Question about Sony DVP-CX850D DVD Player
HOW DO I TYPE NAMES OF CD OR DVD ? - Sony DVP-CX850D DVD Player
  • Sony Master
  • 5,103 Answers
You can't add a title to a disc from a player (such as this). You can only add a title on a disc writer before finishing the disc. (The only exception is RW (rewritable) disc which can be unfinished.) If a title (disc, chapter or track) is on the disc you can display it. Press Title on the remote. If you want to read all of the information on any disc, insert the disc and press Load on the player (when in Stop mode) or press the TV/DiscExplorer/DVD button to set the unit in Disc Explorer mode. It takes about 30 seconds to load the data. Press Stop to cancel the data search. Then use the folder buttons (ALL,DVD,CD,A,B,C,D) on the remote or the player to read the various items. Press Return to leave the folders. If you enter the Disc Explorer while playing a disc, the playback will stop and you will have to press Play to restart (Resume is not an available option).
Once loaded the player will store the data even after you remove the disc. It will clear when a new disc is inserted or you press Load.
The manual for this unit is available at: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPCX850D .
I hope this helps.
Posted on Oct 12, 2010
  • Cindy Wells Oct 12, 2010
    If you have loaded the data from the disc into the Disc Explorer and the disc has no DVD or CD text, you can add a memo that will stay in memory until a new disc is inserted (or the power goes off). Enter the Disc Explorer and select the disc. Press Edit and select each character with the up/down/left/right arrows or the click shuttle. Press Enter to store each character. Press Edit to finish the memo. Press Return to end the Edit functions.
    To edit a memo for a folder, Press Edit then the up arrow. Select the desired folder with the left/right arrows. Press Enter and then repeat inputting each character for the folder memo. Press Edit to end the title.
    To add genre information to the memo, press Edit and the right arrow. Then navigate the list and press Enter to select the desired memo.
    You can also enter the memos with a PS2 IBM combatible keyboard. (I do not think a USB keyboard will work with a USB to PS2 adapter - that would require a USB driver that the player probably doesn't have.) Use the remote or the buttons on the unit to enter the Disc Explorer edit functions as above but then type the name normally. Press Enter on the keyboard when done.
When i enter cd/dvd into lg dvd drive it does not show anything
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Aug 16, 2012 | LG GH22NS70 Super Multi 22X SATA DVD...
I wiped out the cd/dvd DRIVERS on my sony pcv-rs310
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jul 20, 2012 | Sony VAIO PCV-RS310 PC Desktop
My matshita ujda760 dvd/cdrw read and burn cd but can't read dvd rom. I uninstalled the drivers and reinstalled but the problem continue.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Feb 04, 2011 | Panasonic (UJDA750) CD-RW/DVD-ROM (Combo)...
Code 41 error
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 17, 2011 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
My dell studio 1737 doesnt read any disk when i put them in
HI Friend, In this case I would recommend you to check if the CD/ DVD drive is getting detected in Windows Explorer or not ( MY computer) window. If it is not getting detected there then goto device manager and check if you have yellow bang on the CD/DVD drive option or not. If there is a yellow bang then you need to follow the below steps:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation anderror code on the CD or DVD drive is gone
### If CD/1) Close all open programs 2) Click on Start, Run, and type REGEDIT and press Enter
* SYSTEM
* CurrentControlSet
* Control
* Class
BFC1-08002BE10318}
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
### IF CD/DVD is getting detected in windows explorer then try updating the firmware for CD/DVD drive
Dec 14, 2010 | Dell Studio 1737 Laptop
This dvd writer can read and write dvd, cannot read and burn cd
you might have to physically unplug the plug you cd rom back in this should activate the found new harware wizard or you might try
control panel admistrive tools,computer management,device manager scroll cd/dvd rom drives right click you can update driver disable or uninstall select properties from there you can troubleshoot or select driver you can update roll back driver uninstall if at any time you see a yellow question mark? you need to install a driver
or it might be a registry problem you did mention if you could see this dvd burner in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Nov 17, 2010 | LG GH22LP20 DVDRAM Burner
MY COMPUTER IS NOT SHOWING THE CD DRIVER. HOW CAN I EXPLORE THE FILES OF MY CD?
you might have to physically unplug then plug back in this should activate the found new harware wizard or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Nov 05, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My Samsung CD-RW/DVD-ROM Combo Drive could not support dvd ?
try these steps
* SYSTEM
* CurrentControlSet
* Control
* Class
BFC1-08002BE10318}
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
Jul 05, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Get a code 10 error message. it doesn't run any cd or dvd
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Registry Editor
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Jan 11, 2010 | Pioneer DVR-107D DVD±RW Burner
The DVD/CD-Rom device does not work.
* SYSTEM
* CurrentControlSet
* Control
* Class
BFC1-08002BE10318}
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
May 07, 2009 | Dell Computers & Internet
Sony DVP-CX850D DVD Player Logo
109 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
