Question about Hitachi 50VF820 Projection TV
TV doesn't come on right away it cycles for as much as 10 minutes before it finally comes on.
  • churchbebo Oct 12, 2010
    Where are the capicators located, how many are there, can I remove and replace them myself? Can you supply a diagram? I have the back of the tv off and have access to the components.
  • Hitachi Master
  • 11,800 Answers
The electrolytic capacitors have aged and there is a much bigger current passing thru them , overstressing the power source an triggering the protection system which shuts the tv off , which cuts the current thru the capacitors, which makes the protection system inactive, which allows the power source to start again a new power - shutdown cycle.
Only when the capacitors heat up from all that current that has passed thru then their internal resistance approaches the normal level so the current drops to tolerable levels allowing the power source to remain on.
Replace all capacitors immediately , or one will fail for good and fry a lot more.
Posted on Oct 12, 2010
  • Azrael SRL Oct 12, 2010
    The capacitors are all over your tv, they are soldered in and they must be replaced with identical ones. If you don't even know what a capacitor is then definitely you can't fix it - take the tv to a repair shop and let them do it. To replace them it will cost you $50 for all the capacitors and the price for 3 hours of labor so go to the cheapest one you can find.
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
What does beeping mean during dry cycle?
My dryer did the same thing, it was so distrubing noise in the middle of drying cycles, so I turned off the sound switch it went away, now it doesn’t peep any more.
Oct 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Sounds works, image doesn't come on for several minutes
Send your tv back for professional repairs as this is the first sign of failing LED's somewhere in your tv. I hope this helps
Aug 25, 2012 | LG Televison & Video
Samsung DLP turns on and off - cycle repeats
make sure put the lamp door back before trying to turn it on because they have switches on them that allow the tv to turn on. If that is ok you probably have a bad ballast.
Call a local tv repair shop to further diagnose the problem.
Dec 10, 2009 | Samsung DLP HL-P5663W 56" TV
My tv takes like ten minutes untill it's turning on,why?
Replace any swollen capacitors in power supply.
Apr 24, 2009 | Televison & Video
TV switches off after 3 minutes
You have a bad Fan,if fan stops turning on while tv is trying to come on lamp will not light and tv turns off.
Nov 24, 2008 | LG RU-52SZ51D 52" Rear Projection...
White dots/green lines
The problem could be in vertical blanking or video processor circuit. Also redish vertical lines may be from external RF or magnetic interference. Move set to new location away from appliances and speakers
Apr 21, 2008 | Sony KP-53V85 53" Rear Projection...
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Color comes in and out
could be loose connection bad solder or crack,on the main board ,is hard to tell with out open it, you need to have a little experience to do that, 60 to 80 dls depends on the tech who works on it , in shop 125
Jun 10, 2007 | JVC AV-32F475 32" TV
Hitachi 50VF820 Projection TV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
