Question about Ovens
Greetings, LG oven model # LSC5622WS is showing an F-7 error code. The oven, broiler and warming drawer wont heat up at all, simply display a 100 degree temp on control panel. Elements, clock etc all work as they should still. Help!! :)
  • honestlydish Oct 12, 2010
    Thanks!
    Code doesnt re-appear, but problem still persists.
    By ERC, do u mean the largest circuit board in the back? There's lots of 'em!
    Thanks for the link!
    Just to clarify, when you say 'control board', do you mean the larger or smaller of the two pcb's?
    If u look at the picture of the touchpad (part # 1366629) on the site-link you forwarded, that is the same as mine. Should I be ordering the smaller or larger one u can see there?
    Cheers!
    President:
  • 1,796 Answers
Hi!
Let's try this:
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Posted on Oct 12, 2010
  • Rene J Solis Oct 12, 2010
    click on the following link and check the control board that look like the one on your unit. http://www.repairclinic.com/LG-Range-Sto...
    The touchpad/control module #1366629 is the part the manual calls for replacement. This supplier says the item has been discontinued by manufacturer, you need to call LG to get the replacement item # or to find out where you can get yours rebuilt, you may want to ask how much will it cost before they send somebody over, just to be in the safe side. Good Luck!
What is a error code F/19 mean?
That error means that the lower oven is not heating fast enough. IT should rise to over 150 in 5 minutes. Check the broiler and the baking coils for continuity. If they are ok then check the radiant heater in the convection fan housing.
May 12, 2015 | LG 30" Built-In Double Electric Convection...
Kenmore warm ready drawer oven
I don't know about the burner... but the oven needs a safety valve (or the igniter) The safety valve is about $140. some people would rather replace the whole range than pay for the part and the service call.
Oct 20, 2013 | Ovens
GE wall oven gas model # JGRS14 won't heat past 100 and I don't see any flames
if you can see the ignitor glowing on either the broiler or the lower area of the oven then the gas valve is bad and not opening anymore,sometimes the ignitors are the culprit as they are in series with the gas valve and if weak wont let the valve open,but both upper and lower burners not operating i would suspect a gas valve first
Nov 24, 2012 | GE JGRS14 Gas Single Oven
It's a Model JJW8530CAB. The baking element
Are you having any issues at all with the display at all? Did this start out of the blue or did you have a power outage or anything else?
Jan 20, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Bottom element is not heating to temp an shuts off during heat up - without error code showing in the display. IE. - Press Bake, 350 degrees defaults on screen; Press Start. YOu hear the Click as it...
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 05, 2011 | GE JTP15 Electric Single Oven
F3-error. Kenmore classic oven Heating element will not go pass 100 deg. Heating element recently replaced. Broiler is also malfunctioning
Hello there:
Whenever you get the dreaded f-3 code this is the code that tells you that the temperature sensor is going bad or already has gone bad and needs to be replaced immediatly. It should look something like this and cost about 50 dollars
Jun 20, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
790.7921
Does the bottom ignito glow when the "bake" option is selected? If not, replace the ignitor. Even if it glows, it may not be achieving the electrical resistance value needed by the safety valve to open thus allowing the gas to flow to the burner.
Aug 23, 2007 | Kenmore 30172 / 30174 / 30179 Gas Single...
Ovens Logo
359 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
