Question about Teac PD-H300 CD Player
Teac Reference 300 CD model PD-H300C very muffled sound.\r\n I've tried different leads, and using the Aux input on the amp. I've tried cleaning the laser - carefully! The CD reads OK but the sound is very very muffled, I can only just tell it's there at all. The problem affects both channels, so it must be a common component, presumably in the power supply. How can I check and track down the failing item? Thanks, Nick
4 Suggested Answers
  • 3 Answers
SOURCE: Display doesn't work on TEAC PD H300mkIII
I had the same issue today. I found that opening the unit you can see that there is a white ribbon cable connecting the head unit to the main board. removing this cable and re-inserting it the connector fixed the problem. The display now works again...hope this helps
Posted on Nov 21, 2009
taran_2005
  • 10515 Answers
SOURCE: I turned on my TEAC
Switch off power, remove cover. Remove four screws holding top black plastic disc cover and then remove all of the black plastic ( x 7 ) disc holders. You may find that the aluminum cross structure has come adrift. Replace into the slots again and replace all the disc holders. If you want, you can check before replacing cover, by then ejecting and 'disc skipping'. It should then be OK. If it has been forced, the aluminum cross structure thing may have also come out of the slot it should in in on the right hand side. Slide the disc frame in or out until it can be fitted and retest.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
  • 910 Answers
SOURCE: My TEAC PD-H380 cd/mp3 player
PDF Manual at the link below Page 11.
http://www.teac.co.uk/manuals/pdf/PD-H380(EFS).pdf
The USB connection is only for a USB Memory stick, not an external MP3 Player
Posted on Jun 16, 2011
I would like to find out how to play audio from my panasonic viera tx-40cx400b tv/other devices e.g. xbox one etc through to my Teac A-H300 amplifier.
Having looked at the TV, you will have a lot of problems trying to connect to that amp. The TV has a digital optical out output only. The disc player you mentioned will also be out only. You need a optical "in" for them both. The TV has no analogue out sockets. The only chance you might get any sound out is via the scart socket. If that is fully wired, then the scart might produce L&R analogue out. A scart plug with RCA connections (make certain it has both audio in and out) might produce some sound for the amp.
Otherwise no chance!
The amp you have was not made to work with digital signals. The TV will produce high quality Dolby 5.1 sounds. Assuming you get the scart to produce the sound, then you will only get stereo sound, little better than the TV itself!
I therefore recommend you get a decent digital amp that you connect all your future devices too. One that has HDMI connectors as well as at least two optical inputs.
Onkyo make some excellent models. For example this model would do the job Onkyo TXSR444 Home Cinema Receiver.
Feb 25, 2016 | Teac A-H300 Amplifier
Turntable hookup to AUX or CD (no Phono input) only producing very weak sound, even at full volume
You are doing nothing wrong at all. It's just that as you say it has no phono input. Which means the sockets you have will NOT amplify the signal. So you need to buy a magnetic cartridge pre-amp and once connected to the aux the weak signal will be at the normal level.
Jul 11, 2017 | Pioneer VSX-818V-K Receiver
Only two of my amplifier inputs are outputting sound correctly!
Odd one! Normaly you would loose a channel if the main amp was down, or the pre-amp was. But clearly the main is working. The only conclusion is that there must be more than one pre-amp and that's why the Tape section works. The only way to solve this one is to go inside and trace the imputs to where they join the PC board.
A helpful hint is that if you touch the audio section with a srewdriver, it will buzz! And since you have two channels which copy one another you can work out where the fault is. Because if it buzz's in the good channel, it should in the same place on the bad one.
WARNING don't stick your srewdriver on power parts, and don't short any part out with it.
Feb 09, 2010 | Teac A-H300 Amplifier
After 16 months our PD-D2610 CD changer has started misbehaving. Some of the 5 positions work fine but positions 1 & 4 almost never work.
I read enough comments from unhappy TEAC owners with similar problems to learn that the drive motor is to blame and that repair sounds like sending good money after bad. I'm going to buy a Sony changer.
Nov 18, 2009 | Teac PD-D2610 5-Disc CD Changer / Player
Aux input for sony car stereo (cdx c 5000r)
For Sony Stereos, you will need to get what is called a Bus Converter. The RCA ports you are trying to use are for a CD changer or alternate device like satellite or HD radio, and those have to have some sort of frequency signal to even be selected. You can find a Bus Converter that will allow you to use this as an Auxiliary input. The device you are looking for is called a Sony XA 300, and it will allow you Two extra Aux Inputs, I believe.
Jan 24, 2009 | Car Audio & Video
Teac Receiver lost AM and FM
Well, if your unit had that happen, it sounds like it is possible. ;)
I would imagine that the radio, like all the other inputs, is in itself a separate unit or circuit board. If something fails on it, it probably wouldn't harm other inputs or the actual amplification itself... just a guess on my but it makes sense. A repair shop could probably open up the case and visually inspect the tuner circuits to make sure there isn't a short or dead something somewhere.
If there is still sound in Jim's case, I would try a different antenna and/or make sure its hooked into the correct antenna hookup. if sound but antenna change doesnt help, it could still be an internal but maybe simply problem.
i'm no pro but that's my 2cents
Oct 29, 2007 | Teac AG-V8060 Receiver
Teac PD-H300 CD Player Logo
222 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
