Question about IBM Wheelwriter 6 Typewriter
How do i change the batteries in my typewriter? It has a piece of plastic like thing over the battery holder
  • IBM Master
  • 3,594 Answers
The black plastic retainer is removed by gently prying the ears on the side and lifting. If the batteries are corroded be sure to clean the contacts.
DickyO
Posted on Oct 18, 2010
IBM 1500 Typewriter has started beeping once when I reach 35 on the 10 pitch scale. I have reset my margins and cleared all tabs but it still does it. It just started do it.
Have you replaced the batteries in the machine? Lift the cover and you should see a holder that usually has 3 AA batteries. You can replace them with the machine turned on. Once they are replaced, turn the machine off for a few seconds and then turn it back on. Change the margins and see if that works.
Jan 07, 2016 | IBM Wheelwriter 1500 by Lexmark Electronic...
My xbox 360 controller keeps turning off when i shoot or do anything in halo reach and the batteries are brand new.
It means that the controller battery holder is loose and the batteries are loosing contacts with the terminals, this happen specially when the controller vibrates. Try to put a piece of paper or plastic in the inside covering the body of the battery or a tape to thicken it a little then place the battery in the battery pack holder and it should work fine. Hope it helps.
May 10, 2011 | Microsoft Xbox 360 Controller
It appears that my battery for these headphones doesn't hold it's charge....It's hardly been used Battery type.....BP HP550-11 for headphones Serial No MDR RF 840RK
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries installed in the Sony headset you MUST use the bottom part of the plastic battery holder piece on the BP-HP550-11 battery pack (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism inside the headset to enable the cradle charger to charge the batteries.
NOTE: I am not an electronics expert so I do not know if there would be any problem using other rechargeable AAA batteries (with higher mAh ratings). So I decided to be safe than sorry and ordered the 550 mAh batteries through Ebay.
Dec 03, 2010 | Sony MDR-RF960RK Consumer Headset
I need rechargeaable battery for wireless sony stereo headphones mdr-rf860r
Since many Sony headsets use the BP-HP550-11 battery pack, I assume your battery pack is the same. If not, I assume whatever battery pack your headset came with, it is some type of plastic holder that holds two batteries together. Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make them work in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
Nov 19, 2010 | Sony MDR-RF960RK Consumer Headset
I need a new battery (BP-HP550-1 1/2.4V 550mAh) for my sony headset. Regular batteries will work (non-rechargeables and rechargeables) but I found that the cradle will not recharge the rechargables only...
Nov 01, 2010 | Sony MDR-RF960RK Consumer Headset
I have searched the web for this battery BP-HP550-11/2.4V (two batteries), to replace the ones in our Sony wireless stereo headphone system model MDR-RF970RK.
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make them work (be able to be charged using the cradle) in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism inside the headset to enable the cradle charger to charge the batteries.
Sep 22, 2010 | Sony MDR-RF960RK Consumer Headset
Sony batteries BP-HP550
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
Jul 27, 2010 | Sony MDR-RF960RK Consumer Headset
Where can i buy a sony battery bp-hp550 1 1/2 4v
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries installed in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
Jul 11, 2010 | Sony MDR-RF960RK Consumer Headset
IBM Wheelwriter 10 Series II Typewriter 6783. Spacebar suddenly does nothing. Everything else functions fine. Removed spacebar key and vacuumed dust underneath. When investigating possible problem we found...
you will need to replace the keyboard. we see this alot,keyboard starts to fall apart due to age. batteries are only used to hold tab and margin positions in memory. machine works fine without batteries.
Dec 15, 2009 | Televison & Video
IBM Wheelwriter 6 memory loss
If you have changed the batteries the battery holder is probably corroded, take a piece of fune sand paper and clean the contacts, put the batteries in and spin them around to help them seat.
DickyO
Dec 08, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6 Typewriter Logo
52 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
