Question about Uniden Cordless Phone
ANSWERING SETUP- NOT ABLE TO TURN ON - Uniden Cordless Phone
    Problem Solver:
  • 9 Answers
It may be similar to the problem I had with the wireless home phone with answering machine not taking messages when had the answering machine set to 12 rings before answering. Found the sim card (my wireless system) auto response would answer first. Fixed it by reducing time to 6 rings and answering machine now comes on first. This might resolve it for you.
Posted on Oct 15, 2010
Need to turn volume up on fax
From the printer home screen control panel, touch the Setup button > Fax Setup > Ringing and Answering > Ringer Volume. Adjust to your preference.
Hope this information has been helpful.
Sep 12, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
My answering maching is answering in another language. How do I get it to answer in english?
Press and release SETUP button until you hear the feature announced that you want to change.
Press ANNC/SKIP or MEMO/REPEAT button to change the current setting. Press PLAY/STOP to
exit feature setup.
Jan 19, 2011 | AT&T 1717 Digital Answering Machine
HP L7650 will not auto answer incoming faxes
To set the answer mode to manual or automatic via the control panel
? Press Auto Answer to turn the light on or off, as appropriate for your setup.
When the Auto Answer light is on, the device answers calls automatically. When
the light is off, the it does not answer calls.
To set the answer mode to manual or automatic via the embedded Web server
1. Open the embedded Web server, click the Settings tab, click Fax in the left pane,
and then click the Basic sub-tab.
2. Select On or Off in the Auto Answer drop-down menu in the Other Basic Fax
Settings section.
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1. Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
To set the number of rings before answering via the embedded Web server
2. Select a number in the Rings-to-answer drop-down menu in the Other Basic Fax
Settings
section.
Dec 02, 2010 | HP Officejet Pro L7650 Printer
How do I set a new time and date on the answering machine
Press and hold the SETUP/ENTER button for two seconds to enter the setup menu. The "Changing the Settings" section begins on page 10 of the manual at
http://www.home-electronics.net/USER-GUIDES/29871_DOM_ES_AN_IB.pdf
Oct 06, 2010 | GE 29871GE3 Digital Answering Machine
How do I get the answering machine to work properly?
Answering System Feature Setup
You can set up one feature at a time, or you can set up
a feature and then move on to set up another feature.
1 Make sure the answering system is on.
2 Press and release Uuntil you hear the
system announce the feature you want to set.
Refer to the Feature Summary chart on page 54
for a description of the features and your choices.
3 Press cto hear the feature’s settings.
4 Press Uto move on to the next feature
or press a PLAY/STOP button to exit Feature
Setup.
You can download the pdf format manual on this website:
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=261
Sep 12, 2010 | AT&T 5840 5.8GHz...
Setup answering mach.
how do you set up the answering machine on the base?
Feb 14, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
AT&T 1717 How to turn on Announcement Monitor.
You can choose whether to hear the
announcement when your system answers
a call, or have it silent (off) on your end
(your caller will still hear an
announcement).
1 Press and hold "Setup". After the Ring
Select setting is announced, continue
to press and release "Setup" until the
system announces “Monitor is on (or
off)”.
2 Press and release "ANNC/SKIP"or "Memo/Repeat"
until the system announces your
selection.
3 Press and release "Play/Stop" or "Setup"
to exit.
Jan 01, 2009 | AT&T 1717 Digital Answering Machine
How can I change the Rings to Answer setting to one ring?
1.
Press Setup.
Get manual at http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Jul 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Setup Instructions
did you scroll through the options (up and down arrows) until the Global Setup screen appeared?
Nov 18, 2007 | Uniden TRU8885 Digital Answering Machine
Uniden Cordless Phone Logo
353 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
