Question about kawasaki Full Suspension Mountain Bike Men
Im looking for torque specs for a kawasaki fh580v
  • 160 Answers
SOURCE: What are the Torque Specs for a Kawasaki Bayou 350 ATV?
which specs do you need engine ?
Posted on Nov 12, 2008
  • 2692 Answers
SOURCE: Torque Specs
Torque: 210 @ 4000 rpm
Posted on Dec 22, 2008
SOURCE: torque specs for the cylinder head
2004 ENGINE
Engine Mechanical - 1.6L (L91) - Aveo
SPECIFICATIONS
FASTENER TIGHTENING SPECIFICATIONS
Fastener Tightening Specifications
Application
Specification
Metric English
A/C Compressor Mounting Bolts 27 N.m 20 lb ft
A/C Compressor Mounting Bracket Bolts 50 N.m 37 lb ft
Air Filter Housing Bolts 12 N.m 106 lb in
Alternator Adjusting Bolt 20 N.m 15 lb ft
Alternator Adjusting Bracket Retaining Bolt 20 N.m 15 lb ft
Auxiliary Catalytic Converter-to-Exhaust Manifold
Nuts and Bracket Bolts
40 N.m 30 lb ft
Camshaft Cap Bolts 16 N.m 12 lb ft
Camshaft Gear Bolt 67.5 N.m 49 lb ft
Camshaft Pressure Plate Bolts 10 N.m 89 lb in
Connecting Rod Bearing Cap Bolts 25 N.m+30°+15° 18 lb ft+30°+15°
Coolant Pump Retaining Bolts 10 N.m 89 lb in
Coolant Temperature Sensor 20 N.m 15 lb ft
Crankshaft Bearing Cap Bolts 50 N.m+45°+15° 37 lb ft+45°+15°
Crankshaft Position Sensor Retaining Bolt 10 N.m 89 lb in
Crankshaft Pulley Bolt 95 N.m+30°+15° 70 lb ft+30°+15°
Cylinder Head Bolts - Camshaft Support Housing
and Cylinder Head Mounting Bolts
25 N.m+60°+60°
+60°+15°
18 lb ft+60°+60°
+60°+10°
Electronic Ignition System Ignition Coil Mounting
Bolts
10 N.m 89 lb in
Engine Mount Bracket Retaining Bolt 65 N.m 48 lb ft
Engine Mount Bracket-to-Engine Mount Retaining
Bolts
60 N.m 44 lb ft
Engine Mount Retaining Nuts 40 N.m 30 lb ft
Exhaust Flexible Pipe Bracket Bolts 40 N.m 30 lb ft
Exhaust Gas Recirculation Valve Adapter Bolts 25 N.m 18 lb ft
Exhaust Manifold Heat Shield Bolts 15 N.m 11 lb ft
Exhaust Manifold Nuts 25 N.m 18 lb ft
Flexible Plate Bolts 60 N.m 44 lb ft
Flexible Plate Inspection Cover Bolts 10 N.m 89 lb in
Flywheel Bolts 35 N.m+30°+15° 26 lb ft+30°+15°
Flywheel Inspection Cover Bolts 12 N.m 106 lb in
Front Muffler-to-Main Catalytic Converter Nuts 30 N.m 22 lb ft
Fuel Rail Retaining Bolts 25 N.m 18 lb ft
MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 1 of 330
http://www.eautorepair.net/app/PrintItems.asp?S0=2097152&S1=0&SG=%7BEEDCF... 3/30/2009
ENGINE MECHANICAL SPECIFICATIONS
Engine Mechanical Specifications
Intake Manifold Retaining Nuts 25 N.m 18 lb ft
Intake Manifold Support Bracket Lower Bolt-to-
Engine Block 40 N.m 30 lb ft
Intake Manifold Support Bracket Upper Bolts 25 N.m 18 lb ft
Lower Timing Belt Cover Bolts 10 N.m 89 lb in
Oil Pan Retaining Bolts 10 N.m 89 lb in
Oil Pressure Switch 40 N.m 30 lb ft
Oil Pump Retaining Bolts 10 N.m 89 lb in
Oil Pump/Pickup Tube and Support Bracket Bolts 10 N.m 89 lb in
Oil Pump Safety Relief Valve Bolt 36 N.m 22 lb ft
Oil Pump Rear Cover Bolts 6 N.m 53 lb in
Power Steering Pump Mounting Bolts 25 N.m 18 lb ft
Power Steering Pump Pulley Bolts 25 N.m 18 lb ft
Rear Timing Belt Cover Bolts 10 N.m 89 lb in
Spark Plug Cover Bolts 3 N.m 27 lb in
Spark Plugs 25 N.m 18 lb ft
Thermostat Housing Mounting Bolts 20 N.m 15 lb ft
Throttle Cable Bracket Bolts 8 N.m 71 lb in
Timing Belt Automatic Tensioner Bolt 25 N.m 18 lb ft
Timing Belt Idler Pulley Bolt 40 N.m 30 lb in
Transaxle Bell Housing Bolts 75 N.m 55 lb ft
Transaxle Brace Bolts 40 N.m 30 lb ft
Transaxle Torque Converter Bolts 65 N.m 48 lb ft
Upper Timing Belt Cover Bolts 10 N.m 89 lb in
Valve Cover Bolts 10 N.m 89 lb in
Application
Specification
Metric English
General Data
 Engine Type 4 Cylinder - In-Line
 Displacement 1598 cm3 97.51 in3
 Bore Stroke 79.0x81.5 mm 3.1x3.21 in
 Compression Ratio 9.5:1
 Firing Order 1-3-4-2
 Maximum Power - At 6200 RPM 77 kw/103.3 hp
 Maximum Torque - At 3400 RPM 145 N.m 106.9 lb ft
Cylinder Bore
 Diameter 79 mm 3.1 in
 Out of Round - Maximum 0.0065 mm 0.00025 in
 Taper - Maximum 0.0065 mm 0.00025 in
Piston
MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 2 of 330
Posted on May 09, 2009
robotleg
  • 9 Answers
