Question about MTX TA4501 Thunder 4501 MonoBlock Car Audio Amplifier
I have a MTX 4501 amp and it has two lights a thermal light and a short light, the short light is on and i have no idea what to about it. any help would be great.
SOURCE: My car AMP will play for a few minutes, then just Turn OFF
Is your sub single voice coil or dual? If it's dual, is it wired in paralel or series? It's possible for an amp the heat up so fast, the outside is not hot to the touch. Also, the next time it happens, use a paperclip and short the 12+ to the remote wire on the amp and see if it comes on. Let me know, and be sure to leave feedback or I don't get paid
Posted on Oct 03, 2007
sparky1500
  • 1066 Answers
SOURCE: MTX 4501 Mono Amp - no output
broken crossover switch or damaged circuit
Posted on Nov 29, 2008
jrw4u
  • 62 Answers
SOURCE: Everything works fine but my amp light is red.
if its not coming on it usually means you have a bad ground if it works for a little while then does it then its over heating and you will need to get a fan
Posted on May 01, 2009
  • 84 Answers
SOURCE: mtx thunder 304 4ch red amp light comes on but no audio
if the lights on and there is no sound it's either a cd player issue or your rca issue or the inputs for rca's on the amp are no good. or you have your subs wired at a wrong load to your amp and it is in a constant protection to avoid burning up.
Posted on Jun 14, 2009
nate6556
  • 103 Answers
SOURCE: MTX Terminator Amp...Red light comes on when it should be green.
its just a power light to let you know its on
Posted on Jul 25, 2009
Need manual for mtx audio thunder 4501
Hello
Get into this link. You can download the user manual to your device from here. OK.
caraudio.manualsonline.com/manuals/.../mtx_audio/mtx_audio_car_s
Jan 13, 2012 | Car Audio & Video
I installed a MTX Thunder 3401 with a PA sub. after turning the car oh every things works great. After about 2 mins of play, the thermal light begins flashing red and it will shut off the amp. After the...
You are def overheating, If the ohms rating of the subwoofer is too low it will cause this same thermal over heat. If you have 2ohms in sub and a 4 ohms stable amp, you will overheat. Check the ohms rating of the sub to make sure this is not the problem
Jan 31, 2011 | MTX Thunder 3401 Car Audio Amplifier
Fast blinking red light
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Good L .A thumbs up would be greatly appreciated if this answer is helpful to you. MTX Audio
Aug 13, 2009 | MTX X Thunder 1000XD Car Amp
No LED power lights go on
the light with the power light(middle) is a blue/purple faint light try checking it out at night.The squiggy(as heat waves) will only light when the amps shuts down due to thermal protection(wait for it to cool). The bolt/yellow (short circuit) will light when there is an electrical overload in any of the wires(check +ve leads).
May 26, 2009 | MTX JackHammer JH202 Car Audio Amplifier
My red light on my amp is on and wont go out
Unfortunately I think you need to get it repaired or replaced .When a protection light will not turn off it is generally caused by an internal short and needs one or more replacement parts for it to come alive again.
-Dynami
Apr 03, 2009 | Insignia 600W Bridgeable Amplifier with...
Help connecting the sub
Your sub or amp is probably blown. Do you get any power to the amp? try hooking up another speaker and seeing if you get any signal at all.
Jun 24, 2008 | MTX TA4501 Thunder 4501 MonoBlock Car...
It sounds like you have a defective switch or a broken solder connection. If the amp is new, return it for repair/replacement. Don't break the warranty seal if it has a warranty.
Apr 03, 2008 | Car Audio & Video
Amp works fine i think??? but Prsim efx not working at all
You need to contact MTX tech support before the warranty runs out. You'll probably have to get an RA number to send it back.
http://www.mtx.com/caraudio/contactMTX.cfm
Oct 18, 2007 | MTX TA4501 Thunder 4501 MonoBlock Car...
Car Audio & Video Logo
112 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
