Question about Dell PowerEdge 2600 Server
How do i reset the power supply on my poweredge 2600?
    Sergeant:
    Novelist:
  • 143 Answers
You don't "reset" power supplies. They run until they fail. At that point, you replace the power supply with one that works.
If you meant "reseat" then you would first determine what type of PSU you have. If it's a redundant power supply, you unplug the power supply, activate the latch on the handle of the PSU module and pull...then push it back in and plug it back in. (Flip any switches to the "On" position.)
Replace power supplies that do not come back on.
Posted on Jun 14, 2015
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 24 Answers
Resetting the power supplies isn't necessary. Once one of the ptwo power supplies fails, the second power supply automatically takes over. Also, there isn't a need to power down the system to change the supplies as long as you change them one at a time.
Posted on Oct 17, 2014
3 Suggested Answers
MDoe
  • 156 Answers
SOURCE: Poweredge 2600 power supplies in red
Hi
PowerEdge 2600 utilizes a Power Distribution Module (PDM) for power redundancy. The two (Max) Power Supply Units plug into the Power Distribution Module in the front and two power cords at the back from power outlets..
If a power supply lites RED, it indicates the respective power supply unit is faulty (normally) and/or the slot/PDM is faulty (very rear). Given that both power supplies indicated fault the issue may as well be with the PDM.
Check here for help to re-seat the PDM cables. If issue persists consider replacing the PDM.
Let me know if further help is needed
Mike
Posted on Jul 12, 2008
  • 159 Answers
SOURCE: Adding DVD to Poweredge 2600
PE2600 has lots of spare power (unless you are already using all 6 SCSI drive bays) ..
You can fit 3 x SATA drives in the space where the (useless) tape backup unit is sitting [you can even buy a 'proper' enclosure = Icy Dock MB453SPF or I think the SNT-2131 will fit ] .. and you can split the power off the Tape drive (4pin) power socket ..
I've not found a DVD burner (only a combined DVD reader / CD burner = TS-L462C) .. however if you have a spare IDE port you should be able to use an external unit [you will need an e-ide cable & enclosure for the drive]
Posted on Feb 09, 2009
I'm trying to start Microsoft Windows Server2003 from USB Hard Drive on Dell PowerEdge 2600 Server.
Dell provides lifetime tech support for all PE servers. Call them at 800-945-3355 and give them the service tag or express service code from the server. If it can be done, they will tell you how.
Feb 29, 2012 | Dell PowerEdge 2600 Server
Dell poweredge 2600 server recently display a message " No boot device available Press F1 to reboot or F2 to setup" Please why?
Did you experience a power event? Go to BIOS (F2), and make sure that RAID is Enabled. If RAID got turned off (power event, BIOS reset), then it will give you that message. If RAID is already enabled, then you may need to repair your operating system. If something else happened (drive failures, drives removed, etc.), then the array may be completely gone. Call Data Recovery services if it is critical you retreive the data.
Aug 03, 2010 | Dell PowerEdge 2600 Server
Poweredge 2600/Powervault 770N does not boot
I recommend that you first try replacing the power cord, if that doesn't work try replacing the power supply.
Mar 30, 2017 | Dell PowerEdge 2600 Server
Dec 11, 2008 | Dell PowerEdge 2600 Server
Problem with USB cable
Have you tried connecting it to another USB port?
Sep 19, 2008 | Dell PowerEdge 2600 Server
Problem with creating array
The Perc RAID controller in a 2600 doesn't support RAID 4.
You can do RAID 0, RAID 1 and RAID 5.
With 3 HDD's your best bet would be a RAID 5.
Mirroring is RAID 1 (which would only use 2 of the drives)
Aug 31, 2008 | Dell PowerEdge 2600 Server
Possibly a power distribution board problem.
PDB requires replacement.
Jul 09, 2008 | Dell PowerEdge 2600 Server
In front pannel RED light is on and off what is the reasion
Dear Rameez,
it means your computer is in trouble.try contacting the customer service. its usually due to loose connection between the hard disk cables or your RAM...but avoid opening the cover, call service care instead.
Takecare
Mar 18, 2008 | Dell PowerEdge 2600 Server
Dell PowerEdge 2600 Server Logo
435 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
