Question about Poulan "" Push Mower
I have a Mountfield bvs153 petrol mower. The
I have a Mountfield bvs153 petrol mower. The problem is, that the mower stars ok, works for approx 10mins, then cuts out nd will not fire up again.
  • Anonymous Mar 29, 2014
    What Oil should I use?
  • 755 Answers
It fails after it has 10 minutes to warm up right?
I think you should run it till it fails and then test it for spark.
My guess is that your coil is going bad and heat just triggers the failure. After a while even cooling down wont help.
The good news. If you need to replace the coil its a pretty simple job that can be done with a few hand tools and a new coil. It shouldnt be too expensive either. 25-35 dollars for a new one if your shop around online or go to Ebay.
The only thing special you need to do once you have removed the recoil cover and removed the old coil is to take a piece of thin cardboard *(I actually recommend the box the coils usually come in. But a playing or business card will do) Put this paper between the coil and the flywheel to set the coil gap. Tighten on the screws and then pull out the paper. Put the recoil cover back on and you are done!
Good luck and be careful.
Posted on Oct 12, 2010
Why does my Mountfield Petrol powered lawn mower cut off instead of idling while I empty grass cuttings?
what engine does it have, how old is it and does in not have a bar you have to hold in to start/stop the engine?
Mar 07, 2015 | Garden
Dear Sir, I have an Mountfield m4 major petrol lawn mower some 20 years old. It starts O.K. but the engine will stop after a few minutes.By turning the choke on just before the engine stalls, will keep it...
sounds like the needle valve Seat is slightly clogged and the gas entering the Carburetor cannot keep up with the Draw from the engine.
Oct 05, 2013 | Garden
Mountfield Mower is chugging.
Excess air. Remove clean or replace air filter.
Jul 12, 2013 | Garden
My mountfield hp164 petrol mower starts but wont run smoothly even when the engine is warm it is constantly idling erratically
Check sparkplug ie remove and clean. Set gap normally 1mm. Check s/p lead has firm connection. Check manual for correct fuel requirements. Other wise take it to the mower repair shop. It's not worth your time to muck around with it. Too frustrating!
Apr 17, 2013 | Garden
1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Jul 17, 2011 | Garden
I am looking for a Mountfield HP 470 Lawnmower instruction manual
I have a Mountfield HP 470 Petrol Mower 8 years old and I have started it the for the first time and it runs but seems to be hunting or missing as I cut the lawn.
Mar 24, 2011 | Garden
MOUNTFIELD PETROL MOWER WONT RUN
If there is a float bowl on this model, takeoff the center screw and look for a little pilot hole on the side and take a small pin or the like and clean this pilot hole and try again to start. Good Luck Pal.
Jun 04, 2010 | Mtd 22" Yard Machine Push Mower
Running problems with Mountfield HP454 petrol lawnmower
First thing to check is the air filter. It may be plugged.
May 28, 2010 | Mtd 22" Yard Machine Push Mower
My Mountfield Petrol mower cuts out after 5 or ten seconds. The fuel tank is full
Remove fuel car and re-test. If no problem, the vent hole in the cap is blocked. Need more info about engine type to help further.
Mar 08, 2010 | Garden
Poulan "" Push Mower Logo
799 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
