Question about Samsung SyncMaster 793DF 17" CRT Monitor
I want to know how install the wire color in the pins in the order
  • 11,361 Answers
Creative 9 pin male din damaged
The only way to go is Replace the 9 pin adapter. Radio Shack may have the adapter, check them out. You will need to be observant when locating the proper colored wire corresponding with each pin. Two ways to do this and all require a soldering iron. Either split or open the cover on the 9 pin male adapter and expose the wires going to each pin. Identify the colors and pin numbers and draw a diagram on paper to keep for reattaching the wires later on. Cut 1/4 of the insulation back from the end of each wire and tin the wires. In short, hold the solder to the wire ends and heat with the iron so a flow of solder runs along the bare wire. Make certain to put a connector cover onto the wires prior to soldering each wire in place on the pin end. Simply set the correct colored wire end in the proper pin number, hold the iron to the pin back end and allow the wire to affix itself. Do this with all wires. If you do not have 9 wires, that is not unusual, just do the procedure with what wires are available. If you cannot get the outer jacket off of the current 9 pin connecter, then you will need a Volt/Amp meter. Here you simply cut the wire approximately 1/2 to 2/4 Inch back from the cable 9 pin adapter, and locate the pin that corresponds to the colored wire. Using the RESISTANCE part of a meter, when you touch the two probes together the needle moves on the scale. Touch one end to a pin and try each colored wire end until you see the movement on the scale. Now you know what color corresponds with each pin. Solder each colored wire as mentioned above.
Dec 15, 2013 | Creative Technology SBS A200 2 Speakers
Hi,Excuseme.I have 16 pin connecter of the JVC KD-S575. But,color of the wires does not match the position of the pin.I want to know the position of the 16 pin connecter of the JVC KD-S575 It has 2...
Car manufacturers donot keep color code. Your best bet is to order a universal adapter. JVC color code can be found in the instruction book. I will attach a picture. upload is not working. email me to jpulickal@gmail.com
Oct 02, 2013 | JVC KD-S570 CD Player
I want all the pin details of motherboard diagram for GA- 8i845GV
Download the manual from Gigabyte;
http://download.gigabyte.eu/FileList/Manual/motherboard_manual_8i845gv_e.pdf
In order to view the manual you'll also need to download and install Adobe reader; http://www.adobe.com/products/reader/
With Adobe you can zoom in on any page. The manual is put together in such a way that you'll be able to connect everything. Most people have trouble connecting the, chassis front panel. Since wire colors vary from case to case you'll find each two pin jumper will share a specific wire color. Normally this common wire color is white and is used as negative.
(Except for the MB speaker). Common wire color for the speaker is, "red for positive and black for negative".
Take you're time and follow the manual.
Mike
Apr 28, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Hi . I have foxcon 760gxk8mc-rsh motherboard and i disconnect all wires.I connected most of it and only don't know where I should connect power sw and reset sw( in which pin)
If you do not have you're manual for the motherboard open the link provided below and download it; http://www.foxconnsupport.com/download.aspx?models=en-us0000190&category=C000000001&series=en-us0000003&keywords=&sort=Motherboard
You will also need to download and install Adobe reader in order to view the manual. Download Adobe form the link; http://www.adobe.com/products/reader/
Open to page 4. This is motherboard layout.
Turn to page 13. Here you'll see how to connect the front panel, [FP1] jumpers. The wire colors define which wire is positive and which wire is negative. Each set will have a common color. This common color will be used as negative.
Cheers'
Mike
Feb 23, 2010 | Computers & Internet
Hi i need to know the color code to assemble a new 3 prong stereo 1/4 inch jack for a shure sm 58 microphone. i need to know the order and color to reassemble the mic cable to a new 1/4 inch guitar type...
Unfortunately, different cables use different colors of wires. Thus, you'll have to see what colors are connect to both ends of the cables. Here is the wiring:
XLR -> 1/4 inch
Pin 1 -> Sleeve
Pin 2 -> Tip
Pin 3 -> Sleeve
Dec 24, 2009 | Audio Players & Recorders
Need info on how to change wiring from recirculation to remote
get another electrician, he doesn't know what he is doing, this is not easy to figure out without diagrams of the connector that shows exact wire colors and where they go or went in prev installation..
Apr 10, 2009 | Thermador UCV36ASS Kitchen Hood
JUST NEED TO KNOW WHAT PIN RECIEVES THE B +
Ken,
Most common for all car Stereo wire color coding are:
Solid RED wire = +12V
Solid Black wire = negative ( - )
Solid Yellow wire = +12V (power ON /OFF) can add additional toggle switch for switching on and off the car stereo
Solid blue wire = Power antenna
the rest of the wires are for car speaker having positive and negative polarity.
note: for the speaker connection wires, all the solid colored wires are positive side (+) of speaker. those solid colored wire with stripe black line are for negative side (-) of the speaker
cheers,
mark
Dec 30, 2008 | Pioneer 12" Shallow Sealed Enclosure,...
RADIO INSTALLING
there is a code for color!? ok, wait im searching...
found it! here you go, hope it helps...
Wiring color codes are the identification colors that color the wires in your automobile. For example, if you have a British car the blue, blue and white , and blue and red wires are for the headlights. The red and white wires are for the instrument lights, and the green and white and green and red wires are for the turn lights. The color code simply identifies what that wire does. Could you imagine if all of the wires were the same color. You couldn't identify anything in a harness.
Jun 19, 2008 | 2001 Chevrolet Tahoe
Samsung SyncMaster 793DF 17" CRT Monitor Logo
70 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
