest audio level which is very ear fatiguing. It may sound better to you at first at louder volume levels but you will quickly learn to hate it over time because it does not sound natural. That is why most music today is all about loudness and ear fatigue. And because of the loudness wars going on today every Record company is trying to have the loudest album out there thinking it will sell more copies. It is all false baloney, it really should be about the quality and dynamics of your sound instead of how loud it is.
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
How to adjust hearing volumn on samsun cell phone
Adjusting the volume during a call Use [up navigation /down navigation ] to adjust the earpiece volume during a call. Press [up navigation ] to increase the volume level and [ down navigation] to decrease the volume level.
2helpful
2007 Saturn Aura XE, the audible alarms can hardly be heard
Good news - they're adjustable. The radio is used to adjust the vehicle's chime level. To change the volume level of the chime, press and hold push-button 6 with the ignition on and the radio power off. The volume level will change from the normal level to loud, and LOUD will appear on the radio display. To change back to the default or normal setting, press and hold push-button 6 again. The volume level will change from the loud level to normal, and NORMAL will appear on the radio display.
Note: Each time the chime volume is changed, three chimes will sound to indicate the new volume selected.
MY MUSIC DONT GET LOUD AND THERE IS A LOUD STATIC COMIN FROM MY SPEAKERS AND MY VOLUME IS TURNED ALL THE WAY UP
Hey there, you have a sound level on your computer, available in the control panel as well as the volume knob on the speakers. Check the sound level on your pc. Let me know if this doesn't help.
seth
2helpful
To increase up volume
The code is: *#0206*8378#
Then go in: H/W Test > Audio Settings > MP3 spk
change 'ear gain' to 14.
Then, enter 'Rx vol.'....
I made this changes:
Level 1: 150
Level 2: 180
Level 3: 210
Level 4: 260
Level 5: 300
Level 6: 370
Level 7: 460
Level 8: 550
Level 9: 640
Level 10: 700
Level 11: 800
Level 12: 1000
Level 13: 1350
Level 14: 1400
I made this changes and the sound of mine became very loud now...
You can do your own changes,
1helpful
2answers
PRIMA 32" TV
if you know how to solder, try to solder the system ic an the sound ic but be careful of short circuit.
21helpful
Samsung F250
Level 1: 150
Level 2: 180
Level 3: 210
Level 4: 260
Level 5: 300
Level 6: 370
Level 7: 460
Level 8: 550
Level 9: 640
Level 10: 700
Level 11: 800
Level 12: 1000
Level 13: 1350
Level 14: 1400
You can do your own changes, but don't abuse.
\o/
Sony STR-DE475 - Sound levels dropping
When did this start? Did it ever work right?
How's the sound from your TV speakers by itself and from DVD? The same? Problem's in the TV.
If it's just the receiver doing it from both sources that's where we start.
Check the settings for dynamic range (ratio of loud sounds to soft sounds) in both your receiver and your cable TV tuner. Many devices have a setting sometimes called "MidNight Mode" to be used in the event you're listening while someone else might be sleeping or otherwise would be disturbed by the TV volume.
The assumption is that you will turn the TV down but that normally means you would lose the quiet programming in the background nosie of your home. Through the magic of dynamic compression the quiter sounds are raised to audibility while loud things like explosions and fanfares will be limited in volume. Depending on the design and whatever the broadcaster is doing to the sound themselves this could be anywhere from pleasingly effective to aggravatingly inconsistent with odd variations in the levels.
Hope this helps.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
