Question about Sony Playstation 3 (PS3) Console
Power is on and menu options appearing but when you insert a game it doesnt appear on the menu so you can enter and play on it
    President:
  • 2,777 Answers
Hello there, sorry to hear about this problem. This is unfortunately fairly common with the Playstation 3, it means the laser unit on the actual disc drive of the Playstation is having problems. Depending on how old your system is, Sony will fix this for free, or there may be a small fee. At this point you will want to call Sony at 1-800-345-7669, unless you want to try and replace it yourself. It is very hard to do though. I recommend you call them and explain the problem, they will definitely get you fixed up.
Please be sure to rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful. If you have more questions on this or need further clarification please just respond to this answer and I will get right back with you. So sorry you have to go through this, but Sony will definitely help get you fixed.
Thanks
Tim
Posted on Oct 12, 2010
MATTEL POCKET UNO GAME INSTRUCTIONS (how to change the number of players)
Here is the information you requested:
GAME OPTIONS The default options for Electronic UNO® are a Level 1, 4-player game with the sound on. If you want to change those options, this is how you do it:
1. Press the Menu button and "New Game" will flash. Press the Select button and "New Game" will stop flashing-Press again and it will go out. If you press Enter/Play with "New Game" showing you will start a new game.
2. Press the Select button then press Enter/Play. The Player 1 icon will flash.
3. Press the Select button to cycle through the number of players, represented by the 2, 3, or 4 icons, and press enter when you choose the number of players you want.
4. After the number of players is selected the, Level will begin to flash. You may change the level by using the Select button to cycle through Levels I, II or III. When you see the level you want, press the Enter/Play button.
5. Once you have selected the level, you will see the musical note icon flashing. This is the sound indicator. You may turn the sound off or on by using the Select button to make the note appear or disappear and then press the Enter/Play button. If you can see the musical note the sound is on. The Hi Score will be displayed and the player that achieved it. Press Enter/Play to start or return to your game.
6. You may start a new game, check the Hi Score or turn the sound on or off at any time by hitting the Menu button.
Jul 15, 2017 | Mattel Toys
Tip
Games Explorer link does not work in Windows 7 or Vista.
To open the Windows Vista games folder, you'd normally click on the Games Explorer link in the Start Menu.
You have to ensure that it appears there in the first place.
If it doesnt appear, Click Start > Rt Click > Properties > Start Menu tab > Customize > Select Games > Display as a link or Display as a menu > OK > Apply > OK
Incidentally, if you type Shell:Games in Vista's start menu search bar and hit enter, then too the games folder will open.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); But if the Games Explorer folder does not open in your Windows Vista, here is what you may try.
Type cmd in Vista's start menu. When cmd appears as a result, rt click on it and select Run as administrator.
In the elevated command prompt, type
regsvr32.exe gameux.dll and hit Enter. This will re-register the ganeux dll file.
It should help.
on Jun 25, 2010 | Computers & Internet
Tip
Try this to play DVD movies on your PS2 if it wont play DVD movies.
If your PS2 works fine with Games and just wont play any DVD movies at all.Then you should try this trick to play movies on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:894e4e5.jpg
  3. Press the ps_b_triangle.gif (triangle) Button to enter Version Information Menu that looks like3aef030.jpg
  4. Highlight the Play Station Driver as above and again press ps_b_triangle.gif (triangle).
  6. Highlight the Disc Speed as above and press ps_b_x.gif button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the movie plays itself.If your lens is good then it will play DVD in first go else try again till it PLAY your DVD movie.
Thank you!
on Nov 29, 2009 | Sony PlayStation 2 (PS2) Console
Leapster restarts select cartridge game
Try this
Ensure that a cartridge is not inserted
Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.When the LEAPSTER menu screen appears, press the A button.Touch each of the crosshairs that appear with the stylus, Restart unit
Aug 13, 2014 | LeapFrog Leapster 2 Learning System
Where do I enter the cheat for mx unleashed
Choose the "Options" selection at the main menu, then press L1 or R1 to cycle from the "Game Settings" option until the "Cheats" option appears. Then, press Down until the desired cheat option appears. Press Circle to display a keyboard that is used to enter the code to unlock that cheat option.
Read more: http://www.cheatcc.com/psx2/mxu.html#ixzz37jCIuMBj
Under Creative Commons License: Attribution Non-Commercial No Derivatives
Jul 17, 2014 | Video Game Consoles & Games
My two girls have dsi,s how do the play with both ds,is on one game
hi there this should help ye out
Playing multiplayer with one Game Card:
Certain Nintendo DS games require only one player have a copy of the game to play multiplayer. Those without a copy of the game will need to download the game information from the player that has the game in their system.
