Question about Haier Washing Machines
My Haier HNS1460TVE washing machine is set on delay for too long and i dont know how to cancel the delay so it goes straight to the wash. any ideas??
  • 11,896 Answers
One simple solution would be to use an alarm clock. you would remove the alarm speaker, and connect the speaker contacts to a push solenoid (you'll have to check the voltage coming out of the clock to see if it can drive a solenoid, if it can't you'll have to probably use a relay in between). when the alarm goes off it would actuate the solenoid which would press the button, then the alarm would stop and release the solenoid. the biggest issue i can see with this is that the pulsing signal of the alarm might not stay "on" long enough to actuate the solenoid. so if you can find an alarm that's got a steady sound instead of a "beep beep beep" it would probably work better.
you could also go analog and get an old style alarm clock (with the bells and what not) and remove the bells, and attach a "stick" or rod to the hammer that strikes the bells. when the alarm goes off the hammer would swing the stick into the power button.
or you could open up the washing machine and bypass the push switch and make your own switch that's easier to actuate
Posted on Oct 12, 2010
HNS1460TVE Manual
You may download a copy of the manual at http://image.haier.com/manual/Laundry/wm/201108/P020110822633253533223.pdf. The second half is in English.
Aug 08, 2013 | Haier Washing Machines
Delay timer is flashing and locked ini that position
did you select delay wash.... it sometimes happen by accident try delay time button to stop delay wash the hit cancel....
Jan 31, 2011 | Kenmore HE3T Washer
The delay start light on my washer is on and I do not want to delay start. I have pushed the cancel button twice like instructions say and once I hit start, the delay start light is on and machine is...
First I made sure the detergent dispenser door was closed. That did not work. Then i made sure that the dispenser was clean, by running water thru it. That did not work,. Then I turned the dial to hand wash and pushed the start button. That worked. Delay light did not turn on. Then i turned the setting to the proper wash cycle and pushed the start button. Clothes are being washed now.
Nov 23, 2010 | Frigidaire FTF2140FS Front Load Washer /...
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
Front load whirlpool washer wont drain. (ghw9150pw0) I cleaned the trap, ran the spin and drain cycle. It gave me the suds message, but then the load drained fine. I then ran an empty cycle hoping to...
I don't know if this will help you, but we have a Haier HNS1460TVE and this is apparently made by Whirlpool ... we have a similar problem in that if the load is not full it will not spin, it stops at 9 minutes and just gets stuck !!!
We have found that emptying the machine & turning it off and on, with the door shut, resets the machine ... hope that helps you !!
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a haier hns1460tve washing machine that is stuck on a spin cycle, no pipes blocked it turns but does not spin and is stuck on nine minutes. can you help me please
I doubt this is if much use to you 3 months down the line, but if anybody else has this problem, we have found that emptying the machine resets it.
Not impressed with this machin at all, though, and the Haier web site is a waste of (cyber) space !!!
Anyway, I hope this helps anybody else who gets this same problem ...
Feb 21, 2010 | Haier Washing Machines
Haier washer the water goes in and goes straight out through the drum into waste pipe
There is an exit hose behind the machine. This hose should be approx 3 feet above ground level, you may find a water mark behind the machine; then it goes down into the sink or standpipe in the wall. This hose holds the water, your pump pumps it over the height as & when required; the hose is never let loose at floor level.
Feb 22, 2009 | Haier HWD1000
I need to cancel a washing cycle in the middle of the cycle.
usually pressing PAUSE/CANCEL twice cancels the cycle and shuts it off allowing you to then re-start the cycle. If not try unplugging it and see if it resets to allow you to start cycle again.
Dec 07, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
121 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
