Question about Cycling
I have an old (15 years?) Giant bike with the Shimano 70GS derailleur. It has been so long since I rode the Giant that I cannot remember how to actually adjust or even work the shift properly. The biggest problem is in the adjustment; I can figure out the shifting part -- if I can remember my right from my left.
  • Jim Allen Oct 12, 2010
    Many thanks. It's been at least four years since I rode it and now I have the need again. Good advice.
    Yes, it was very helpful. The mind is a terrible thing to lose.
    President:
  • 1,514 Answers
If the derailleur was working alright when it was last used it probably only needs to be oiled rather than adjusted. The rear derailleur moves in, towards the bike, and out when you move the gear lever. There's a screw that acts as a stop to prevent it moving out too far. If you look at it and move the derailleur by hand you'll see it. This can be adjusted if it needs to be. To oil the derailleur, oil the hinge on which it moves in and out. Oil the teeth and the chain. The cables may be seized and need replacing. To check you can disconnect them by loosening the nut and bolt that connects them to the derailleur and try moving the gear levers or just pushing and pulling the cable wire through the core. If they move easily enough it's worth pulling them out and oiling them as they probably have some rust on them. There's very little else to getting them working again. The front derailleur will also need oiling and the wheel bearings on both wheels will need greasing.
Posted on Oct 12, 2010
Can I replace a Shimano RD-TY15 with a Shimano Tourney TX?
This may be to do with the replacement having a shorter cage, so it can't go on the big sprocket and big chain ring at the same time.
Try to not use the big rear sproket and the the big front chaining at at the same time,
Apr 24, 2015 | Shimano Cycling
Fitting instructions needed for Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur with Bracket
The semi-circular spacer is what holds the derailleur in the dropout. Take the part that looks like a "C" and line it up on the drop out, the spacer goes on the other side of the dropout. There should be a screw that fastens to the spacer and clamps the derailleur to the drop out.
Apr 14, 2014 | Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur...
Shimano fd-m510 front derailleur spring is stuck
Not a problem that can be diagnosed without eyes and hands on the bike. Post a clear video, or better - take to a bike shop or bike co-op.
Jun 12, 2017 | Mountain Shimano Deore Fdm510 Front...
Large trigger has to sit for a while befor it will engage. Derailleur does move when it does engage. You get one pump and then you wait. This bike has been sitting for 3 years unused.
If you mean the derailleur doesn't move straight away when you move the gear trigger it's likely that the derailleur needs cleaning and oiling. As the bike hasn't been used for 3 years also oil the chain, check that the cable pulls the derailleur far enough. if it doesn't there the cable may need to be tightened. If the derailleur is not going back out far enough there's an adjusting screw which sets the limit. this may need adjusting.
Jul 17, 2010 | Shimano Shifter Pods 3x7 Shm Bicycle...
Shimano Tourney rear derailleur is stuck on smallest gear and will not shift. How do I adjust the tension correctly?
There are several things that could be wrong. You could have thrown your chain (you couldn't ride at all if so). The bike could have been crashed and the derailleur bent. The cable might have slipped where it bolts to the derailleur. Or the cable or shifter could need maintenance, too. It is most likely one of the above. If it is only the adjustment, there are two stop screws on the derailleur that can be adjusted.
My best advice for you is to either find a bicycle repair manual at a local bookstore or your library that can show you some of the detail. Or just let your local bike shop do the repair.
Aug 30, 2009 | Mountain Shimano Tourney 6/7 Rear...
Shimano 70gs rear derailleur won't shift. The thumb levers move but don't engage. Can I fix it or will it have to be replaced.
I just had the same problem with my wife's old bike. After removing the cover (as explained in answer #2), I saw that the pawl (the part that engages the ratchet)was stuck in the open position because the grease had dried up. A shot of pbblaster (or WD40) freed it up and everything is now working fine.
Jul 26, 2009 | Cycling
I am having problems with my Shimano front derailleur
Adverse temperatures can affect metal, and left idle over time the cables can stretch.. It needs adjustment. Usually the is a pair of screws on top which limit the movement of the derailleur.
Mar 14, 2009 | Mountain Shimano Alivio Front Bike...
Cycling Logo
417 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
