Question about Buck AP Industries Lollipop Crib
Instructions for converting the AP Industries Lollipop Crib to a Toddler Bed
Converting crib to toddler bed. i bought this system used and don't have all instructions
Don't worry, there are instructions online that will talk you through the process of converting your crib into a toddler bed. check out this article from the 'How Stuff Works' website which is really useful.
http://tlc.howstuffworks.com/family/how-to-convert-crib-to-toddler-bed.htm
Jun 23, 2012 | Baby Gear
I need to convert our sorelle tuscany convertible crib to a toddler bed and lost the instructions. how can i get a set of instructions?
http://www.sorellefurniture.com/instructions.php
Not sure what model yours is, but that's their site for instructions.
Mar 14, 2011 | Sorelle Tuscany 1050 Crib
Converting a crib into a toddler bed
what brand and model number of crib/bed is it?
Jun 13, 2009 | Delta Luv Delta - Baby Products 5-in-1...
Need instructions ofr converting crib to a toddler bed.
This site has instructions for the cribs listed below. The 1st two listed seem to be generic cribs with a metal mattress support. It worked for my used crib.
www.milliondollarbaby.com/help.milliondollarbaby.com/
*For cribs with snap-in spring hangers hooks & metal mattress support.w/ spring hanger hdware.
*For cribs w/ bolt-in metal hdware for metal mattress support w/ metal hdware.
For cribs with Safety Glide nylon(rodless) hardware
Sleigh Convertible 3001 Crib
Sleigh Convertible 3091 Crib - Safety Glide
Jenny Lind Crib
Ashley/Alexandria Crib (1 piece headboard) +Day bed info.
Ashley/Alexandria Crib (3-piece headboard) +Day bed info
Lauren Crib ) +Day bed info
Emily Crib (One piece headboard) ) +Day bed info
Emily Crib (Four-piece headboard) ) +Day bed info
Mini Emily Crib
Anastasia Crib
Bridget Crib
Valerie Crib ) +Day bed info
Bailey Crib ) +Day bed info
Ellie Crib Day bed and full bed info
Kalani Crib Day bed and full bed info
Bordeaux Crib Day bed and full bed info
Annabelle Mini Crib
Italian Cribs-Metal Barrel Nut
Italian Cribs-Nylon Nut
Canopy cribs with snap-in spring hanger hardware
Canopy cribs with metal bolt-in hardware
May 16, 2009 | Bassett New Haven 3 N 1 Crib
Need instructions on how to convert my aspen simplicity crib into a toddler bed?
i think this is the same crib that i have. I remove the front rail that slides up and down, then i removed the plastic contraptions that allow it to slid up and down on. I then attached the bed frame on the lowest setting, by first fastening the two back ends first. Then I attached the toddler rails to the bottom of the bed frame and then once they where on I attached the bed frame to the crib with the rails and the brackets for the bed frame pressed together. I hope i explained it so that i makes sense.
Mar 14, 2009 | Simplicity for Children Aspen 3 in 1...
Get the crib into a toddler bed
Evenflo.com. Replacement parts, enter your model number and the manufacture year. The hidden hardware instructions will give you the steps to convert your crib to a toddler bed. Good luck!!
Feb 02, 2009 | Evenflo Jenny Lind Crib
Crib to toddler bed instructions
I need instructions to transform my mama and papas Aspen Cotbed into a bed! We have lost the instructions! Can u help?
Jul 28, 2008 | Baby Gear
Pali Mia crib
I just bought this crib on Craig's list and the ad said it converts to both a day bed and toddler bed, however I didn't have any instructions so found the Pali website and requested an instruction manual for this bed - and they indicated it converts only to a toddler bed, but you have to have purchased the conversion kit, which is also avaiable on their website.
So I would recommend going to the pali website and requesting the manual ! Hope that helps.
Jun 01, 2008 | Pali Mia Crib
Convert crib to toddler bed
I finally found my instructions!! It's actually really easy to convert to a toddler bed:
Step one: Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
Step two: Lower the mattress to the lowest setting.
Step three: Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
Step four: You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
That's it.. You've now got a toddler bed!
Apr 26, 2008 | JCPenney All-in-One Nursery Crib
Buck AP Industries Lollipop Crib Logo
1,165 people viewed this question
Top Buck Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Buck Baby Gear Expert? Answer questions, earn points and help others