what size bolt heads on these bolts (the bolts size chart for correct torque specs is 2mm smaller than the head of the bolt on Kaw).while the forks are still off and the end caps also still off,hold them level (up/down) and by hand (which will be easy because the caps are off to let the springs come out past the tube-but leave them in as they change the amt. of fluid goin in)push down slow to compress and bottom them out then fill till you get 100mm from inside the top of the forks tube is on the mark.then pull them back to fully extended ,put the caps CAREFULLY back on so they dont stripp the soft threads up.P.S.if this was used at a track there are 2 inexpensive brass or copper bushings inside the big tubes top and a bit lower that will get worn and let the inner fork tube **** back and fourth as it compresses in and out that causes the seals to leak again very soon because it flexes the round inner part of the fork seal to become out of round (not tight all around the tube for correct sealing) from slack and to much movement from the above mentioned cheap bushings wear.I cut em out with a dremmel and freeze the new ones for easy insertion with fingers to not nick em from tappin in with a hammer,etc.good luck,wallace
Posted on Jul 26, 2009
  • 3567 Answers
SOURCE: Im looking for the torque specs to put my engine
You can find the torque specs in a service manual. Go to this site and you can download a free PDF service manual.
www.carlsalter.com/motorcycle-manuals.asp Most all of the manuals are in English but some are not. There is no way to be sure without doing the download. You can always delete it if in a foreign language.
Shown below are a couple of manuals on the site. Yes, I know the years are not 1993 like your bike, but the torque values don't change from year to year. Even the service proceedures don't change often.
Posted on Oct 18, 2009
95 kawasaki 750 zephyr head bolt torque settings
Hi, David for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
97 kawasaki 750 sts torque specs for cyclinder and head
cylinder head torque spec 97 750 ssxi
Kawasaki ZR550 and 750 Zephyr 1990 1997 service repair Download Manuals... $10
OEM Parts for Kawasaki
KAWASAKI ZR 7S Manual
Aug 26, 2017 | 1992 kawasaki Zephyr 750
WHAT IS THE TORQUE SPEC ON KAWASAKI ENGINE FR600V MOWER ENGINE
I think it's 170, but don't quote me. Snug it tight, and then add a 1/4 of a turn. Determine that torque value, and then just duplicate it in a cross-cross pattern across the head. Should be fine.
Aug 25, 2016 | kawasaki Garden
1999 Kawasaki KX 125 clutch hub nut torque spec
Hi, Kevin for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
kx 125 clutch hub torque
99 kx250 clutch basket torque specs
Kawasaki KX125 Service Manual
Kawasaki kx125 1997 Owner Manual
Oct 15, 2014 | 2003 kawasaki KX 125
Kawasaki torque specs
The torque specs are 18 ft lbs. for the cyl. & head nuts
Jul 13, 2014 | 2007 kawasaki Vulcan 1600 Mean Streak
Remove clutch from kawasaki fh580v
to remove clultch pulley remove crank bolt unplug pulley first then ie should pull off some times you mights need to need to use a pulley remover
Oct 26, 2013 | Kawasaki Engines NEW 19HP KAWASAKI ENGINE...
Can I replace the kawasaki 19hp FH580V AS14 with a 20hp FR600V AS05R on a Phazer lawn mower
Hello friend... I know people that have had replaced their Kawasaki FH580V-AS14 with the FR600V-AS05R... so, the answer is YES, SURE YOU CAN !!
Mar 11, 2013 | Garden
2005 Kawasaki ZZR 600 torque specs for the clutch friction plate springs?
Hi, J_g_wolfgang for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
torque specs for clutch springs for the 03 04 zx6r Kawasaki Forums
Need some torque specs
Kawasaki VN 750 Service Manual
2006 Kawasaki ZZR600 Owner Manual
Sep 27, 2017 | 2005 kawasaki ZZR 600
What are the torque specs for head cover bolts on a 2008 ninja zx6r?
If you mean head bolts you need to ask a dealer, if you mean valve cover bolts you can look up torque spec's by bolt size just google it look for a flow chart of spec's.
May 06, 2012 | 2006 kawasaki Vulcan 800 Drifter
kawasaki Full Suspension Mountain Bike Men Logo
625 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
