Question about NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive
HARD DRIVE ENCLOSURE RECOGNITION BY MY PC PROBLEM
MY Nexxtech 3.5" Hard Drive Enclosure (NHDE35) IS NOT BEING RECOGNIZED BY MY PC. WHEN I PLUG IN THE USB2 WIRE INTO USB2 PORT I GET MESSAGE THAT READS: "YOUR UNKNOWN DEVICE CAN PREFORM FASTER IF IT IS PLUGGED INTO A HIGH SPEED PORT." I AN USUNG A NEW PC WITH WINDOW VISTA HOME EDITION. SEEMS I CAN'T GET PC TORECOGNIZE IT REGARDLESS OF WHAT USB2 PORT I USE. CAN ANYONE HELP?
  • 2 more comments
  • AGALSGUY Jun 02, 2008
    i am using a hard drive enclosure. It is made with a 2.0 port and cable. Therefore, it's evidently Vista that is the problem. Need Vista drivers from the OEM of the hard drive enclosure, unless one of you tekkies know where I can find the drivers!
    thank you
  • mlspar4 Jul 30, 2008
    I have the same problem. I have XP, and it was set to master.
  • Anonymous Sep 04, 2008
    Vista will not recognize drive
  • Randy
    Randy Feb 25, 2009
    I also had a problem with XP not recognizing the hard drive. The USB Mass Storage Device was reporting a Code 10 (Device cannot start). Ryockey provided the solution in that the drive pins can be offset by one set when connected to the interface. Be careful to get the pins aligned correctly, it worked for me. I also have my drive jumper set for Master. Thanks Robert!
    Randy
Had the same problem today. I finally noticed that the pin bay on the enclosure was large enough to allow the pins to be offset by one pin set. The open pins were hidden by wires. Once I carefully aligned the pins, everything worked fine.
Robert
Posted on Aug 30, 2008
    Problem Solver:
  • 8 Answers
Try setting the HD jumper (in the Nexxtech enclosure) to "master"...it worked for me!!!
Posted on Jul 22, 2008
    Champion:
  • 208 Answers
You have an old pc with no usb 2.0 u have 1.1 get a pci usb2.0 card if that bothers you.
Posted on Jun 01, 2008
  • Arnold G
    Arnold G Aug 01, 2008
    also diskmgmt.msc will get your drive listed..
    create partition then format it.
My Nexxtech nhde35 ext. hard drive is suddenly not working. Now when I plug it in, the indicator light alternately blinks red/blue. The PC does not see the drive at all. Tried swapping to another hard...
Seems most likely that the drive enclosure has failed, since swapping to a different HD made no difference. If so enclosure will have to be repaired, or replaced.
Jan 03, 2011 | NexxTech Portable Hi-Speed USB 2.0 Kit...
I've inserted PC/system hard drive into enclosure and connected by USB port to my stand-alone computer . . .How do I recognize or where do I find the menu to allow me to access the attachment/enclosure...
You do not have to do anything out of the ordinary for it to recognise. Connect the USB cable to the PC. If the hard drive is above 250Gb in capacity, connect the external power supply to it. Turn on any switc/buttons in the casing. Your PC should detect it as a Mass Storage device or as a regular hard disk.
Nov 22, 2009 | NexxTech 2.5" Hard Drive Enclosure
No install CD for NexxTech NHDE35
Apple MacOS 9, Apple MacOS X, Microsoft Windows 98SE/2000/ME/XP will support these If your using Vista It wont work, and no upload is available.
Apr 21, 2009 | Computers & Internet
NHDE35 Enclosure
Posted by Decoder1 on Feb 25, 2009 I also had a problem with XP not recognizing the hard drive. The USB Mass Storage Device was reporting a Code 10 (Device cannot start). Ryockey provided the solution in that the drive pins can be offset by one set when connected to the interface. Be careful to get the pins aligned correctly, it worked for me. I also have my drive jumper set for Master. Thanks Robert!
Randy P.S. I am using a Seagate 250 GB HD 7200.7 Ultra ATA
Feb 12, 2009 | NexxTech Portable Hi-Speed USB 2.0 Kit...
My old Dell HD will not fit in HP w/vista
i see..well..was the old hard drive running xp by chance?..seems that with the new vista, that each application would need to be upgraded with drivers to pull the old data..another option is to use a data recovery service.
May 10, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Problem setting up Enclosure
Please check if your jamper of the hardrive must be set to primary settings. Or possible your usb connector having lost contact problem.
Hope this will be helpful to you.
Oct 26, 2007 | NexxTech Portable Hi-Speed USB 2.0 Kit...
I'm not saying this will solve all problems, but it solved it for me. I am running Vista and got this to work following someone's instructions from another forum.
The slot in the enclosure that you plug the hard drive into has one set of holes fewer than the hard drive has pins. This means you can plug the hard drive in two ways "left" and "right" if you will. I had to plug my hard drive in so that the unused pins were farthest from the power cable that plugs into the hard drive.
Incidentally this made the screw holes line up better, too.
Oct 01, 2007 | NexxTech Portable Hi-Speed USB 2.0 Kit...
NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive Logo
639 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Joe Goldman
Joe Goldman
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
