Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
I have a 5 year old x500. It turns on, hums for about 10 seconds and then cuts off. The pump is not working. The control panel lights up, but the jets will not come on and the pump does not run.
  • 990 Answers
This is probably a bearing problem with your motor. On a above ground spa five years is a long life.
You should be able to find two main valves to shut and stop water from draining. Then open the unions on the suction and discharge of the pump. It will probably be bolted down. If you can bend your arm ten ways getting these bolts off will be no problem. If you can't swear a lot. These are for shipping so you don't need to replace them all. Remove the pump and pull the wires or unplug from main box. You can take this to a pool shop or a motor shop and get a new one. They will do all the work cheap or for nothing and just charge for the motor and parts. When you remove the unions on the pump don't loose the "O" rings, often they can be tough to find to replace.
Posted on Oct 14, 2010
I have a Speck Pump, model E71, only a year old. It suddenly stopped working - it was fine at the start of the season. The problem is that it just hums when turned on.
Since it hums it has power. I believe there is a start capacitor on it, that or the start switch may have failed.
Speck Pumps Pool Pump Parts
usa speck pumps com
have Speck Pump model E71 only year old It suddenly stopped working it was...
Speck Pumps Pool Products Inc
Jul 02, 2016 | Speck Pumps Pool & Spa
My Pentair pump is just 2 years old and it was working good yesterday I turned off I turned it on in now it humms for a minute or 2 then it just turns off completely how do I fix this
motors that hum indicate 2 things
seized pump or failed start /run capacitor
as it was running recently I would be checking the capacitor
the stopping altogether may be the thermal overload switch cutting in because of the high current draw from the failed capacitor
Jun 05, 2016 | Pentair 2.0 Hp Whisperflo Pump
Powers off immediately after starting
My immediate reaction would be to cut your losses and buy a new unit as sooner or later you will run into a part that is no longer available.
Nov 03, 2012 | Whirlpool Microwave Ovens
Sitting 5 years now no fuel pressure pump was less than 1 year old when stopped driving. 1990 bonneville sse
Pump is probably stuck. Pound on tank with a rubber hammer or wood bat (no metal) with the key on. Pump should make a humming noise for 1-5 seconds after key is turned to on if working. Next replace the filter.
Feb 28, 2011 | 1990 Pontiac Bonneville
Samsung microwave -the electrical panel runs, the
it sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
Nov 14, 2009 | Samsung MU3250W Microwave Oven
Dishwasher just hums, faintly, when I turn it on.
motor is locked up.. if you let it hum faintly for a couple min it will cut out most likely.. thats the thermal trip built into the motor.. the motor assm needs to be replaced..
Apr 10, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
393 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
