Question about Zanussi FLA1101W Front Load Washer
How do you change the belt on a zanussi nexus fl 1082.iv got the top off and tryed to slip my hands down the back of machine to attach the belt to the motor and wheel,but just cant get the last bit on,and i cant see what im doing.i even try to boil the belt to strech it a little more..
  • Zanussi Master
  • 3,463 Answers
With the help of someone, tilt the washer forwards towards you, this will give you more room to get your hands inside to fit the belt, it is awkard, but can be done, I have done it this thay on many occasions, otherwise, it entails removing the rear half of the cabinet, not an easy job!!!!!¬.
Good luck.
Posted on Oct 12, 2010
Have zanussi FL1082 stuck on rinse cycle water in and emptying so never fills enougth for sensor to move cycle on. is it worth changing the exit valve
Posted on Mar 18, 2011
Zanussi fs 1555 w machine stopped during cycle now drum will not turn
If you cannot turn the machine by hand then it may be an idea to see if the drive belt has snagged around the back end some how take a peep with a torch thru. top.if the belt looks ok it may be that something has got stuck inside the drum.Sometimes socks get stuck between the front of the drum casing and the drum shine a torch around the front by the door seal and see if you can see any objects jutting out if you can be careful and try with a vice grips to pull out if no joy it sounds as if it will have to be a tub out job.Sometimes objects like coins can be fished out thru the back where the heater sits but still a lot of work to get down there.Body of machine has to be split for access.
Good luck
May 04, 2010 | Zanussi F1245W Front Load Washer
How di change the belt on a 2000 maytag top load washer?
HI. you may have a defective idler pulley. excessive bearing clearance can cause the belt to slip off at times. A worn belt will slip off as well. i suggest gaining access to the belt to inspect for damage. you can start by pressing in the middle of the longest straight run. It should deflect no more that one inch. also inspect the belt for cracks, frayed edges or other signs of excessive wear. if any damage or excessive looseness is found, replace asap. It could also be stretched.
((You can check the pulley by removing the belt and physically rotating the pulley, if the pulley has excessive wobbling or shifting, replace it))
Sep 03, 2009 | Zanussi ZWF1430W Front Load Washer
Softener still in dispenser after wash cycle
Sounds like you have a clogged tube.Try cleaning out the dispenser,pour hot water into it then run threw a cycle empty setting on hot this may clear it out.
Hope this helped.Please rate me
For more help go to live chat.
lenwest
Jan 30, 2009 | Zanussi FJS1225W Front Load Washer
FAN BELT
It can be done from the top, but it is awkward.
Remove top cover, and tilt washer towards you , you may need someone to hold it steady for you.
Reach down inside washer and slip belt over motor pulley, then start to feed belt over drum pulley guiding it round the pulley, at the same time turn drum with pulley gradually feeding the belt around..
The only other way is to remove the rear half of the cabinet, this is quite an involved job.
Good luck.
Plz rate my soution.
Thanks.
Jan 24, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi nexus FL 1081
Sounds like your water pipes are on the wrong way round so its rinsing in hot water.
Nov 07, 2008 | Zanussi FJS1225W Front Load Washer
Squeal that sounds like belt spippage
The motor slides back and forth so there is know way to tighten the belt.The new  belt is needed if your old one shows any ware or if has shiny look to it which would mean its been getting hot and slipping.
May 16, 2008 | Maytag Legacy Series Top Load Washer
WONT SPIN
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
May 10, 2008 | Zanussi FLE1416W Front Load Washer
Zanussi IZ 12
I've just spent an hour taking mine to bits. On the back there are 2 x 9mm silver nuts at the bottom, below the star head screws you removed to get the top off. Then there are two more sneaky ones at the bottom of each side panel, just next to the gap about half way along on both sides., with a plastic cover hiding them from view. Make sure you release the mains cable holder from the top of the back by pressing the plastic clips down, then the whole shebang should slide off easily.
Regards. Paul C
Dec 31, 2007 | Zanussi IZ12 Front Load Washer
Zanussi FLA1101W Front Load Washer Logo
296 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
