Question about Whirlpool LEB6300 Electric Dryer
When hit start button nothing happens...but the timer and motor are good
  • Whirlpool Master
  • 8,220 Answers
The first thing to check is for signs of air restrictions. Blocked vents and clogged dryers cause safety limits to melt and this prevents fires. So the first thing I do is check for blockages in the wall and vent pipe. when hit start button nothing happens...but the - 45df00b.jpgI don't just replace a part, I cure the problem. The next thing is to check components. Any component that does not have continuity is gonna be it. If I see their was a lint problem I disconnect the power and remove the rear cover. I take a look at the duct fuse. 298e77b.jpgThat is most likely it. The only other thing it when hit start button nothing happens...but the - c4b0f35.jpg the door switch assembly. c5d0118.jpg Manual and more photos HERE
Posted on Oct 12, 2010
try jumping the start button out on top if thats it ,replace it
Jan 15, 2013 | Kenmore Dryers
I have a 2003 sony kp51ws500 television and there's a timer on the tv and it won't turn on. A red light blinks 6 times then nothing happens. I unplugged, I hit the reset button, nothing happen
read the instruction manual and see how to operate.
if the timer is for to sleep, the problem will be the IC associates with him, you must see the block diagram and w.diagram. and tracking the signal.
go to www. retrevo.com and download the diagram. God bless you
Jul 31, 2012 | Sony Televison & Video
Power comes on. timer says 41 min but when I hit the start button nothing happens?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 31, 2011 | Dryers
2003 VTX Ran Yesterday, today hit the start button and nothing happens. Had the battery checked and its good. The F1 light comes on and you here it priming but after that when you hit the start button...
sounds like you have a bad ground somewhere on the frame.I know there is a ground on the frame just in front of the battery and one on left side under front of motor factory painted the frame and they just bolted up the wires need to clean paint off and retighten. might be the problem
Apr 03, 2011 | Honda VTX 1800 Retro Spoke Motorcycles
WONT START CAN HEAR TIMER RUNNING DOOR BUTTON WORKS MAKES START BUTTON RESET CAN HEAR IT RESET BUT NOTHING HAPPENS WHEN I HIT THE START BUTTON
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Nov 14, 2010 | Dryers
Dryer will not turn on although the timer is working
IF your hearig a click when you push the start button then the button and relay are good check the saftey switch on the door to see if it has come loose and follen down or moved back if the switch is not pressed the motor will not work also I have seen the switches go bad you need to unplug the dryer and cross the too wires togeather plug the dryer back in and press the start button if she starts order a new swith. The motor could also be bad you nees to remove the back cover and check to see when the button is pressed if you are getting the correct voltage you will need a volt meter to check this they cost around 10- 20 bucks if you have correct voltage from the wires and the conections to the motor are ok the motor is no good and needs to be replaced hope this helps...
Jul 07, 2009 | Kenmore Dryers
Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Jun 26, 2009 | Kenmore 62602 Electric Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Whirlpool LEB6300 Electric Dryer Logo
44 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
