Question about Sony DAV-C990 System
My Sony DAV-C990 plays CD's and DVD's fine for about the first 20 minutes, then starts to skip and freeze. I read on a particular site that this can be an overheating problem that can be taken care of by using Heatsinks on the bottom side in the area where it feels hot. Is this the typical problem and solution with these units? I have owned mine for several years and do not use it that often. Any advice is greatly appreciated. Thanks, Lu.
SOURCE: PROTECT UNPLUG
This is a common problem with sony it means unplug me or i will explode, it is a protection of the heat sync and usually means that a cooling fan has shorted out. If under gurentee return to Sony for repair if not under guranebntee as is generally the case check on the net for a replacement fan motor - as far as i know sony were sourcing thier fanns from Sunon there is a German based headquarters - just google sunon europe
Posted on Aug 12, 2007
SOURCE: SONY Model No: DAV-D150G DVD play problem!!
dav-dz100 a disc cannot be ejected and locked
Posted on Jan 04, 2008
  • 8 Answers
SOURCE: sony dav-c990 not functioning
A lot of "aged" problems relate to the power supply with this type of unit. If you are a handy chap and know what capacitors are you will find that finding and replacing the "dry" caps in the power supply will fix most problems including streaky pix and crackly audio.
Posted on Mar 10, 2008
SOURCE: DVD skips or freezes when playing and not related to a scratched or dirty DVD
I think that this is the laser unit as I have three of these units and I have swapped everything but the laser unit.
Posted on Mar 12, 2008
rencelle
  • 6 Answers
SOURCE: DVD does not work...no lights are on
its better to buy a brand new than to diagnose cause it will be damage again soon.. your money will be useless.
Posted on May 28, 2008
My Sony master 5.1 full digital ampllfier DAv-C990 says reading when I load a DVD and won't play what could be the problem
Laser mechanism is fubar. Repair not cost effective. U can just get an external player and plug it into the receiver.
Jun 06, 2016 | Sony Audio Players & Recorders
DVD images freeze at certain points or playback becomes choppy
sounds like you will need to clean laser, there are cleaners you can buy out of walmart for this. Don't know if they work well, I take mine apart and use soft cloth and alcohol then letting dry, works fine for me.
Dec 16, 2007 | Sony DAV-FR10W System
I have a sony dav-s880 player..b4 it was running superbly but now it can only play a song cd,vcd but cannot play the dvd...its either will eject the dvd or a message will appear cant read.. pls help me...
Sorry to inform you that you have to replace the DVD optical unit ( lens assembly ) .Will cost you about 20$ plus labor. Will need professional help to replace.
Mar 18, 2011 | Sony DAV-S880 System
My Sony DAV-DZ720 Theater System not read the some dvd disc,.,i think problem is in lens system,..help me to fix lens pls,tanx
First try playing a CD. If that too skips you can clean the lens by opening it.Dust on the lens will effect all types of disc and will not be selective.
You can buy a lens cleaning disk from any Cd store and play it to clean.
The cleaning action takes place only if the disc rotates, so keep the top lid off to see if it rotates.
If you have crossed 500 hours of playing may be the lens is due for a change.
Mar 08, 2011 | Sony DAV-DZ720 Theater System
Sony DAV-C990 can't get it off the standby mode
Unplug DAV-C990 from AC outlet for couple of minutes, replug back in and power it up. If problem still exist then home theater has got problem in amplifier output section. Let me know the results to help you more.
Jun 12, 2009 | Sony DAV-C700 System
Movie freezes, skips.
Does sound like the laser. Realitically, not worth repairing. I'd say you'd be worth connecting a cheap DVD player to the system - then the Sony can carry on providing the surround sound audio and the new DVD player can provide the video. Then, if the cheap DVD player is still going, it can move to a bedroom TV if and when you replace the surround system....
Otherwise, I would imaging the speaker set (and even the non-working DVD player) on its own might fetch a reasonable price on an auction site - anyone who has a stolen DVD unit will probably be desparate for the speakers as Sony don't sell them separately!
Jan 04, 2008 | Sony DAV-S500 System
Dec 27, 2007 | Sony DAV-C770 System
Can not load or Eject DVD
Be sure NOT to load any CD+ -R,CD+-RW or DVD+-R,DVD+-RW to this unit.
Try to load up a standard CD see if there is audio first. If so,try a good(not scratches) dvd movie.If you have tried both and still not working.You need this unit to be repair or buy a new one!
Joe
Apr 18, 2007 | Sony DAV-C990 System
Black box showing up while viewing DVDs
Go to your TV remote, in the menu find the closed caption or sometimes it is on the remote itself. Turn off the closed caption. this should solve your problem. Good Luck
Mar 28, 2007 | Sony DAV-C990 System
Dvd pauses
mY DAV-C770 has the exact same problem ...when watching a movie it will intermittently pause or freeze ...then continue. It will do this 20 or 30 times throughout a movie. I asked a tech at Sony for help and he told me the laser reader is out of alignment. The minimum amount to have the dvd player sent out and repaired is $200.00, and thats if it does not require any parts. with a new laser reader it will be about $400.00. Almost the same price as a new dream system. Not worth fixing. I used to think really highly of Sony - until now. Jackal
Nov 21, 2006 | Sony DAV-C770 System
Sony DAV-C990 System Logo
59 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
