Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Not enough quota is available to process this command. any files not open and the prompt comes again. my windows is not genuine.
5 Suggested Answers
  • 75 Answers
SOURCE: Windows XP... Problem
majorgeeks.com has a good forum for helping get rid of virus. All you need to download is HiJackThis which is a free program install that and post the report shown at their forums and a spyware/antivirus guru will walk you through all you need to do to eradicate the virus from your system.
Posted on Jan 25, 2008
pagebor
  • 2785 Answers
SOURCE: Command Prompt shut down my computer
your pc is infected by viruses please update your anti-viruse then disable system restore and boot in safe mode and do a system scan
Posted on Apr 08, 2008
AZinkey
  • 60 Answers
SOURCE: genuine hide in windows7
press win+r type "msconfig" without qoute startup uncheck wga then go to registry editer find all wga entry & remove it
restart ur pc, then go to search check hidden and system file in more advance option find wga then delet it if you cant delete this then download a little software called unlocker 1.8 its free & try to search on google you find it after delete wga.exe or wgasetup.exe restart pc now you happy
Posted on Aug 11, 2009
bronk50
  • 27725 Answers
SOURCE: bypass windows password
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard.
Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in
Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Reboot the computer into Safe Mode
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears.
Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system.
Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
In User Accounts select the account you wish to change the password for, click change password and then enter the new password or click remove the password to remove the password from the account.
If all else fails you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard
Many RTC's require an external battery. If your RTC is one of this type you can clear the BIOS password just by unsocketing the RTC and reseating it
Hope it helps
Posted on Jun 26, 2012
How to Remove Shortcut Virus on Windows?
Connect the affected USB drive to your computer. When the files on your USB drive have been changed to shortcuts, your files are actually still there in a hidden location. This process will restore the files so that you can see them again.
  • Do not run any of the shortcuts on the USB drive, or you risk spreading the infection.
Determine the drive letter of the USB drive. You'll need to know the drive letter for the USB drive or memory card that has been affected by the virus. The quickest way to find this is to open the "Computer"/"This PC" window. The drive letter for the USB drive will be listed next to the drive label.
  • Press Win+E to open the window on any version of Windows.
  • Click the Folder button in your taskbar to open the window.
  • Click "Computer" in the Start menu if you're using Windows 7 or Vista.
Open the Command Prompt. You'll be performing the fix using a few quick Command Prompt commands. The process for opening the Command Prompt varies depending on the version of Windows you are using:
  • Any version - Press Win+R and type "cmd" to launch the Command Prompt.
  • Windows 8 and newer - Right-click the Windows button and select "Command Prompt."
  • Windows 7 and older - Open the Start menu and select "Command Prompt."
Type .attrib -h -r -s /s /d X:\*.*and press? Enter. Replace Xwith your USB drive's letter. For example, if your USB drive's letter is E, typeattrib -h -r -s /s /d E:\*.* and press ? Enter.[1]
  • This will unhide the files, remove any read-only attributes, and remove the shortcuts.
  • The process may take a while to complete, depending on how much data is on the USB drive.
Open the unnamed folder created on your USB drive. This folder will contain all of the data that was previously hidden by the infection.
26319209-bxzhjmonsmllydp0qa2riq2g-2-20.jpg Copy the recovered data to a safe location on your computer. This is a temporary location while you finish cleaning the drive. You can create a folder on your desktop to hold the files for now. Just drag the files from your USB drive to whichever folder you choose.
  • It may take a while to copy large amounts of data.
Right-click on your drive in "Computer"/"This PC" and select "Format." This will open the Format window.
  • The formatting process will completely erase the drive, so make sure that you've copied your data off of it first.
Uncheck "Quick Format" and click "Start." Unchecking "Quick Format" will scan for and remove the infection on the USB drive. The format process will likely take a while to complete. 26319209-bxzhjmonsmllydp0qa2riq2g-2-44.jpg
Oct 20, 2016 | Microsoft Computers & Internet
Tip
Delete An "undeletable" File!
