Question about Honeywell Programmable Thermostat Heater
We would like our CM67NG to come on at the time to which we set it, but it always comes at some point (sometimes 3 hours) before the set time. How can I make it do as requested?
  • keith_charlt Oct 12, 2010
    I have looked at these more obvious things, and am convinced that it is something to do with the "Optimum Start" system. Presumably it looks at the differential between the room temperature and the required temperature to decide how long it will need to attain the required temperature; but this will depend on the max water temperature which has been set on the boiler control. Seems a somewhat hit and miss arrangement
  • 6,826 Answers
I think that after reading about this product, that it adjusts itself to try to get heat to the comfortable level, before the user expects it to be that temperature. In your case, you do not like it when the thermostat behaves in this way.
I would try another model of thermostat from Honeywell, as Honeywell has a wide variety of thermostats that will work with your furnace or boiler application.
Good luck on getting a better digital thermostat, or else, get a more manual one.
Forum HONEYWELL CM67NG
Date: 2009-12-30 at 13:37
Reply to author
Report this message
New post HONEYWELL CM67NG
CORRECT OPERATION OF CONTROLLER IN AUTO MODE
I HAVE A HONEYWELL CM67NG CONTROLLER WHICH I AM HAVING TO USE IN MANUAL MODE ALL THE TIME BECAUSE WHEN I PUT IT INTO AUTO MODE IT SEEMS TO STILL TURN THE BOILER ON WHEN IT IS OUTSIDE THE PRESET TIMES. I BELIEVE IT HAS BEEN LIKE THIS SINCE INSTALLATION SO I AM TRYING TO TRACK DOWN INFO OR WIRING DIAGRAMS ON HOW IT SHOULD BE CONNECTED IN ORDER TO ELIMATE THAT AS THE PROBLEM REGARDSADAM
Someone else had a problem similar to yours, apparently.
Manual abstract:... When the LED is OFF the boiler is OFF.Display shows flashing `battery' symbolImproper battery compartment insertion Batteries need replacingDisplay shows `flame' symbol but heating does not switch onThe heating is not required at this momentWhat is an RF Programmable Thermostat?A Honeywell Radio Frequency (RF) programmable thermostat is a thermostat that controls your heating system so that you can have comfortable temperatures when you are at home and energy savings when you are out. With RF communication there is no need to provide a wired connection between thermostat and boiler. The CM67NG can therefore be installed without disrupting your room decor. These instructions explain how to program and operate your CM67NG to get the most comfort at the least cost.When do I need to use the push button?You should use the push button to control your boiler only when the RF communication is lost (see the CM67NG Trouble-Shooting Guide).What other accessories can I buy for the CM67NG?Automatic Time Setting (ATS) "Add-On" Module * (Part No. Q6667B1015)Display works but heating does not switch on (HC60NG LEDs are off or green one is on)Boiler switched off Wrong electrical connectionHC60NG red LED is constantly on or flashingRF communication lost due to the wrong location of the room unit RF communication faultWhat will the CM67NG Programmable Thermostat do for me?· · · · · · · ·Wireless connection to the boiler allows you to mount the CM67NG in your room without disrupting the decor Armchair programming lets you set up your resting comfortably in your armchair CM67NG whileThe ATS module picks up a daily time signal from a transmitter in the UK and corrects the time on the CM67NG display. So:Call installerOptimum Start means that the CM67NG will switch on your heating system so that your desired comfort temperature is reached by the start of the program period and thus avoid unnecessary boiler firing Attractive slim styling compatible with any room decor 7 day program lets you set the lifestyle CM67NG to match your weekly· · ·You never need to set or adjust the time There is no need to adjust the unit by -/+ 1 hour in summer / winter since the unit does this automatically Your CM67NG is the most accurate clock in your home so you can use this information to set-up all your other clocks.Remove the battery compartment and re-insert it. If the `spanner' symbol does not clear itself in a few minutes call the installer* Not available in all Geographic Regions depending on transmitter range and home location Table stand for the room unit (Part No. F42010248-002) If you do not want to mount the room unit on the wall you can use optional table stand, ask you installer for details6 daily independent temperature levels let you set any 6 temperatures from 5 to 30°C at any time each day, to match your daily lifestyle Party button lets you temporarily maintain (or adjust) the current temperature for 1 - 23 hours. Useful when you have friends round or go out of the house for a short while Day Off button copies Sunday's program into tomorrow so that you can make the CM67NG follow the Sunday program if you have a ...
