Question about Mitsubishi Televison & Video
What do I do when TRACK is flashing on recorder
  • Mitsubishi Master
  • 5,151 Answers
Nothing it should right itself and the picture should come on shortly afterwards. It just means it's auto tracking. IE getting the best picture. If you don't get a picture try cleaning the video head.
Posted on Oct 12, 2010
Tascam DP02CF not responding to anything what should i do nest please?
That's an 8-track recorder that records to a compact flash card. It is not a minidisc recorder.
Oct 01, 2012 | Tascam Dp-02cf Digital 8-track Recorder
How do you record on tracks 3-8? i can record only on tracks 1 and 2, this is marketed as an 8-track recorder but is it really?? if i cant record on track 3 or track 4 then i just waisted alot of money i...
Yes you can record on the other 6 tracks, but you need to assign them.
If you are having problems assigning them, don't forget that you need to clear the previous assignments (for track 1 and 2 for example) FIRST, before you try and assign to say tracks 3 & 4.
To clear assignments hold down the assign key and the previously assigned tracks should flash. While still holding the assing key, press each one of the flashing channels seperately to un-assign them. Now release the assign key.
Jan 08, 2011 | Tascam Dp-02cf Digital 8-track Recorder
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Recording multiple tracks at the same time.
Yes you certainly can record the 8 inputs onto 8 tracks simultaneously. You will need to make sure you are assigning each input to each track individually by first pressing the input button for an input and then pressing the select button for a track. Do this for each input/track and then make sure all of the 8 tracks you want to record to are armed for recording (the red rec buttons above each should be lit) before pressing record and play together.
You might want to insure that no tracks are linked (you can see this by pressing an input and observing which tracks have their 'select' button flashing). If 2 adjacent ones are flashing for the same input simply unassign one of them by pressing the 'select' button above that track. Then you'll be free to assign the next input to that track as above.
Best of luck.
bd.
May 19, 2009 | Tascam 2488 Portastudio Multitrack...
DP-01 Wont Record
You may need to assign one of the inputs (a or b) to the track you want to record to. Do this by first pressing the 'Assign A' or 'Assign B' (if you are lining in a guitar to the Hi-Z input then you'll be using 'Assign A') and then press the record/select button for the track to assign. After doing this you'll arm your track for recording and proceed to record.
Hope this helps.
bd.
May 17, 2009 | Tascam DP01 All-In-One Recording Package...
Recording
You take the .wav from each track from mr-8 and insert to desired track in your software. Use a CF Card reader to make this easier.
May 10, 2009 | Fostex MR8-MKII - 8 -Rack Portable Compact...
Unable to record or playback on new DP 02
It sounds like either the inputs are not assigned or the tracks are not armed for recording (or both).
Here is a quick explanation of the procedure involved in recording with the DP-02 that I posted for another person who was asking for some basic instruction on how to record. You might be missing a step somewhere along the line as for instance you will still see the meters move even if you don't have the inputs assigned or don't have any tracks armed, but the DP-02 won't record anything until you do both.
To record you need to first assign your input to a track, then arm the track for recording, and then press play + record at the same time.
1. So you would patch your mixer output, mic or instrument into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
2. Then to assign that input to a track simply press and hold the 'input A' button and then press the 'rec' button of the track you with to record on. The 'rec' button will flash rapidly to indicate that the input is assigned to the track.
(To assign the input to a different track you have to clear the input assignment from the first track and assign the input to a new track. To clear an assignment press the input assign key, A in this case, and the track it's assigned to will flash its 'rec' button. Hold down the input assign key and then press the flashing 'rec' button. The button will stop flashing and the input can then be assigned to another track by following step 2 again).
3. Next, to arm the track for recording simply press the 'rec' button for that track. The 'rec' button with flash slowly.
4. To begin recording press play + record together in the transport section and the 'rec' light for the armed track will stop flashing and light steadily. Press 'stop' to end recording.
This should get you started. The operation of the DP02 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Hope this helped.
Cheers,
bd.
Nov 25, 2008 | Tascam 2488 Portastudio Multitrack...
Don't know how to actually record
1. So you would patch you mixer's output into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
This should get you started. The operation of the DP01 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Cheers,
bd.
Nov 20, 2008 | Tascam DP01 All-In-One Recording Package...
Just bought a DP-02 w/40gb hard drive
You'll first need to find some aux audio out jacks on your karaoke machine. You might need an adapter, but the basic idea will be to connect the aux out from the karaoke machine to an input on your Tascam DP-02.
Then on the DP-02 you need to assign whatever input your plugged into to one of the 8 tracks. Let's say you're using the left input (input A) and want to put the karaoke music on track 1. You'll press the 'Assign A' button on the DP-02 and while holding it then press the 'Rec' button of track 1. The 'Rec' button will flash rapidly to show its been assigned. (for reference: assigning an input is better described on page 23 of the manual). Then you'll want to arm track 1 to record. Press the 'rec' button for track 1 and it will start to flash slowly to show it has been armed for recording. Now you are ready to start recording. On the DP-02 press the large round play and record buttons on the lower right together to start recording and start your karioke machine playing. When the song is done press stop on the DP-02.
Now to record your vocals you'll need your mic to be plugged in (lets' say it's in input B). You'll need to assign this input to a free track (track 2). Press the 'Assign B' button and while holding it press the 'Rec' button for track 2 (rec button will flash rapidly). Then you'll want to un-arm track 1 and arm track 2 for recording. To do this press the 'rec' button for track 1 so that the light goes off and then press the 'rec' button for track 2 so that it flashes slowly.
So now when you press play and record together to record, you'll hear track 1 playing (the karaoke track you recorded earlier) and you'll be recording vox on track 2. Of course you'll also be recording whatever you hear in the room onto track 2 along with your singing, so in order to get a clean recording there (prevent bleed) you'll want to plug some headphones into the DP-02 and listen to those as you record.
That's pretty much all there is to it. Some variations if you wish to record the karioke in stereo vs mono (I gave you the instructions for mono here), and you may need to turn on phantom power if you have a non-powered mic, but the idea is basically the same.
Hope this helps.
Good luck.
bd.
Oct 24, 2008 | Tascam DP01 All-In-One Recording Package...
How to erase recordings on the Panasonic RR-US500
I called the Future Shop where I bought the recorder and the salesman looked at the manual online and saw that the Delete instructions do not tell you what you need to know.
To Erase or Delete recordings from this recorder, you have to select the track or file you want to erase, hit the Erase button, see that track number flashing THEN hold the Erase button down for a full second.
You can toggle until ALL comes up and then erase all your files at once if you wish.
You can also hit the Erase button first and then select the track you want recorded. The important thing to know is that you then have to see the number flashing THEN hold the Erase button down for a full second.
Mar 29, 2008 | Panasonic RR-US500
Televison & Video Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