<p><b><u><span>Delete An "undeletable" File</SPAN></U></B><br> <p><b><span> </SPAN></B><br> <p><span>Open a Command Prompt window and leave it open.</SPAN><br> <p><span>Close all open programs.</SPAN><br> <p><span>Click Start, Run and enter TASKMGR.EXE</SPAN><br> <p><span>Go to the Processes tab and End Process on Explorer.exe.</SPAN><br> <p><span>Leave Task Manager open.</SPAN><br> <p><span>Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.</SPAN><br> <p><span>At the command prompt type DEL &lt;filename&gt; where &lt;filename&gt; is the file you wish to delete.</SPAN><br> <p><span>Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.</SPAN><br> <p><span>Close Task Manager.</SPAN><br> <p><span>Or you can try this</SPAN><br> <p><span>Open Notepad.exe</SPAN><br> <p><span>Click File&gt;Save As..&gt;</SPAN><br> <p><span>locate the folder where ur undeletable file is</SPAN><br> <p><span>Choose 'All files' from the file type box</SPAN><br> <p><span>click once on the file u wanna delete so its name appears in the 'filename' box</SPAN><br> <p><span>put a " at the start and end of the filename</SPAN><br> <p><span>(the filename should have the extension of the undeletable file so it will overwrite it)</SPAN><br> <p><span>click save,</SPAN><br> <p><span>It should ask u to overwrite the existing file, choose yes and u can delete it as normal</SPAN><br> <p><span>Here's a manual way of doing it. I'll take this off once you put into your first post zain.</SPAN><br> <p><span>1. Start</SPAN><br> <p><span>2. Run</SPAN><br> <p><span>3. Type: command</SPAN><br> <p><span>4. To move into a directory type: cd c:\*** (The stars stand for your folder)</SPAN><br> <p><span>5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:\progra~1\kazaal~1</SPAN><br> <p><span>6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.</SPAN><br> <p><SPAN style="FONT-FAMILY: 'Tahoma','sans-serif'; FONT-SIZE: 10pt
on Dec 10, 2010 | Computers & Internet
I need to restore my computer without disc, what should I write in command prompt?
To access the System Restore Gui from command prompt you will need to type in rstrui.exe
OR
%Windir%\System32\rstrui.exe
Other Thoughts
If you are experiencing Boot issues you will need to install a boot manager. If your system is missing a file or a file is broken, you may need to replace that file with a working version that's compatible with your OS Version.
Aug 07, 2015 | Dell OptiPlex GX270 PC Desktop
Windows not genuine notification
Windows 7 not genuine notification using command propt How to make Windows 7 genuine using Command Prompt
Press Windows key + R
Now "run" box will appear , in "run" box type CMD
Click on OK
Note : Run CMD as Administrator
Now command prompt will appear
In command prompt type SLMGR -REARM
Hit Enter.
Wait 5-10 seconds
Now a message will appear as shown in image below.
Done !!!
Now your Windows 7 is genuine .. :D
Restart your PC once. Hereafter you won't see the warning message that "Windows 7 is not genuine"
Apr 05, 2014 | Microsoft Windows 7 Ultimate 32 bit Full...
Not enough virtual memory
Step 1:
Virtual memory is a portion of your hard drive that Windows sets aside to utilize as memory. When your RAM is over utilized, the operating system can swap pages of data to the hard drive to make more room. Swapping files, or paging, is slow, but it allows your computer to remain functional when your memory space is full. If your virtual memory space, or page file, fills up as well, you'll get an error. Fixing this issue is quick and the process is identical in safe mode or in a typical boot situation.
Change Virtual Memory Settings in Windows XP Click "Start" from the Windows desktop. Right-click "My Computer" and click "Properties." Select the "Advanced" tab and under Performance click "Settings." Select the "Advanced" tab and click "Change" under Virtual Memory. Click "System managed " to allow Windows to automatically adjust your Virtual Memory as needed. Click "Custom " to alter the memory space to your own specifications. Enter a value in MB equal to at least 1.5 times the of your computer's memory for the initial . Enter a value in MB no larger than four times your memory for maximum . Click "OK" and restart your computer for the changes to take effect.
Feb 13, 2013 | Microsoft Windows XP Professional
My computer prompt me that my OS is ingenuine, what should i do?
If your computer shows that the os is not genuine, that means the os is a victim of software counterfeit. You can check it by right clicking on My Computer - Properties. Check Windows Activation option, if it says windows is not activated, then truly the os is not genuine. In that case you need to contact with your os vendor, or you can report Microsoft, about it - http://windows.microsoft.com/en-US/windows/genuine.
May 06, 2011 | Microsoft Windows XP Professional for PC
A message appearing"you may be
Windows Genuine Advantage Notifications for Windows XP notifies you if a copy of Windows XP is not genuine. The notification messages only appear on computers that have failed the WGA validation process and that are running a copy of Windows XP that is not genuine. If you are running a validated, genuine copy of Windows XP, you will not receive notification messages.
