Question about Saeco Incanto Classic Espresso Machine
Incanto deluxe is leaking
My saeco Incanto delixe seems to be leaking from the coffe outflow area. should there be a rubber gaske that seals the coffee flow pipe from the brew group tot he SBS outflow? This is the connection that is made when you close the door after cleaning.
Regards,
Paul
  • 487 Answers
Sometimes the spout in the door is kinda clogged. Take this out ) need phillips head) and clean it . Make sure to turn the knob on it to left and right while cleaning.
There is no gasket but the little plastic pipe goes in there.
Should help.
Check this for parts SAECO
Posted on Jun 02, 2008
Saeco incanto deluxe frother leaking and wont pull shot because water comes out of frother tube during shot disbursement
Dear Jon,
Hi this shrikant from mumbai.This problem is happen due to dust stuck in tea/hot water valve ( for steam which you rotate).
If you have screw driver set then open the machine by using + screw drive. step below,
1.I here attach picture of valve.
2.you have to open it and clean it ( sea in pic 44,46,47,54).
3.after water leaking stop you have replace one o-ring 54 no. in picture.
4.After you machine work fine.
regards,
Shrikant Shinde
Yogishri Engineering
+91-8425830001
Jan 28, 2015 | Saeco INCANTO DELUXE Espresso Machine
I have saeco incanto coffe machine and when I have turned on the machine message appears Ventilate.
hi,probably your machine is need decalcify. Try to turn on the hot water knob when you start the machine. Fill about 1 water glas with hot water from machine.If the ventilate is still appear-you must decalcifying machine with special liquid for descaling.
Jan 04, 2015 | Saeco INCANTO DELUXE Espresso Machine
Grinder grinds coffee, but does not make coffe and dumps dry grounfds
Hi your brew unit is blocked. Open the service door and remove the brew unit and wash and rinse under water. Hot is better. The spout on the back side of the brew unit canbe unscrewed and cleaned. This is where most blockages are, Dazza REPAIRER
Sep 25, 2011 | Saeco INCANTO DELUXE Espresso Machine
Our Saeco Incanto Deluxe keeps saying "fill water tank" on the lcd screen but the tank is full. I remove the tank and put it back on then it leaks in the area of the hole where the tank sit in. ...
Does not sound like the seal. A bad seal would leak outside the machine.
The cause usually is the magnet in the water tank. Make sure that the magnet is floating when the tank has water in it. Click here to see what it looks like.
Hope this helps.
May 23, 2011 | Saeco Incanto Classic Espresso Machine
My Saeco Vienna Deluxe started to leak water underneath and the grinder will only grind coarse and not fine for good espresso, should I ditch this one or repair? I know Saeco is not good at customer...
hi i hope i can help you ? may i please ask you are you over filling? if not open the machine up and go straight to where the water is coming out check for a broken seal if the seal is ok check for any little hair line cracks
May 07, 2009 | Saeco Incanto Classic Espresso Machine
Descaling a Saeco InCanto deluxe
Press and hold the descale button(lower right), it will light up.Then you can start the process. The machine will prompt the next step when the solution in the tank is used up. Have a go.
Apr 04, 2009 | Saeco INCANTO DELUXE Espresso Machine
Out of 10 cups of coffe maybe i get 4 cups
Try to make a cup of water (the) and see if you can make a full cup.
Try to take out the brewing unit (central unit) and wash it in warm water.
/Best regards
/Mirran
Jan 29, 2009 | Saeco Incanto Classic Espresso Machine
Algae in water tank?
Try to clean it with soap, if you are careful you can bend in the edge and take it off.
Use some glue on it when you put it back.
/Mirran
Aug 22, 2008 | Saeco Incanto Classic Espresso Machine
Saeco incanto rapid steam Model #SUP 021yr
Try to clean the brewing unit and make sure the filters is clean.
/Mirran
Aug 21, 2008 | Saeco Incanto Classic Espresso Machine
Leaky Incanto
Jason if the leaking is coming from the coffe flow...check the rubber gasked located on the front top of the brewing assembly.
May 04, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
301 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
