Question about Brother MFC-5840CN All-In-One InkJet Printer
When i press print quality the print quality black very poor and the other three colours are fine
Try to reseat the ink cartridges
Then try to print or power off your printer after that then try to print.
Posted on Oct 12, 2010
Replaced black ink cartridge, but now it only prints a very faint line, cant make out what is printing
Sir/Madam
If your printed pages have a horizontal line in the text or graphics (as shown in the illustration below) or blank text, some of the nozzles may be clogged and need to be cleaned
Go to Section 2 for instructions on how to print the Alignment Check sheet and adjust the print alignment.
Section 1: Checking the print quality and cleaning the print head
  1. Print a Print Quality Check Sheet.
    1. Press Menu.
    2. Press the UP OR DOWN ARROW key or the dial pad to choose Ink Management and press OK.
    3. Press the UP OR DOWN ARROW key or the dial pad to choose Test Print and press OK.
    4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and pressOK.
    5. Press Color (Colour) Start. The machine begins printing the Print Quality Check Sheet.
  2. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
  3. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
    (A) One or more complete blocks of colors are missing:
(B) Most of the short diagonal lines are missing from one or more color blocks:
(C)Some parts of the short diagonal lines are missing from one or more color blocks:
  1. The display will then ask you if the print quality is OK for black. Press the DOWN ARROW key or 2 to choose Nofor black with the problem.
  2. The display will then ask you if the print quality is OK for Color. Press the DOWN ARROW key or 2 to chooseNo for color with the problem.
  3. The display will then show Start Cleaning? Yes No.
    Press the UP ARROW key or 1 to choose Yes and the machine will start cleaning the color ink cartridges.
  4. When the machine completes cleaning the print head, press Color (Colour) Start. Another Print Quality Check Sheet will print.
  5. Repeat the cleaning and the quality check process following the Step 4-7.
  6. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
9. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you do not see any improvement on the second or third Check Sheet, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you see some improvement on the second or third Check Sheet but it's not perfect, repeat the cleaning and the quality check process three more times (totally five times). If you do not see any further improvement after that, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (C) and you do not see any improvement on the second or third Check Sheet, repeat the cleaning and the quality check process three more times (totally five times). If you still do not see any improvement, please contact Brother Customer Service from "Contact Us."
10. Press Stop/Exit.
Section 2: Checking the Print Alignment
  1. Press Menu.
  4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and press OK.
  5. Press Black (Mono) Start or Color (Colour) Start. The machine begins printing the Alignment Check Sheet.
  6. By reviewing this Check Sheet, you can determine if the alignment needs adjustment.
  7. Examine the 600 dpi and 1200 dpi test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 dpi and 1200 dpi most closely matches the 0 sample, press the UP ARROW key or 1 to choose Yes.
    If one of the other samples is a better match for the 0 sample, press the DOWN ARROW key to choose No. The display will then prompt you to choose the sample that most closely matches the 0 sample for 600 dpi and then 1200 dpi.
  8. Press Stop/Exit.
If the print quality continues to be poor, go to Section 1 to clean the print head.
If your question was not answered, please check...
Improve poor print quality Brother
Or
If You Still need Brother Printer Help then I suggest You follow Us On For: Brother Printer Support
Oct 09, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    Sir, I hav canon ip1880 pixma. I have already refilled the black cartridge and is working fine. my question is that can I refill the colour cartridge with black ink in all its three compartments instead...
    I would not advise doing that. Once you do this you could have unexpected poor print quality.
    If you only want to print black documents then I suggest you purchase a laser printer, these printers are not expensive now and the cost to per page is cheaper than inkjet printers and they do not suffer from block inkjet nozzles.
    Mar 20, 2011 | Office Equipment & Supplies
    How do I clean my Brother MFC 210C. I've done it before ont eh computer, but can't find where to do it this time.
    Press the Ink or Ink Management key on the control panel of the machine. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set. Press Color (Colour) Start. The machine begins printing the Print Quality Test Sheet. By reviewing this Test Sheet, you can determine if the print quality needs improvement. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
    The display will then show START CLEANING? 1.YES 2. NO. Press 1 (YES) and the machine will start cleaning the color ink cartridges.
    Jan 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
    Print quality with black ink is poor throughout the page
    hi, i have one of these to, mine is still running on the "test" inks as well but i have all colours in mine, anyway i digress, you can try, going to print something , when the chose printer box apears, choose cpl300 then choose properties ( to the right ) then choose graphics thumbnail, on quality choose best, then at the bottom you will see advanced options, then just click print all txt black, and click darken txt, and that should give you nice black txt....hope this helps
    Mar 15, 2010 | Samsung CLP 300 Laser Printer
    BROTHER MFC-210 PRINTING IN BLACK INK POOR QUALITY BUT COLOURED INK FINE. USING INK MANAGEMENT TO CLEAN PRINTER NOT HELPING. HAVE TAKEN OUT AND REINSTALLED BLACK CARTRIDGE WITHOUT IMPROVEMENT. WHEN...
    Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
    Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
    Dec 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
    We have a HP Colour Laser Jet 3600n. We have
    nope...... the problem as you rightly poit out is the cartridges, most refills are poor quality and dont last, but the real ones are expensive but very rarely cause issues. If one colour is dodgy the entire colour process fails, print a square of each colour to determine which colour cart is the issue and complain to seller, 99.9% of print quality issues with these HP's is due to non gen toner....not much you can do, expensive is colour printer fullstop.
    Nov 06, 2009 | HP Color LaserJet 2600n Printer
    Prints in black are poor quality
    fist of all reunisall your printer driver ....
    if problem dose not fix .
    it means black colour laser section have problem so you can clean lens of laser if posible and replace laser secaner.
    thanks
    Apr 29, 2009 | Epson AcuLaser C4100 Printer
    Epson aculaser c1900 error code e014
    Error code 014 indicates that the cooling fan on the power supply board is not operating when the printer is switched on. Does n't explain the poor print quality though. I suspect it is a worn 2nd BTR roller (the black foam coloured roller inside the rear door). To check this send a coloured print through and press hard against the rear door during printing. If the print quality improves then it is a worn roller, if it doesn't let us know and we'll try something else.
    Please take a moment to rate this solution. Thanks.
    Mar 10, 2009 | Epson AcuLaser C1900 Printer
    My copy prints come out blurry after changing ink cartiges
    Try this:
    Checking the print quality:
    1. Press the Ink or Ink Management key on the control panel.
    2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
    3. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set.
    4. Press Color (Colour) Start. The MFC/DCP begins printing the Print Quality Test Sheet.
    5. By reviewing this Test Sheet, you can determine if the print quality needs improvement.
    6. Closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
      If all lines are clear and visible, press 1 (YES) and press Stop/Exit.
      If you can see missing short lines, press 2 (NO) and go to Step 7.
    7. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
    8. The display will then show START CLEANING? 1.YES 2. NO.
      Press 1 (YES) and the MFC will start cleaning the color ink cartridges.
    9. After the cleaning is finished, press Color (Colour) Start. The MFC/DCP will print another Print Quality Test Sheet.
    10. If you can see missing short lines in any of the four color blocks press 2 (NO) and repeat the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
    Setting the Alignment:
    3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
    4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
    5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
    6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
      If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
    7. Press Stop/Exit.
      If I could be of further assistance, let me know. If this helps or solves the issue, please RATE it.
      Thanks, Joe
    Oct 11, 2008 | Brother MFC 420CN All-In-One InkJet...
    Brother MFC-5840CN All-In-One InkJet Printer Logo
    103 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
