Question about Pioneer A109 2-Channel Amplifier
My pioneer A-109 amplifier has stopped emitting any sound. power is still being recieved, but no sound from any inputs or sound devices, also no feed back noise. speakers and cables are as should be. any help would be much appreciated.
If there's not even a hiss from the speakers it may be that you've inadvertently hit the small button underneath the power button which turns the speakers off in favour of the headphones.
Posted on Sep 13, 2011
How do you connect a pioneer 3 band tuner model F-X33ZL to a pioneer amplifier A 109
Plug the output of the tuner into any AUX input on the amp.
Charlie
Jan 09, 2011 | Audio Players & Recorders
No sound
What brand of reciever are you using. Most pioneers have a floating signal ground and the shield of the input at the amp needs to be connected to chassi ground. Also if you had a previous amp failure and the power ground in your old amp opened the current to power the amp will flow through the signal ground of the reciever and burn the copper trace on the circuit board in the reciever. test this by connecting signal cable shield to car reciever chassi.
Aug 29, 2009 | Kenwood KAC-8401 Car Audio Amplifier
I have Pioneer Amplifier with Phono Inputs. Also I have an Akai stereo Equalizer. I want to connect my Turntable to the pioneer amplifier through Akai stereo Equalizer to have a better sound quality. Is it...
hook the turntable "directly" up to the "phono" inputs. if it sounds normal this way, and not loud and distorted, then you have to plug the turntable up that way, directly to the reciever's phono input.
you can hook the eq up through the "tape in/out" jacks.
take the tape record out jacks, and hook them up to the input of the eq, and take the tape play input jacks and hook them up to the output of the eq. then, to use toe eq, select whatever input you want eq'ed, while also selecting "tape monitor"
Mar 07, 2009 | Kenwood Audio Players & Recorders
How to hookup to u dvr dish reciever to pioneer surround sound
You will need to run the video cable to the telivision. You will need to take the digital feed from the dvr and run it into the pioneer digital input.
Jan 28, 2009 | Pioneer Dolby Digital 5.1, Pro Logic II...
Denon AVR 886 only shows analog input
Are your speakers able to handle the 886's power. I have the same reciever and changed by speakers as the Denon would turn off instead of frying the speakers.
As for the digital, have you used the option to change your audio feed and video feed. (for example - I'll show photos through the front input but use the CD -digital for music. Maybe the audio feed is locked onto an analog input. Just a suggestion.
Jan 01, 2009 | Denon AVR-886 Receiver
Pioneer gm-5000t amp
If the amplifier is powering, but no sound, try disconnecting the speaker outputs from the amplifier and connecting a test speaker to the output channel. If you get sound, then one of the speakers in the car may be bad or shorted out. That can be confirmed with a voltmeter. If still no sound, then you need to check the input to the amplifier. Disconnecting the RCA cable from the input and testing that with an amplified speaker like you can get from Radio Shack will allow you to make sure that the amp is getting signal from your radio.
Jul 13, 2008 | Pioneer GM-5000T Car Audio Amplifier
Connecting 2 stereo amplifiers using one as a preamp and the other as a booster
I would take from the tape out of the pioneer and feed into the aux input of the marantz you will then have to adjust the volume levels on each amp as required
Oct 28, 2007 | Audio Players & Recorders
There is no sound on my powered sub
Since you have a powered sub, the feed to it is a line level signal. If your unit is only 6 months old, it should still be under warranty. Check. If it is under warranty, have it repaired under warranty. Otherwise, update this and we'll dig deeper.
Dan
Aug 06, 2007 | Pioneer VSX-816-K/S Receiver
Pioneer A109 2-Channel Amplifier Logo
310 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
