Question about Hoover AL130 Front Load Washer
TROUBLE CHANGING BEARINGS, DUE TO BEARING SHaft pushing through the bearing as we try to draw the drive end bearing off with bearing pulleys
  • Hoover Master
  • 3,463 Answers
You will have to remove the complete drum and shaft assy from the washer to change the bearing/s, there is no other way of doing it unfortunately.
Posted on Oct 12, 2010
Is it possible to remove and replace front wheel bearings with out a press
In order to remove the front wheel bearings without press hub off the bearing and then the bearing out of the knuckle. To do the first step need a a Support Bridge.It is a special tool. Make bridge and use a general bearing pulled kit to replace bearings. use a "Front Wheel Drive Bearing Removal Adapters Puller Pulley Tool Set Kit" .To replace the bearing, remove front CV shaft taking care not to move the CV shaft too far out .
Nov 06, 2015 | 2002 Kia Rio
While mowing the drive belt tightner spring broke. I bought a replacement but the blades will not engage. The drive belt has been routed properly. it seems as though the blade's drive shaft will not spin.
Check and see if the shear pin has broken. If the pulleys spin but not the blades then the shear pin in the pulley or shaft has broken.
Mar 30, 2015 | Garden
P0741
It is most definitely a transmission code.
P0741 = Torque Converter Clutch Circuit Performance or Stuck Off
If there is a whine/whirring sound, it may be due to drive sprocket support bearing fluting and/or bearing failure.
Replace the drive sprocket support bearing. Inspect the channel plate and drive sprocket for any abnormal wear, Turbine shaft for cut seals and/or nicks, and chain for excessive play due to failed bearings.
Important:
When installing the new bearing, the part number MUST be visible (facing upward). Before installing the drive sprocket, lubricate the bearing assembly with J 36850 assembly lubricant.
Service Parts Information
Part Number = 24214158
Description = Drive Sprocket Support Bearing
I hope this helps!
Mike
Dec 15, 2011 | 1999 Oldsmobile Silhouette
How to change the bearings in a washing machine hotpoint model no wma40s thank you
Please mention if the bearings are in the drum, If so the assembly must be mechanically removed with the pulley out of the shaft and the fittings removed with the mount of the bearings.
Once the agitator is removed fromt he top and the pulley from the bottom, the shaft will come off and the bearings can be pushed out with the same size fitting to the bearing outer..might need pressure or a slight tap to move it out.
All of this only if you have a confirmed bearing which is faulty with a good indication.
Oct 07, 2010 | Washing Machines
To fit front wheel bearings honda xr 125
Hello unless there something unusual about the front wheel.
bearing removal is not difficult
once you have the wheel off remove the seals on both sides.
remove any internal snap rings or retaining rings.
now the correct way to remove the bearings is with a bearing remover its a shaft with an expandable tip and a weighted slide. when the end is inserted into the center race of the wheel bearing then the shaft is turned to expand the expandable end locking it in place then you use the weighted slide on the shaft to drive it out.
replacing the bearings easiest way is ti use a press not everyone has one of those a bearing driver or and old socket can be used to drive in the new bearings just make sure it is smaller than the inside diameter of the bearing hole and just enough to make contact with the outer bearing race do not force or make contact with the center race.
Hope this helps you out
May 10, 2010 | 2003 Honda XR 125 L
1999 chevy silverado z71 5.3 ujoints just got changed loud squeal in back sound like center of drive shaft / no vibration when driving, no play up/down side to side on drive shaft,is it in the rearend or...
i would suspect bad driveshaft hanger bearing - to confirm, jack up back end of truck and hold up with jack stands. have someone in the truck to accelerate to the speed where you hear the noise, listen for the noise - a stethescope is very useful for this. good luck!
May 10, 2010 | 1999 Chevrolet Silverado 1500
I have taken my Maytag Neptune-TL washer apart(model FAV6800AWW). The machine did not spin dry anymore do to the roll clutch bearings being frozen. When I knocked out the roll clutch bearings, I did not...
Hello datil7772 ,
Did you see this post? My series 16 machine did not use the upper bearing ring. What is 1st two digits of your serial number.
I believe that bearing ring is a plain bearing ring not a One-Way Roller clutch bearing as is in the Clutch Pulley. I refer to it as One-Way roller clutch but I believe I’m wrong can you confirm?
