Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
My Sony tv turns itself off after a few seconds. the standby light flashes 7 times then stops then flashes 7 times repeatedly. should I take the tv in to a repair shop, call someone over to fix it, or is it something that I might be able to solve myself? I dont have much knowledge on tvs
SOURCE: sony kf-50XBR800 tv turns itself on and off
I just purchased a replacement lamp off ebay and the TV is working fine now. Color looks better too (which I guess I should have expected). Search for "REPLACEMENT LAMP SONY XL-2100U" on eBay and look for seller "niosales". I paid $129 out the door. Their are other auctions for this lamp you can check out. Make sure you look at lamps that include the entire lamp housing, not just the bulb.
Posted on Mar 14, 2008
  • 4234 Answers
SOURCE: Sony KV-30HS420 turns off all by itself
6 blinks is a horizontal sweep problem (I think). If the problem did not show up at the shop, I'd suspect bad connections that the move "corrected" for the short term. If you can solder, resolder any joints that appear grainy or have rings. Pay particular attention to the area close to the flyback transformer (part with large red wire coming out the top). Report back here with your results.
Dan
Posted on Apr 08, 2008
  • 9 Answers
SOURCE: RE: Flashing "Standby" light
Go here http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=4
for my post #108 for a step-by-step solution with pictures. $21.83 is all it cost me. I fixed my own TV as many others on that forum have. Feel free to contact me at eclipsedave@yahoo.com if you run into difficulties.
-Dave
Posted on May 12, 2008
ikecur
  • 52 Answers
SOURCE: Sony trinitron KV-27FS100
probably, you have to call for a technician to check for it, the switch of the tv might have some dis alignment of cables
Posted on Oct 30, 2008
mistersony
  • 320 Answers
SOURCE: Flashing Standby Light (6 times every 2 second interval)
A 6 flash error indicates a problem with the backlight. Your set is less than a year old and still in warranty, so you should contact Sony and arrange for a service call to get it repaired.
Posted on Nov 10, 2008
Problem with Sony Grand Wega TV
This could be due to bad capacitors in the sweep supply, a bad High Voltage block, a bad regulator.
Jul 06, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
The tv repeatedly turns on then off
First area to check out is the power supply of the set.
Jun 14, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Sep 30, 2009 | Sony Televison & Video
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Sony sxrd --cuts off after a few seconds then cut itself back on.
Symptom shows lamp is weak and requires replacement.
Please buy Sony original lamp for TV safety and good picture result.
May 31, 2009 | Sony Televison & Video
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Wega KP-FW46 - Standby Flashing 10 Times
Remotes can be ordered from various websites, I would check ebay, sony, those type of websites. The standby light flashing means your bulb on the TV needs to be replaced.
Good luck.
Mar 31, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
487 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
