Question about Brother Sewing Machines
Purchased a new 6000i last week. Read manual. Filled bobbin. Started to sew doll clothes. 15 minutes OK. Then machine shook and needle bent. Now cannot sew. Bobbin feed is totally uncontrollable, pulling great amount of thread. Machine does about 4 stitches and begins to shake.
  • Brother Master
  • 7,365 Answers
I would suggest you take the machine back to where you bought it from & get another one
a new sewing machine shouldn't be doing that
Posted on Oct 12, 2010
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
Good day!
Jun 08, 2011 | Husqvarna Freesia 415
Needle keeps jamming, won't thread
Good day!
Good day!
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
Good day!
Jun 07, 2011 | Brother CS-6000
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
Good day!
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
Good day!
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
I have the error message that there is a mechanical problem and the guide says that the machine is stuck??? How would this be repaired?
Good day!
Good day!
Jun 05, 2011 | Feiyue FY100 Computerized Sewing Machine
Sewing Machines Logo
46 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
