Question about Welding Tools
I just bought a Simadre520dx 3 in 1 plasma cutter. I went to use it and couldnt get it to arc in the cutting stage or the tig stage and theres no air coming out in cut and no gas in tig . The arc welder seems to work alright . Any help would sure be appreciated . I called the place where I bought it from and he told me to take pictures of the boards in it and e-mail them to him so I did, [I have no idea why] but havnt heard back from him yet.
  • 905 Answers
They probably suspect board damage in the gas control / air control. They will analyze the pictures, looking or signs of failure. If found, they will either send you a new unit, or replacement boards to be installed. This is very common troubleshooting / diagnostic when the manufacturer gives its support staff the training and latitude to go this deep.
Give it more time, you are easily within the warranty period. Keep track of all communications though. Given that you just bought the machine, I am surprised that they were not more apt to replace it altogether unless another is not available.
Posted on Oct 12, 2010
  • Larry
    Larry Oct 21, 2010
    He's asking for photos to see if he can see any wires disconnected.
    It could be wires disconnected or a fault with the torch control switch or wires. Easy test to see if it's a machine or a torch issue would be to cross the correct two pins at the control cable connection at the front of the machine. If after crossing them still no air then it's inside the machine, if air then it's at the torch control switch or wires/connections. Ask him which two pins to cross.
Spectrum 2050 plasma cutter . Cutter blows air and stops when trigger is pulled no pilot arc or any cutting when trig is released air flows again and stop after 10 sec new tips was working the day...
Check compressed air pressure is in limits otherwise unit will cut out. Try adjusting the pressure up. also make sure the supply pressure is correct as it may not be your plasma cutter at fault.
Jul 30, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
No Arc on a Cut 40 Plasma cutter
Check your consumbales to be sure they are tight in the torch head. Check your ground be sure it's good and connected to the pc you are cutting. Make sure you are running air at 65 to 70 psi as it exits the torch. Email me if you have any other questions.
Jul 14, 2009 | A & A Manufacturing Ramsond 40D Plasma...
No power to the cutting torch when the trigger is pressed
check to make sure all torch parts are in good shape and is put in correctly
Mar 11, 2009 | Welding Tools
Plasma cutters Question
There are a few things about plasma cutting safety that are different from general welding safety tips This short list of plasma cutter safety tips is geared toward light duty plasma cutting using compressed air not large industrial units that use gas mixtures and water cutting tables. Electric Shock Can Kill - Operating a plasma cutter completes an electric circuit between the torch and the workpiece. The workpiece and anything touching the workpiece are part of the electrical circuit. - Never touch the torch body, workpiece or the water in a water table when the plasma system is operating. Voltages & Currents - Plasma cutter output voltages are much greater than welding voltages, usually 100-200 volts. Precautionary Measures - Do not pick up the workpiece, including the waste cutoff, while you cut. Leave the workpiece in place on the workbench with the work cable attached during the cutting process. - During plasma cutting operations do not move the work clamp. Wear insulated gloves and boots, and keep your body and clothing dry. - Do not stand, sit or lie on or otherwise touch any wet surface when using the plasma cutter system. - Insulate yourself from work and ground using dry insulating mats or covers big enough to prevent any physical contact with the work or ground. If you must work in or near a damp area, use extreme caution. Work Cable - Ensure metal-to-metal contact between work cable and workpiece or work table. - Work cable clamp should make contact with clean metal free of rust, dirt, painted surfaces, etc. - Do not attach work cable to the piece that will fall away when the cut is complete Plasma cutter Arc Rays Plasma cutter arc rays produce intense visible and invisible (ultraviolet and infrared) rays that can burn eyes and skin. Protective Clothing - Guantlet gloves, safety shoes and hat. - Flame-retardant clothing to cover all exposed areas. - Cuffless trousers to prevent entry of sparks and slag. - Remove combustibles, such as a butane lighter or matches, from your pockets before cutting. Noise Levels of Plasma Arc Cutting - Plasma arc cutting systems can generate noise levels in excess of 120 dB during high-amperage cutting operations. - Ear protection should be used when operating or working near plasma arc cutting operations. Toxic Fumes & Gases Plasma arc cutting can produce toxic fumes and gases that deplete oxygen and cause serious injury. - Keep the cutting area well ventilated or use an approved air-supplied respirator. - Do not cut in locations near degreasing, cleaning or spraying operations. The vapors from certain chlorinated solvents decompose to form phosgene gas when exposed to ultraviolet radiation. Pacemakers & Hearing Aids - Pacemaker and hearing aid operation can be affected by magnetic fields from high currents. Pacemaker and hearing aid wearers should consult a doctor before going near any plasma arc cutting and gouging operations Overall Plasma Safety - The plasma arc cutting process can be very safe. - By paying attention to safety standards and correctly setting up and operating the system, plasma arc cutting poses no more a threat than most welding processes.
Aug 27, 2008 | Miller Spectrum 375 Cutmate Plasma Cutter...
Plasma cutters problem
Depending upon the design of the torch (e.g., orifice diameter), electrode design, gas type and velocities, and the current levels, several variations of the plasma process are achievable, including: * Plasma Arc Welding (PAW) * Plasma Arc Cutting (PAC) * Plasma Arc Gouging * Plasma Arc Surfacing * Plasma Arc Spraying
Aug 27, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
Plasma Cutters support
In this process, an inert gas (in some units, compressed air) is blown at high speed out of a nozzle; at the same time an electrical arc is formed through that gas from the nozzle to the surface being cut, turning some of that gas to plasma. The plasma is sufficiently hot to melt the metal being cut and moves sufficiently fast to blow molten metal away from the
Aug 27, 2008 | MILLER 192049 SWIRL RING PLASMA CUTTER
Plasma cutters support
Plasma Arc cutting is an excellent choice for most cutting applications but it is particularly well suited for applications where speed and excellent cut quality are important. Because of the intense heat of the plasma arc – around 40,000° F compared to 5,700° F, with gases used with Oxy-Fuel torches – the cut is clean with little or no dross.
Aug 27, 2008 | Miller Spectrum 1000 Plasma Cutter...
Welding Tools Logo
76 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
