Question about Samsung Refrigerators
I bought a model RF26XAERS bottom freezer/ French door Samsung efrigerator the end of May 2010 and today (Oct. 11, 2010) it stopped dispensing water. It sounds like the solenoid for the water engages (but not sure) and all I get is a drop of water about every 10 seconds. Now even when I'm not trying to dispense, it drips a drop of water every 1 - 2 minutes. Just to let you know, I had to turn off the water-box at the street to work on a faucet issue in an upstairs bathroom last Monday and all was fine until now. Please advise.
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
SOURCE: Kitchen Aid Superba refrigerator
the black panel that runds down the side of the refrigerator between the freezer and food storage area is very hot. also the small light in the freeezer is blinking even though i have it turned off
Posted on Aug 07, 2008
SOURCE: water dispenser
We have a hd2560 (bot 10/04), french door with inside water dispenser and it had stopped working a year ago, but started working a few months later. I couldn't figure out what happened, but suspected the water line was frozen. I later found out that the water reservoir is located behind the fruit and vegetable bins, so look there to see if the water is frozen.
Two weeks ago, our frig/compressor stopped cooling after making humming/clicking sounds for weeks. Fortunately, Maytag has a 5 yr parts & labor warranty on the compressor, so we were covered. Evidently, there are quite a few faulty compressors out there.
I believe that the compressor had been over-cooling in the past and caused the water lines/tank to freeze. This would also cause frozen produce/fruit. I would immediately contact Maytag/Whirlpool if you suspect a faulty compressor as well.
Posted on Oct 30, 2008
  • 247 Answers
SOURCE: kenmore refrigerator ice/water in door not working
welcome-
what type of kenmore do you have (brand and model number)? this way it is easier to find infomation for you.
thanks and happy holidays
Tom
Posted on Dec 19, 2008
MNTECH
  • 1543 Answers
SOURCE: Reset Filter Indicator Light is on
Look for your model number from the sticker inside the fresh foods section of the refrigerator, usually on the liner near the door opening. Now, go to http://www.geappliances.com/service_and_support/literature/ to download a use and care manual for your model, as the reset procedure may vary by model. The filter is usually located at the very back right upper side of the fresh foods compartment, but again, it may vary by model.
Posted on Apr 11, 2009
Rather than self-closing, our refrigerator doors each stop about 4 inches short, requiring a strong push to close. Is this normal or problematic? No kidding ~ 41 views and no answer?!
it would seem as if the doors need fixing or that the icebox isnt leaned back enough to self close...but that is just my IMO sadly...
Dec 28, 2016 | Samsung Refrigerators
Why is my Samsung RF26XAERS refrigerator repetitively chiming, and how can I fix it?
NOISE? from the fridge inside? or from the outside compressor? In overstressed compressor or low freon level will make weird noises? a bad fan in freezer will? Even seen bad ice makers make weird noises? if the ice making is hindered by obstructions?
Aug 20, 2014 | Samsung RF26XAERS 26 Cu. ft. French Door...
The ice maker will make the ice but I have to manually press the reset button to have the ice dump into the tray. It will not dump ice on its own. This is for the samsung RF217AB french door bottom...
Make sure the freezer is cold enough. If not this might cause problems of poor dispensing.
If your ice makes unit has a 'heater'build into it, it just might be that the heater in the tray does not work..if so, new ice tray dispenser.
Oct 25, 2013 | Samsung RF217ABWP (20 cu ft) Bottom...
My whirlpool French door fridge is leaking all over the floor. The drip pan underneath is bone dry. I can't find the drain hole inside the fridge to see if it is clogged. Is letting it thaw for tw
there is a water tube connection at the bottom of door on hinge side that has a spring and allows it to swing with door. it also has a fitting there so the door can be removed.it is the tube running inside the door to the ice water dispenser. if it has one, it can leak at the fiting
Jul 07, 2012 | Whirlpool GX5FHDXVY Stainless Steel (248...
I bought a kenmore refrigerator model 71303... a french door model with nothing on the doors (dispenser-wise) and a pull out drawer freezer. fits the space in my kitchen perfectly, however I just...
Unfortunately, 71303 is not a complete model number, even though that is how Sears lists the unit here: http://www.searsoutlet.com/22-7-cu-ft-French-Door-Bottom-Freezer-Refrigerator/d/product_details.jsp?pid=41106&mode=seeAll . However, most french door refrigerators can have the doors and freezer drawer removed. I think your model number will be 795.71303* (there are a few digits omitted). The manual is available here: http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1103856L.pdf . The directions for removing the doors and freezer drawer start on page 11 (page 10 of the PDF).
The 795.71313 is a similar refrigerator. The directions to remove and replace the doors and freezer drawer is given starting on page 13 in the manual. See that manual here: http://c.shld.net/assets/docs/spin_prod_946454012.pdf .
I hope this helps.
(Kenmore refrigerators are made by other manufacturers. The three digit prefix in the model number is important to find the correct manual. A different French door refrigerator, 106.7200*, can have the doors removed. However, only the front of the freezer door comes off. That manual is here, http://c.shld.net/assets/own/spin_prod_734629012.pdf; see page 10 and subsequent pages.)
Mar 12, 2017 | Kenmore Refrigerators
Water will not dispense--fairly new filter
Are you sure about that model number because I have the service manual for a RS265AA if you like. The water valve can be tested ao back with a multi-meter and should show 120 volts or your home voltage when someone presses the dispense water switch. If yes the voltage is present the water control valve is defective and will need replaced.Double check your model number because there are no Samsung refrigerators with the RF2 prefix RS2 is Samsung prefix. Let me know, what you find, Sea Breeze
Dec 11, 2009 | Samsung RF265AA Bottom Freezer French Door...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerators Logo
83 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