This feature is available on games that have this icon on their packaging:
    To download game information:
  1. Insert the Game Card into the DS Game Card Slot on one system and slide it into place until it clicks. Turn the system on by pressing the POWER button.
  2. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears. If the host DS system's Startup Mode is set to
    • Automatic. The game's menu will appear.
    • Manual. Tap on the box for the Nintendo DS Card Slot using the stylus to start the game.
  3. Turn on the other Nintendo DS systems. For each of these systems, when the main menu appears, tap on the "DS Download Play" icon on the right, middle side of the screen to display list of available games.
  4. Tap the title of the game to begin the download.
  5. See the individual game's multiplayer instructions for additional game play information.
  • Playing multiplayer with multiple Game Cards
    Games that require each player to have a copy of the Game Card inserted into the Nintendo DS will feature this icon:
    multi_pak.gif Because each individual game title has its own method for setting up multiplayer games, you will need to consult the instruction manual for that particular title.
Jan 18, 2011 | Video Game Consoles & Games
Can't connect to router by wireless and by local area connection with cable, it just saying limited or not connectivity, even after router reset.
Locate the MAC Address for the Computers You Want to Use for Gaming
1. Click the Start button.
2. Click Run.
3. In the Open box, type the following text:
cmd
4. Click the OK button.
The command prompt screen appears.
5. At the command prompt, type ipconfig /all
6. Write down the MAC (Physical) address of your computer to configure for gaming.
Change Router Settings
1. Open a web browser, and type http://my.router, or http://192.168.2.1. The Enter Network Password login prompt appears.
2. Type the following text in the user name and password fields: "admin".
3. Go to the Advanced Settings menu option tab on the top navigation bar and wait for the menu to appear.
4. Click the DHCP Server Settings menu option in the drop down menu.
5. Click the Add button in the IP Address Reservation section.
a. Enter the MAC address of the computer you wish to use for gaming in MAC Address field.
b. Enter an IP address for the computer.
6. Click the Submit button.
7. Go to the Advanced Settings menu option tab on the top navigation bar and wait for the menu to appear.
8. Click the Port Forwarding Settings menu option in the drop down menu.
a. To set a single computer for gaming, click to select Enable DMZ Host.
b. Enter the IP address of the computer in the DMZ IP Address field.
c. Click the Submit button.
NOTE:
Only a single computer can be set for DMZ service. To set multiple computers for gaming, please refer to the Custom Port Forwarding Settings under Port Forwarding Settings.
9. Reboot the client computer. The client computer will use the newly assigned IP and will not have any TCP/IP ports blocked by the firewall feature of the router.
Oct 28, 2010 | Dell Wireless 2350 Router
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
Wii cant play the game
Hi . i have had this sorta problem when i play the resident evil game. I find that if you go to your menu on your startup screen and change the screen resolution it should work. some games require certain television res to allow play.
Feb 28, 2008 | Nintendo Wii Console
Couldt find_ds_menu.dat
Do you have your DS set on Auto Mode, if so the DS will automatically start up any games that are inserted.
Deselecting Auto Mode:
If it's on Auto Mode, any games are automatically started. To deselect auto mode you just need to start up your DS without any games in either of the game slots, then it'll go to the DS screen, since no games are in for now this screen is useless right?
To select Manual Mode ( where it goes to the selection screen ) as your preffered setup, you'll see a small icon of what resembles a DS at the bottom of the menu screen. Remeber your games are still not inserted at this point yet. Use the directional pad to select the mini icon, or you can tap it twice. Tapping it proves more difficult though due to it's position. Once selected a toolbar of four options will appear, tap on the one displaying a wrench. From that box three other options should appear, tap on the one shown as an arrow pointing halfway through a rectangle (start up settings) you want to select Manul Mode. Wait a few seconds for the DS settings to save then you can turn it off. Now you'll be able to see the selection screen with your games inserted.
Summary of all that:
  1. remove any inserted games
  2. turn on to see the menu screen
  3. select the mini DS icon at screen's bottom
  4. when the four pictures appear, tap on the one of a "wrench"
  5. when three more pictures appear tap on the one of an arrow pointing half way through the rectangle
  6. two options appear, select manual mode.
I really hope thats what you meant ^_^ If it wasn't, ask one of the experts.
Dec 30, 2007 | Nintendo DS Lite Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
