Question about Ovens
Remove light globe from simpson harmony nova oven
Hi I do not have the instruction manual for my oven.  The light globe has blown and needs replacing but I can't work out how to remove the old globe.  There appears to be a cover inside the oven but I have tried turning this to no avail.  I don't want to force it in case this is not the way in.  Please help.
  • johnnywangst May 02, 2009
    I have the same problem and I couldn't turn the cover glass anti-clockwise to solve the problem.
  • ARYLIOA Feb 14, 2012
    I also found the cover to be hard to turn. It finally turned out as expected after wiggling it a bit while still in place and turning it back-and-forth a bit as I wiggled it. It is also a bit hard to put back in without cross-threading it but the same technique finally got it in properly. (After I found out the bulb had only worked itself loose a bit! But now I have 2 spares and know how to change it if I ever need to do so.)
The glass cover is a screw in. You will need to remove this by turning anti-clockwise to get to the globe.
Posted on Oct 19, 2008
Simpson Harmony Nova electric oven heating problems (oven heats but no fan and light)
The Fan has ,in most cases, two functions - to maintain the oven temp and to clear any condensate or smoke coming from items being cooked. If your oven is over heating it could be the thermostat sensor faulty and giving a faulty reading to the fan. If you set you oven at 350F then sensors control the heat by kicking the heating elements off and in some models and makes the fan aids cool down. Make sure it is at a temperature that would trigger the fan to cool it down. It mostly relies on the regulation of the heating elements to control the temp. Only if it were to get hotter than the elements kicking off can control should the fan kick on. Not being at the site and actually seeing the stove it is hard to determine but if the fan is working every where else it should work when the oven is heating. Again check and see if there is a seperate sensor that monitors the temp of the over and triggers the fan. Not much help but that's where I would look first. Hope this was of some help.
Col. Dana Gillespie
May 11, 2014 | Ovens
Simpson Nova oven model 63-538 fan and light not working
I have the same oven and the fan doesnt work intermittantly. I turn it on and off a few times and if that doesnt work I give the fan a push with the handle of a wooden spoon. Works so far so I havent bothered with a 'real' fix as yet.
May 21, 2012 | Electrolux Ovens
Outside glass on oven door exploded, can't find replacement code, as ID plate in oven unreadable. Model 65-867
I'm presuming that this is a Simpson Nova 65-867
By the look of all the data I can find, this is an Australian appliance. I'm in the UK, and I was presuming that you were in the US, but maybe you're in OZ.
If you are then you can go to
http://www.alliedappliance.com.au/about_allied_appliance.htm
And mail them with a request for help. They advertise loads of spare parts for your oven (but not glass in the listings I have seen). I imagine that they will be able to source what you need.
You can also make enquiries at The Big Warehouse.com, who also stock parts for your oven:
https://spares.bigwarehouse.com.au/contact_us.php?osCsid=3b1cdec4545fb97a677f2646a2b69530
Finally, go directly to Simpson. Contact information as follows:
Simpson appliances are stocked by a wide selection of quality electrical retailers throughout Australia.
To find your nearest outlet, please call our dedicated customer care number:
1300 363 640
For service related questions please call:
13 13 49
For information about spare parts call:
13 13 50
http://www.simpson.com.au/locator/search/retailer/
Worth noting that Simpson are part of the Electrolux group, so you may get help through a local Electrolux agent as well.
Jun 30, 2011 | Ovens
How do you change light globe in simpson evolution 904 oven
The glass cover definitely unscrews anti-clockwise, but mine was impossible to start moving by hand. I used a pair of adjustable pliers and while the glass cover is made out of pretty thick glass, I didn't want to be squeezing it so I set the pliers jaws to exactly the same width as the glass cover. Because the glass cover has 4 bumps set around it, the pliers jammed on them so I was able to unscrew it.
BTW, the globe under the cover is also a screw mount job - if you're looking for a replacement, keep in mind that it has to be a max of 25W.
Oct 26, 2010 | Ovens
Simpson Evolution 906 Oven light. how to replace it?
I have just replaced mine & had the same problem. I couldnt remove the cover. I found that I just couldnt grip the cover well enough. I got some rubber washing up gloves & used them to grip the cover. It was still tight but it un skrewd quite easy this way.
Jun 28, 2010 | Ovens
Simpson Harmony Nova Thermaflow Oven (63B906W) won't heat up
Hello,Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
May 26, 2010 | Ovens
Looking for manual simpson nova 63538
how does the clock work an how do you reset it
May 13, 2010 | Ovens
Griller on simpson harmony nova oven
In my experience, it is normal to leave the the door open when grilling, otherwise it is liable to cause the bakelite handle of the grilling pan to get very hot, and possibly melt or catch fire, and make it to hot to hold the handle.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Ovens
Ovens Logo
1,269 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