Removing WGA Via The Command Line Restart your PC and boot into Safe Mode, usually by pressing F8 whilst your computer boots. Once your PC has booted open a command prompt by clicking Start then Run and typing cmd into the box before clicking OK.
Change directory to your System32 folder with the following command:
cd \windows\system32
Next you're going to need to copy the following lines to the clipboard, in order to paste them into the command prompt quickly. This is necessary to kill the WgaTray.exe process and delete the file before Windows has a chance to launch it again:
taskkill -IM wgatray.exe
del wgatray.exe
del wgalogon.old
If all the commands executed correctly you should have killed and deleted WgaTray.exe as well as WgaLogon.dll. You might also want to have a look for any WGA-related files (WgaTray.exe, WgaLogon.dll, WgaSetup.exe etc...) in \Windows\System32\dllcache and delete them, just in case.
Restart your PC to see if the changes have taken effect, if the WGA notifications are still there then you'll want to continue reading this next bit, otherwise you're done.
Jan 02, 2011 | Microsoft Windows XP Home Edition
How to pass genuine window validation
Please follow this simple troubleshooting procedure, courtesy of MS MVP
Carey Frisch:
1. Download and install the WGA Diagnostic Tool
http://go.microsoft.com/fwlink/?linkid=56062
2. After running the WGA Diagnostic Tool, click on the "Windows" tab and
then click on "Copy to Clipboard".
3. Next, visit the following website and create a post in the "WGA
Validation Problems" forum and paste the results of the WGA Diagnostic Data
in a detailed post:
http://forums.microsoft.com/Genuine/...aspx?SiteID=25
4. A WGA troubleshooting specialist will analyze the data and recommend an
appropriate solution.
In the end you may end up having to buy a genuine copy of Windows XP.
Jul 06, 2010 | Microsoft Windows XP Home Edition
My toshiba A15-S127 has dimed screen and a friend habe reformated 2 times, , it send a message that read missed file or damage system32 foskrnl.exe , if I plug outside monitor it's how i can read the...
  1. Insert the Microsoft Windows XP CD into the computer. Note: If you have a system recovery CD or restore CD (not a Microsoft CD) these steps will likely not work for your computer.
  2. Reboot the computer with the CD and press any key when prompted to press any key to boot from the CD. Once in the Microsoft Setup menu press R to open the recovery console.
  3. Select the operating system you wish to use; if you only have Windows XP on the computer you will only have one prompt.
  4. Once prompted for the password enter the Admin password and press enter.
  5. Once at the command prompt type bootcfg /rebuild to start the rebuild process.
  6. The rebuild process will step you through a number of steps depending upon how many operating systems you have on the computer and how the computer is setup. Below is a listing of the common steps you are likely going to encounter.
    * Prompt for the identified versions of Windows installed. When you receive this prompt press Y if the bootcfg command properly identified each of the Windows operating systems installed on the computer. It is important to realize this command will only detect Windows XP, Windows 2000, and Windows NT installations.
    * Prompt to enter the load identifier. This is the name of the operating system for the boot.ini. For example, Microsoft Windows XP Home users would enter Microsoft Windows XP Home edition.
    * Prompt to Enter OS load options. When this prompt is received type /fastdetect to automatically detect the available options.
  7. Once you have completed all the available options in the rebuild and are back at the prompt type exit to reboot the computer.
Dec 07, 2009 | Toshiba Satellite A215-S7422 Notebook
Free space on my external hdd
If your External HDD file system is configured as FAT32 instead of NTFS, the max file size limit . By using NTFS, you get increased security, file compression, disk quotas, and encryption—features you don't get with FAT.
To convert the default (FAT32 to NTFS):
1.
Close all open programs to avoid loss of data. Be prepared to restart your computer.
2.
Open Command Prompt, and at the command prompt, type convert C: /FS:NTFS, where C represents the drive letter of the disk to convert. Press Enter or Return on the keyboard.
3.
Wait while the process completes. Don't do anything while the conversion is taking place.
You can also open a Command Prompt from the Run line (available from the Start menu). Just type cmd and press Enter.
Other useful links:
http://en.wikipedia.org/wiki/File_Allocation_Table
http://windowsitpro.com/article/articleid/38803/understanding-file-size-limits-on-ntfs-and-fat.html
May 19, 2009 | Western Digital My Book Home Edition 500...
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
232 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