Posted on Oct 13, 2010
    President:
  • 1,514 Answers
It may be that the time is set wrong on the thermostat. While it is a radio controlled thermostat it may not be able to pick up the signal. The clock can be set manually. There's a manual available in Adobe Reader format at http://www.bvt.org.uk/shropshire/pdf/usermanuals/HoneywellCM67.pdf
which explains the complete setup for your thermostat. If the clock is not the problem I would suggest wiping the settings clean by removing the batteries. Leave it for a while to lose the inbuilt memory and then reprogramme it from the beginning. I hope this helps
Posted on Oct 12, 2010
Cant`t get the chimes to ring at the correct time. Not sure why this happened. i have always been able to stop the clock determine am & pm then restart
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Oct 16, 2016 | Home
Can not set up my hydrofarm timer to come on for 1 min and off for 5 min.
You posted next to a photo showing hydrofarm analog timer with segments located on dial face.
Open following link for general look at setting analog timers.
http://waterheatertimer.org/How-to-set-timers.html
Analog timers have a minimum set time of 15 minutes because the trippers-or-pins-or-segments are made certain width.
If you want 1 minute ON and 5 minutes OFF, you need digital timer.
Most digital timers have minimum set time of 1 minute.
But digital timers have limited number of set points per day unless you get into heavy-duty Intermatic timer like the ET70115 timer with 100 or so set points.
If you want 1 minute on and then 5 minutes off, and want to repeat that same cycle over and over throughout the day and night, you would need 240 set points.
Or check out 120V adjustable cycle timers.
https://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hbZ1z0q55s
If you want the cycle timer to operate certain hours only, then put ordinary 24-hour timer between the cycle timer and the load.
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 05, 2011 | Hydrofarm Timer 24 Hour
Hi, I have just changed the bateries of a Honewell CM67ng wireless thermostat. The display now flashes a "Id -" text on the left-hand side (where the temperature is normally indicated/set). I...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Honeywell Programmable Thermostat Heater
Hi any ideas on why this happens, I have a a honeywell CM67NG wireless thermostat and it fires up the bolier(Alpha CD50) even when I have set the programmer for times and days. example I have set it to...
One possibilty is the therm has a antisipator setting, meaning Ex; at 7:00 you want 72*f,but the house is 62*f at 6:15 the therm will bring on the heat early so the house will be at 72*f@7:00.There should be a short lag if it is comming on at 4:00 it is something else.
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
CM67ng will not turn heating off
Are you running some type of program on the tstat??
Jul 06, 2017 | Honeywell Programmable Thermostat Heater
Raypack pool/spa heater works intermittently
You can try pulling your pilot assembly out and clean it. Sometimes it will get sooted up and cause the sensor to short so the heater get's a falce reading and shuts the heater down. Then sometimes the heater will start and sometimes it won't. If this dosen't help check the ignition wire for any cracks or anyplace it may be shorting. Good luck.
Feb 17, 2010 | Raypak Versa 130,000 Btu Above Ground...
RCA DVD Recorder (drc8000n) loses time
Is it always a minus 4:11:50 reset? Do you use Guide Plus+ or something like it for recording off-air? I would think the clock would be set automatically from an external source if you wanted to synchronize with scheduled programs.
I would bet if yoy set the clock and disconnected the cable it would NOT change again in 3 hours as it has been doing. Experiment with that sometime. I'll bet the problem is up the foodchain somwhere.
Apr 05, 2009 | RCA DRC8000N DVD Recorder
Honeywell CM67ng thermostat not working. Have tried various programmes but still seems to have mind of its own. Can we replace with something else?
The cm67ng has a feature which attempts to get the temperature to the desired point before the actual time you set. In reality this "feature" just makes the device turn on and off randomly in a really bemusing fashion. You can turn this off with the following:
1, Set timer mode to "OFF"
2, Hold down "Info i" and press "prog 3" and "prog 4" together. Display Should show a spanner in the left hand corner.
3, press "prog 2"
4, repeated press "clock +" till the characters in the display after the colon read "OP" (the number before the colon seems to vary with model).
5, Press the "temp down" button. The 1 in the right hand of the display should become a 0.
6, Press the "info i" button to save your changes.
7, Switch the mode back to auto, the timer should now behave normally.
You should note that a number of other parameters can be changed in this service mode. Some of which could probably do bad things to your central heating system if set incorrectly.. So this is at your own risk! Either way it's best to read the installation manual before attempting to change anything:
http://content.honeywell.com/UK/homes/Technical/CM/cm67i.pdf
Nov 09, 2008 | Heating & Cooling
Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Jun 26, 2008 | Ovens
Heating & Cooling Logo
331 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
