Question about Stanton STR8-150 Turntable
STANTON STR8-150 Sound levels
I have 2 turntables - and a Numark Dimension 3 amp - and Behringer 1520 speakers and a Numark DXM-09 mixer. when i play a STR8-150 through the stereo on the amp I get a considerable reduced noise coming from one speaker - the problem is the same on both stantons but my CD decks work fine through the system - I only get equal sound if I play through MONO (onthe red wire input) - any ideas what I am doing wrong?
  • 69 Answers
Try different rca leads to amp
Posted on Aug 06, 2009
I have a T62 Stanton and I want to play it like a normal turntable. I conected it in the Behringer mixer using L/R cable. I cannot hear the bass sounds with my headphones. What is happening?
Is it connected to a "PHONO" input or something not labeled explicitly for PHONO?
"PHONO" is the only designated connection on an audio device that is literal and exclusive.Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn't have a PHONO connection you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some... http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
Apr 17, 2011 | Stanton T62 Turntable
I hooked up my new stanton t-60 turntable to an older sony amp that does not have a phono jack. i used a behringer pp400 preamp to connect the turntable to the amp. the sound is coming through with heavy...
Are you using the phono input on the Sony? If so, you're getting too much gain, you've already got a phono pre amp in the Behringer. Try using the tape or C.D. input. That should solve it.
Jan 16, 2010 | Stanton STR8-60 Turntable
Numark dxm power failure?
i'm having the same problem, just wondeered if you found any solutions to this?
Jul 14, 2009 | Numark DM1200 DJ Mixer
My power cord was pulled out while still on.
Are you talking about a Numark DXM mixer? If so, why would you say you have an issue with a CDJ-800? Numark Parts can be found here.
If not, you need to be more specific as to who makes your mixer.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 10, 2009 | Pioneer CDJ-800 Turntable
No signal going into mixer.
Did you buy the gear new? If not, the issue might be with the meter. Also, sometimes the signal isn't loud enough to engage the meter, so try cranking up the Trim and Volume (Master & Line), of course, make sure the volume on your amp is down, so you don't blow anything.
Good luck.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Feb 04, 2009 | Technics SL-1210 Turntable
I have a xenyx 2442fx mixer and ep2500 power amp hooked up to 2 1800x subwoofers and 2 1520 pro speakers. i am using a peavey xr 684f powered mixer to power my monitors. i would like to add another power...
You would need a 2 or 3 way crossover, depending on whether or not you biamp your tops. Simply go out of your main outs on the mixer into the input of the crossover. Go from the low output of your crossover to your low power amp input (subs), and the high output of the crossover to the high power amp input (tops). Then go from your outputs of your amps into the speakers themselves.
Jan 04, 2009 | Behringer B1520 Pro Eurolive 15" 2-Way...
Home stereo audio problems
Could be a bad patch cord, a setting on the mixer, a faulty mixer (unless it works ok with other amps), or a dirty control on the Sony amp if it has analog controls. Have you tried connecting other sources to the Sony?
Sep 27, 2008 | Audio Players & Recorders
Connecting a behringer djx700 mixer to a panasonic amp
The problem is most likely between the turntable and mixer. You need to be sure that the turntable is connected to a phono input. I'm not sure if your mixer has one. If not, you need to have a phono pre-amp between the turntable and the line input on the mixer.
Check that first and get back to us if you still have problems/questions.
Dan
Aug 21, 2008 | Audio Players & Recorders
Stanton STR8-150 Turntable Logo
179 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
