Question about Samsung Refrigerators
Hi i have a samsung refrigerator model sr41ema. problum is after defrost friedze could not restart. when i do main switch off than on after 10 sec. than it start...i call the sevice engineer he changed both sensors ref. & freezer but same problum again.......pl. tell what is the problum & where do i go.............sarvjeet babbar 9953466664
  • 159 Answers
SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Posted on Aug 10, 2007
  • 1314 Answers
SOURCE: Kitchenaid Side by side refrigerator/freezer
when is the last time you cleaned the condenser coils the areas you describe are supposed to be hot there is a loop there to keep the door gaskets dry but should not be too hot pull the fridge out check to see if the fan is running on the compressor then unplug the unit and clean the coils the only other thin that will make it super hot if there is a leak in the low side of the system and has drawn air in see if cleaning the coils fixes it first and we will go from there
Posted on Feb 13, 2008
aborcass
  • 2651 Answers
SOURCE: Freezer/refrigerator compressor running constantly
th ebi-metal is a thermostat which shuts the defrost heater on/off, but doesnt actually put the unit into defrost. if it were bad the defrost heater would never go on resulting in massive build up of ice on back wall of freezer, and noticable refrigeration sect. cooling.. dont know how you know the compressor never shuts down, but if that the case perhaps you have a sealed system/ freon issue. try removing the back panel of freezer section and check the evaporator coil. you shuld have an even frost pattern over the entire evap coil. if theres just frost over the top 1or 2 coils, and the rest of coil is shiny aluminum , thats an indication of a sealed system issue.( 5 year part warr by manufacture) def not a do it yourself issue...but that would,, depending on extent of restriction/loss of freon,, cause freezer to freeze and defrost eratically,and the compressor would be running constantly trying to achieve a good stable temp
Posted on Apr 02, 2008
  • 184 Answers
SOURCE: GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
Posted on Apr 10, 2008
22yooper
  • 828 Answers
SOURCE: Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Posted on Jun 01, 2008
How to access service Menu on Samsung Refrigerator 26Cf French model RF261 BEAE
look on the internet for a service manual from samsung and goo from there maybe it wants a new memory card fitted
Oct 31, 2014 | Samsung RF261BEAEBC 25.6 Cu. Ft French...
I have whirlpool double door refrigerator model ies magic ff-350 elait thi problum is friz is warkig but aftar sum 10 11 haurs friz is off in hi ampar plz ask my solusan
Can you post a better model number? Example=> GC5SHGXKB00
Is there any way you can find the correct model number? Without your model number I am guessing that your refrigerator has a defective fan motor or a defective motherboard. It also could be a defective defrost timer or a adaptive defrost board problem. Thanks John Tripp/Sea Breeze
1_25_2013_9_07_56_am.jpg User manuals parts manuals
Jan 25, 2013 | Whirlpool Refrigerators
Where is the hotpoint HSS251FMD WW defrost timer located?
Hi, I think Your model number is HSS25IFMDCC . There is no defrost timer on your refrigerator, main relay board controls defrost cycles in this fridge. main board p/n WR55X10942 But I suggest to check on heater and defrost switch first - more common problem on this refrigerators. here is my video. hope it helps.
Aug 24, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
My two door fridge freezer works well untill it goes through a defrost then it wont start back up i have replaced the sensors both defrost and room in the freezer and it still does the same thing what...
Then it is the main control or the defrost control board...
Iwould look up the part for you but the model number given here comes up as an oven..
heatman101
Aug 07, 2010 | Samsung RF265AA Bottom Freezer French Door...
My frigidaire refrigerator does not cool? what should i buy for it
Good day.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condensor
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
Thank you for using FixYa
Jan 17, 2010 | Refrigerators
SAMSUNG REFRIGERATOR MODEL SR-368 freezes and no cooling.
Hi!!! You have a defrost problem.You need to change the defrost timer mechanism.In Samsung frig the defrost timer is in the main pc board..Good luck..
Jan 05, 2009 | Samsung Refrigerators
Bosch f/freezer KGV3128
This is a quote from the John Lewis Freezers Buying Guide which basically says keep your freezer in the house where it is warm, otherwise it won't work :)
http://www.johnlewis.com/Magazine/Feature.aspx?Id=39
Manufacturers do not recommend you keep a freezer in the garage or any other outbuilding, as it may have to use much more energy. Most models require a minimum ambient temperature of 10°C (50°F) to operate efficiently. If the outside temperature is any lower, the freezer will struggle to keep your food chilled – it may even start to defrost. If it does break down, the appliance may not be covered by the guarantee.
Aug 31, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Samsung fridge freezer model number srs615dp. The temperature displays -16 and 3 degrees. After approx 10 hours the display flashes. Turn off the power and on again and it displays 4 and 14 degrees and...
Hi just wondering if you figured out the problem with your Samsung fridge yet.
It is definately a problem with the defrost part of the fridge. After approximately 4 to 10 hours dependent on many different factors it enters into defrost mode to get rid of any excess ice in both the fridge and the freezer. During the defrost stage the compressor will not run. If any fault occurs during the defrost stage the fridge will not restart unless you turn it off and back on again which restes the pcb and takes it out of defrost mode and the timer starts again.
Please let me know how you went with it.
Jul 04, 2008 | Frigidaire FRT18B4A Top Freezer...
Samsung RS22NJSH Freezer Fault
hi there the fault you have is very common these units do automaticaly defrost to clear ice from the evaporator the problem that they have is when the defrost heater comes on it overheats and blows the safety thermal fuse resulting in the evaporator getting more and more iced up, to cure the fault you will need to replace the thermal fuse which has now been modified and the defrost sensor.
hope this is of some help
Dec 12, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
103 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
