Question about Samsung Cell Phones
Hi, i ve switched my d500 phone on today and very minute it vibrates 4 times and then does a sound any ideas. i have checked the alarm isnt set and also checked that there is nothing in my calendar, any ideas as it is doing me head in a bit now
    Problem Solver:
Check the phones profile
Posted on Jun 01, 2008
My Mother-in-Law recently purchased a ZTE Majesty Pro [Z799VL] telephone from a Dollar General store. It has an alarm that goes off every 15 minutes. How do I disconnect from this service?
Read the manual. Turn the alarm off and the repeat function. It probably has an alarm set and the 15 minutes reminder is to say it hasn't been cancelled.
Page 89
Clock
Press the
Home Key
Clock
. The Clock app allows you to check local time in places
around the world, set alarms, and use timers.
Setting a New Alarm
1.
Open the Clock app and tap
2.
Tap a default alarm to configure it, or tap
at the bottom of the screen to create a
new alarm.
3.
Set up the alarm options, such as time, alarm days, snooze, and alarm ringtone.
4. Tap
SAVE
to save and exit.
NOTES:
To enable or disable existing alarms directly, tap
On
or
Off
on the right side
of each alarm.
• Tap
to configure alarm settings, including ringtone volume, vibration, alarm
duration, volume crescendo, and alarm in silent mode.
Manual is here
http://zte-iqorsupport.custhelp.com/ci/fattach/get/3730/0/session/L2F2LzEvdGltZS8xNTExMjI1NjY2L3NpZC9mVUl0Ykhoc3lwNW9rVWZ3WU0ycGlPbllqOEdkS1lzTFB3ZkJheHNGdXdFUEtweVpzZWUzZ05BaWhiTmFMJTdFdVBoU09TUVJzcExxYUpXUFBndldkUmVCNl8xNldsTE1RRWlHQ1J1dDhBYkNHa2xFRHNheHVSJTdFZE9nJTIxJTIx/filename/ZTE_Majesty_Pro_LTE_GSM_Z798BL_UM_EN_Approved.pdf
Specs and link to manual at the bottom of the page.
How do get the User Guide for the ZTE Majesty Pro LTE Z798BL GSM
Nov 21, 2017 | ZTE Cell Phones
Thinking of getting the TI150 3-in-1 Timer - Can it set to repeat a countdown over and over?
Review at Amazon seems to say the timer can repeat the same countdown each time button is pushed and countdown is activated.
Amazon review says:
http://www.amazon.com/General-Tools-TI150-Visually-Impaired/product-reviews/B001TOJG7Y/ref=dp_db_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
The timer is easy to set. You just set the time, then hit the big "start/stop" button and the little "H" and "M" on either side of the timer display flashes.
To clear the timer, just hit both the "h" and the "m" buttons simultaneously. (so time has to be cleared)
To stop the alarm or to turn off the timer before the alarm sounds just hit the "start/stop" button.
On the back of the timer, there are 4 different on/off switches: flashing light alarm, sound alarm, vibrating alarm, and one for hours/minutes or minutes/seconds.
When I set the timer on my desk, it moved around when the alarm went off but when I turned off the vibrating function, the timer didn't move around.
If you need to turn off both the sound and vibrating alarms and use only the flashing light alarm, the light is quite noticeable by itself if placed nearby in your line of sight (within a foot or so). This would be very handy if you're near a sleeping baby! :) But if you clip it on a breast pocket, I would use both the flashing light and vibrating alarms. The vibrating alarm does make a sound, but it's not as loud as the ringing alarm.
Dec 27, 2010 | General Tools Hardware & Accessories
I did not get any instructions with my son's ben10 four arms projection alarm clock, and cant figure out how to even set the time, does anyone have instructions please
Hi
Hopefully you've figured this out by now, but if not then I hope this helps.
Alarm Setting - Press Mode twice to change the alarm time. Set switches between hour and minutes and Adjust changes the time. The alarm is on when there is a symbol at the top right on the display. Press and hold Set then press Adjust to toggle the alarm on or off.
Time/Date Setting - Press Mode three times to change the current date/time. Use Set to move between the hour, minutes etc and Adjust to change them, as with the alarm.
Pressing Mode once accesses a stopwatch function. Adjust to start/stop and Set to clear.
Dec 25, 2010 | Toys
How do you set aliam on my nokie e51
Got ot the link below page 67-68 will tell you how to set the alarm.
http://nds1.nokia.com/phones/files/guides/Nokia_E51_UG_en.pdf
Or
Alarm clock
Open the alarm clock tab.
To set an alarm, select Options > Set alarm. When an
alarm is active, is displayed.
To switch off the alarm, select Stop, or to stop the alarm
for 5 minutes, select Snooze. If the alarm time is reached
while the device is switched off, the device switches itself
on and starts sounding the alarm tone. If you select
Stop, the device asks whether you want to activate the
device for calls. Select No to switch off the device or Yes
to make and receive calls. Do not select Yes when wireless
phone use may cause interference or danger.
To change the alarm time, select Options > Reset
alarm.
To remove the alarm, select Options > Remove alarm.
Good luck please rate 4 thumbs up and please leave a testimonial.
Oct 28, 2010 | Cell Phones
Having alarm clock sound even in vibrate mode
It is not possible to sound alarm in vibrate mode, but by going into master volume and setting it to sound alarm only, the alarm sounds in silent mode.
Jan 10, 2009 | LG Cell Phones
Samsung sgh-d500 - sound / hear problem
Take it to the shop. that is a technical problem. sorry. this is an awsome site though because it fixed my d500!
May 08, 2008 | Samsung SGH-D500 Cellular Phone
Alarm beeping
Not sure, but the 1x active may have to do with some time of alert that you may have accidentally set in your calendar or alarm clock. Check your calendar and alarm for active alerts.
Dec 24, 2007 | Kyocera KX2 Cellular Phone
Samsung d500 problem with downloading hava applications
Check if java script is enabled and also u must try upgrading the browser if issue continues.
Mar 01, 2007 | Samsung ZX10, E315, E317, P735, E630, D500...
Cell Phones Logo
14 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
