Question about Microsoft Xbox 360 Console
When i put a disc in it says reading disc and then open tray wots wrong i think i no wot it is but just wont 2 sure
    President:
  • 2,777 Answers
Hello there, sorry to hear about this problem. This is unfortunately fairly common with the Xbox 360, it means the laser unit on the actual dvd-rom of the xbox is having problems. Depending on how old your system is, Microsoft will fix this for free, or there may be a small fee. At this point you will want to call Nintendo at 1-800-4-My-Xbox, unless you want to try and replace it yourself. It is very hard to do though. I recommend you call them and explain the problem, they will definitely get you fixed up.
Please be sure to rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful. If you have more questions on this or need further clarification please just respond to this answer and I will get right back with you. So sorry you have to go through this, but Microsoft will definitely help get you fixed.
Thanks
Tim
Posted on Oct 12, 2010
Hts3455 wot play dvd
That's because the Optical Pickup(the laser) has worn out of specification. When you insert the disc, the laser has to be able to read the TOC(table of contents) If it can't, it will think there is no disc in the unit, and fail to play it. You can confirm that the circuity is OK(for the most part) by trying a CD. I'm sure it will play that, as the laser has 2 parts,1 for CD and 1 for DVD.(the 2 discs use different wavelength light)
May 01, 2014 | Philips HTS3544/37 Theater System
2004 jeep wrangler 2.4 motor bucks on hills.
W.O.T. MISFIRE< that is what you have.!
is the CEL lamp glowing running , and for sure WOT?
yes, then scan it, get the codes, P0300? P030x? what is it?
DON'T NOT IGNORE THE CEL,
hell, id scan it and look for pendings,!!! and freeze frame fails.
i would, id not leave that stone unturned, not me....ever.
it is the first after a tuneup full, i look for troubles even marginal.
Ever to a full 60,000 mile tune up? (fuel filter?) not just plugs?
spark wires, see the list. , ,wires and plugs and filters.. skip this service, means long hard and difficult troubleshooting.
2.4L I4,
if fuel pressure is good on hills its not the pressure side. 49psi.
but the car has a fuel pressure regulator, and we test that at the pump test, its part of pump, if not skipped. with gauge, we make dang sure it regulates.
new fuel pump , means zero to me
49 psi pressure now that matters, what if the reg is bad or the
12v power to pump is 6v, bad.
and not doing the leak down test at the pump pressure
test , misses the injectors leaking, or the balance test shows
clogged injector on say #1 . (not equal)
Real tune up done, and no DTC errors store, or pending.
only hills, can be
clogged injectors
MAP reading wrong, (clogged vacuum input to it)
when you WOT the throttle (wideopenthrottle) the MAP pin1 voltage
changes to 1Bar, (atmospheric, or 0 vacuum)
see page 31 in fuel system section of FSM.
the page is weak, no graph, but 0v (near) is very high vacuum and
4.6V at WOT, sea-level reading)
using absolute pressure method not vacuum (which i like)
is 0v is zero pressure (huge vacuum)
is 4.6v at full atmospheric pressure wot, the butterfly TV is wide open.
at keyon, no start the map is at atmospheric, pressure, 14.7PSI
or 1 bar, pressure. (about)
so if you monitor the mAP voltage output and it goes new 0v at WOT
then its done its job. an the misfire is caused by other reasons.
just one voltage test, and bam. not MAP or clog there.
i check map key on, idle and wot. 3 readings. to prove good maps.
in most cases the clean map works every time. see that its nipple
end is clean, (vac, port)
the ecu reads the MAP and the IAT temp, and computes AIR FLOW
and MATCHES that. with 12.5:1 Air top fuel ratio.
(fuel injections works just like this on Speed Density Systems)
and makes full power. if spark is good, and compression is good.
if the injectors are clooged, it misfires, if the spark plugs foul, missire
if the injectors leak, again, misfire.
that is how it all works, cept the magic fuel; tables in the ECU.
the scan tool ECT showing, 180F or more holding hot engine?
no , then thermostat is bad and AFR is rich as heck.
Is IAT reading odd? not equal to ECT first check key on , in morning not started, is bad IAT. they become equal as you sleep. overnight
the air temp matches the water.... a very easy trick this test.
by careful observation, key on, no start.
the 2 sensors report in , even key on,. all the time.
using any scan tool (not old)
Feb 03, 2014 | 2004 Jeep Wrangler
Susuki esteem TPS
old post.
they used 2 engines, one is 1.6L and 1.8L other.
so my guess, is , that
car starts ok. hot or cold engine.
and
car has no power at WOT, (it wont be the TPS)
Is the check engine light on, key on, and does it stay off running?
if not the ECU/PCM (enginebrain) wants to tell you what is wrong
why not ask it.?
ok there are 3 forms of power loss (engine power)
1: WOT, wide open throttle (on most cars that is the MAF sensor)
2: cruising say,at 45mph that too is MAF + oxy sensor.
3: accelerating only, the TPS does cause Enriich mode.
if not , then the TPS is dead.
Jan 23, 2013 | 2000 Suzuki Esteem
My tabletop juke box wont work know power at all
can you please clarify a bit more about whats wrong with it possibly anything else....if you can change a fuse...chances are you can fix it and i can walk you through it.....just need more info thanks,ben
Aug 13, 2009 | Audio Players & Recorders
Compression test results (I think I am doing something wrong)
sounds like you need a new head. valves may be bent.
Jun 05, 2009 | 1994 Chevrolet Cavalier
Wont play/read any xbox games
1 dirty lens
2 dirty disc
3 programme error
1 i think the xbox cleans its own lens but check the manual if not get a good lens cleaner.
2 clean the disc always clean your discs after and before you use them.
3 take off your hard drive and any memory cards and reset xbox to factory settings
May 12, 2009 | Microsoft Xbox 360 Elite Console
My xbox 360 won't play any disc
I had the same problem, make sure that the game disk and dvd movies are not damage. If you have rings on either one, the 360 cannot read them...
Nov 02, 2008 | Microsoft Xbox 360 Console
K850i games won't open
hello! please put software for your mobile! and then you format your mobile!
Sep 09, 2008 | Sony Ericsson K800i Cellular Phone
My dvd player wont turn on
Unplug the unit - look underneath disc tray for an oblong shaped hole with another pinhole or plastic white piece down inside - use screwdriver to move the white piece to other side of oblong - disc should eject. Then try plugging dvd player in and try again.
Jun 15, 2008 | Philips DVD 622 DVD Player
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