Any way the ears on that upper ring should go up into the tub slots in the bottom of the wash tub. I would be concerned about the reliability of you Clutch you may want to replace it. The post above has the clutch I recommend and the supplier with the best price. I also describe reassembly of the clutch in the machine. Good luck back and post back if
you have questions…… Rich
Info from the above post;
6.
Reinstalling the Clutch Pulley assembly is the most difficult part of the process. With a tight work area try a test fitment of seating (if used) the Upper Roller Clutch bearing with the notches into the bottom of the wash tub. Then insert the Spinner Shaft Coupler into that bearing rotating CW to reseat the coupler notches to the spinner shaft. Then the clutch pulley to the squared end agitator shaft. Rock back and forth the clutch pulley assembly with upward lifting pressure to reseat the clutch assembly. When the clutch assembly is properly seated you will feel a 1/16-1/8" gap between the Pulley face and shaft end as mentioned and shown on page 47 of the SM. On reinstallation, tighten Clutch Pulley bolt CCW to 96” pounds 8’ foot pounds (Snug no torque wrench required).
Nov 27, 2009 | Maytag Neptune FAV6800AW Top Load Washer
How to remove bearings on 1998 gmc jimmy axle shaft bearings and pinion bearing?
if diying and axle bad replace the whole unit from salvage or rebuild shop.if changing the bearings its a lot of work and you will need some special tools to put back together .first you need to use a lift or again have to remove unit from truck, disconnect battery remove drive shaft,remove pinion nut need large breaker bar loosen bolts to rear cover drain fluid remove cover have someone push axles toward center remove c locks slide out axles best way to remove bearings is slide hammer bearing removal unit remove rear [gears] dont loose shims will see pinion bearing bearing remove and replace now 2 put it back.need shim package, red lead, 4 ring and gear mesh adjustments ,,
Jul 07, 2009 | 1997 GMC Jimmy
Asko 620 moter failure?bearing replacement?
It is not normally possible to replace motor bearings, as they are pressed onto the shaft at the time of manufacture, making it virtually impossible to replace them.
I'm afraid it means a new motor.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Asko W620
How to change a bearing on front loader washing machine?
To change the bearing(s) and/or seal on a Simpson 45S100C 5.5kg Front loading washing machine:
1) Disconnect from the power, water etc. and find your self some space;
2) Remove the lid (two screws at back of machine) and the back panel. I also took off the concrete weight on top to give myself some more room and less weight to move;
3) Remove the fan belt;
4) Unscrew the bolt on the end of the drive shaft. This holds the pulley in place;
5) The pulley is pushed on to a V-bushing. It may be very hard to get off. I found the easiest way was to put a large screwdriver behind the pulley hub and the 'spider' bracket behind. Then use leverage to pop it off. The V-bushing should then slide off the shaft;
6) Remove the three bolts that hold the ends of the spider to the drum. I found these very hard to get moving and they are also awkwardly placed. Use a socket set and you may need a bit of rust-remover/degreaser (WD-40 in Australia);
7) Remove the three bolts holding the central part of the spider to the drum;
8) Tap the end of the drive shaft with a hammer while pulling on the spider. The whole spider and the bearings should slide off the shaft;
9) The spider holds two bearings (one next to the drum and one next to the pulley). I’d recommend replacing both. In my case and apparently in most cases it is the bearing closest to the drum that gets damaged, usually due to water leaking through the drive-shaft seal. The two bearings are different sizes 6205 and 6206. When ordering replacements, I’d recommend rubber sealed ‘RS’ bearings. There is also a shaft seal that sits between the larger bearing and the tub. The seal comes from Simpson ($25). The bearing can be bought from any bearing supply company and are about half the cost of the ‘official’ bearings, and probably better quality. I paid $16 for the 6205 and $20 for the 6206;
10) Knock out the old bearings. The correct way to do this is with bearing pullers etc, but I used a long steel rod (one of the transport locking rods that new machine’s come with) and a hammer (not even rubber). First knock out the large bearing and the drive shaft seal by inserting the rod through from the other bearing side and hit firmly while alternating the position of the force around the case of the bearing. I propped the spider against a brick to ensure the bearing and seal could pop out freely. Now turn around and repeat for the other bearing;
11) Clean up the spider and shaft, ensuring you remove any rust and debris;
12) Tap the new bearings into place. Again I used a hammer and firm tapping around the ring of the bearing;
13) Tap in the new drive shaft seal;
14) Reassemble.
Jul 15, 2008 | Washing Machines
Hoover AL130 Front Load Washer Logo
317 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
