Question about Euro-Pro S3325 Handheld Steam Vacuum
Need to replace the dust cup container on my shark model EP602
My Shark Navigator does not have any suction. The roller brush works. What should I do?
Hello, this is Ava with Think Crucial.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it.
If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum.
If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
ou can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark+navigator
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 18, 2016 | Shark Vacuums
Shark navigator lift away turns on but no suction
It seems that there may be something blocking the airway. To fix this, please make sure to unplugged the unit from the power before performing this.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, keep reading for other options to fix the suction.
If both your foam filter and felt filter have not been cleaned in the past month, this may be why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
If none of the other solutions worked, your motor may be bad. You would need to check with Shark about this.
If your need to replace your Shark parts such as filter, belts or hose, you can also order replacement parts directly to us. You can check our online store in this link: http://www.thinkcrucial.com/search?type=product&q=shark
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Oct 17, 2016 | Shark Vacuums
Shark rotator no suction
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark+rotator
Ava B.
Oct 10, 2016 | Shark Vacuums
Where do you get filters for a EP366
TO ORDER REPLACEMENT DUST CUP FILTERS
To order, send check, money order or credit card authorization to:
EURO-PRO Operating LLC
94 Main Mill Street, Door 16
Plattsburgh, NY 12901
or call
EURO-PROCustomer Service at: 1 (800) 798-7398
Monday to Friday 8:30 A.M. -5:00 P.M. Eastern Standard Tim
Please Note:
The Shark Dust Cup Filters are washable.
Importan
Make sure that Dust Cup Filter is completely dry before inserting back in the hand vacuum
http://www.sharkclean.com/manual/EP366_(700_WATTS)_REV_0603A.pdf
Jul 27, 2013 | Euro-Pro Shark EP366 Handheld Vacuum
My Shark vacuum is losing suction. How do I fix that?
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
You can purchase a wide variety of high quality Shark replacement parts for your Shark Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Dec 09, 2011 | Shark Navigator Bagless Upright Vacuum
Shark transformer vac model ep602 will not suction from the floor brush, but will suction from the flexible hose. Dust cup and filters are clean. Do I need to replace the floor brush? Unit was purchased...
Has the floor brush ever worked for you? I thought it was broken at first too. The hose has to be inserted in the appropriate hole in the side of the machine. The hose is where all the suction comes from, when you put it in the side hole it will provide suction for the floor brush.
Oct 11, 2010 | Vacuums
My vacuum (shark modle #UV210BV) turns on but has absolutely no suction.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
You can purchase a wide variety of high-quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Jul 08, 2009 | Euro-Pro Shark Professional Upright Vacuum...
Euro-Pro S3325 Handheld Steam Vacuum Logo
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
