Lennox HPXB15-036-230-01 heat pump owners manual
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Lennox HP13-036-230-01 heat pump with
Being that you had the same problem before I would guess that it is not the filter or TXV that is the problem...
You may have another restriction in the system...
Did it work in heat mode???
Do you have adequate air flow???
Is the coil and filter clean??
Did you try to purge nitrogen through the piping when you changed the TXV???
This really sounds like an air flow problem more then anything else...
heatman101
Posted on May 31, 2011
  • 5 Answers
SOURCE: RTH3100C thermostat for an older Lennox heat pump
well the wire on x will go to e thr r is the red wire goes to r the wire on f willgo to g the y will go to y now the rest you'll have to verfy at air handler o will go to reversing valve common wire will go to c the electric heat will go to aux
Posted on Feb 06, 2014
I am looking for a thermostat manual for a lennox central heating its an older unit thanks in advance
There's 100s of Lennox units and 1000s of tstats. What are the model numbers
May 05, 2017 | Heating & Cooling
My lennox heat pump frequently shows df and cold air pumps out for about 5 minutes then restarts. what is causing this?
Its getting too cold outside for the heatpump to operate. It must defrost the coil. You should have backup electric heat inside your airhandler, possibly not setup or possibly not even there. On your tstat in settings or set up look for heat pump with back up electric heat
Dec 11, 2016 | Heating & Cooling
Is there some way to get the owner manual for the Lennox pro series LN7
lennox support page:
Easy access to Lennox product documents
LN7 didnt pull any results so you might want to double check the model #
Jun 08, 2015 | Pool & Spa
Lennox elite heat pump throws cold air
The unit should give you an error code if something is wrong.
Here's the manual:
http://instalacionesindustriales.com.gt/pdf/Lennox_Minisplit_HE.pdf
Mar 25, 2014 | Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat...
Feb 06, 2014 | Honeywell RTH3100C - Digital Heat Pump...
My Lennox MS7 heat pump was installed about a year ago and hasn't had any problems until last week. It has started changing settings (like on or off, higher temperature, light on or off) without prompting...
Go to the unit locate the control module. Take wires to thermostat out. Now jump from R to Y your AC should come on. Jump R to W your heat should come on. Jump R to G your blower should come. If you have done these and it stay on or run as it should then you need a new THERMOSTAT.
Oct 26, 2013 | Lennox 7 Series MS7-HO-30P MS7-HI-30P Heat...
Lennox codes
e5: open or short circut of outdoor yemp. sensor or outdoor unit.
see more Air Conditioning Fault Codes
May 11, 2013 | Lennox 7 Series MS7-HO-09P MS7-HI-09P Heat...
Owners manual lennox G12RD2-82-3
You might be able to obtain a manual directly from Lennox
Jan 24, 2013 | Heating & Cooling
I have a lennox 2 stage gas furnace and a lennox XP15 heat pump controlled through the Lennox 7000 touchscreen thermostat. I want to disable the heat pump due to excessive noise due to lower temperature...
At tstat press options. Press installer setup. Yes, you are qualified. System settings, non heat pump. Gas/ oil heat. Save changes. That should do it with no wiring changes.
Jun 18, 2017 | Heating & Cooling
Why would my heat pump central air blow cold then warm
Sounds to me like you have wiring issues. Need to make sure all your connections are tight, wires are clean and free of bare spots (possibly from rodents chewing them)and your settings on your tstat are correct. Heat pump with back up electric heat.
Jun 09, 2017 | Heating & Cooling
Heating & Cooling Logo
284 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
