When i turn on my thomson scenium 61dsz644 i have picture and no sound . i have replaced the bulb and still no picture. It is showing fault code 18.
  • 4 more comments
  • john33598 Oct 12, 2010
    i will send you a copy of manual if you send me your email
    thomson 61dsz644 tv has no picture but has sound. i have replaced the bulb but still no good. it is showing fault code 18
    The modle code is correct thomson 61dsz644 itc250 thanks for your help.
  • john33598 Oct 13, 2010
    the tv is now showing fault code 16 have you any info
    the tv is now showing fault code 16 any info
  • 10,594 Answers
Error code 18 is mentioned in service manual that indicates "12C Bus 4 Clock line help low"
This is communication error between chips on various circuit boards, you need to swap boards in similar working tv to sort out defective board to get it replaced to solve the issue.
It would not be an easy fix because all circuit boards have to be checked in similar working tv for confirmation of its performance.
Thanks.
Posted on Oct 13, 2010
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Oct 13, 2010
    Code 16 is also communication error code between chips in various circuit boards, description of error code 16 is as follows as per service manual:
    "12C Bus 3 clock line held low"
    Digital ICs needs clock and data signals to communicate each other to carry out operation in circuit and if communication link gets down for some reason, an error code comes up.
    Please check connectors between circuit boards that might have some lose connections and giving you problem/ different error codes.
    Thanks.
    Error code 11 to 18, all are communication error codes and tv has 4 communication bus lines and each line set consist of clock and data signal lines.
    Thanks and good luck
  • 5,138 Answers
CK the Lamp Fan and the Ballast Board ,Ballast is what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
I Ran your Model# are you sure the # you posted is correct? It shows to be an Hitachi?
61dsz644??
Check the Power supply board for bad Caps,they will be swollen,vented,or puffed up on Top.
If it is OK then problem will go back to the Ballast Board.
Posted on Oct 12, 2010
  • 4,889 Answers
I remember reading error 18 as lamp error . Nut would like to be sure. Unfortunately I do not have the service manual for this model. Would make our job easier if you can get it from the link below and send me a copy as well so that I can see you through this
http://www.nodevice.com/manual/newmans/thomson/61dsz644zip/get60849.html
  • eagle338
    eagle338 Oct 12, 2010
    Upload it to a filesharing site and post the direct link here. We are forbidden from sharing our contact details with the users. Mediafire.com is pretty good example of a filesharing site
  • eagle338
    eagle338 Oct 13, 2010
    Well I did not get the copy of the manual?
What does 3 flashes on the standby light on a Thomson scenium 44jw 611s mean
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Feb 25, 2015 | Thomson Televison & Video
Thomson tv projector 61DSZ644 schematic diagram power supply board
Thompson 61DSZ644...Hello,I have a big problem with this tv.When i start it,the sound is good,but the image is very ,very dark.I buy a new lamp,i change it,but i must change the two wires from the lamp because the new lamp have it change.It came from china and is the same lamp,with the same specifications,just the polarity wires is different.so i change it and when i start the tv,i can see the image better but not normaly,the image is like in the white fog,even if the lamp is new...and after 20 seconds,the ventilator from lamp is stop and TV enter in stand by.Can anyone help me about this problem?
Mar 21, 2013 | Thomson 61DSZ644 Rear Projection Lamp...
I have a Thomson Scenium 67" and just turn off by
Can you please send me the model number. I will be better able to assist you. And another more detailed description.
Dec 15, 2011 | Thomson Televison & Video
Hello, I have a 52"
you do not give a model. is the tv plasma, rear projection or lcd as they have different ways of lighting the screen so i can not advise further
Aug 26, 2011 | Thomson Televison & Video
Hi i want to ask about a lamp that related to thomson tv thomson 61 dsz 644 dlp hd tv lamp what is its price ?
http://cgi.ebay.com/LAMP-THOMSON-SCENIUM-61DSZ644-RP-HD-DLP-TV-/270697798709?pt=LH_DefaultDomain_205&hash=item3f06d89c35
Mar 09, 2011 | Thomson 61DSZ644 Rear Projection Lamp...
I replaced the DLP bulb on my RCA TV, Scenium Model # HDLP50W151, and still am not getting a picture. The sound works, but the on/off button blinks indicating a bad bulb. I don`t know if bulb was damaged...
Hi there.
The guide at the following location will help you. Follow the flowcharts and you should be well on your way. It's not free, but that site is very reasonably priced and I have been most impressed with their products.
https://www.completeservicemanuals.com/Electronics/RCA/Thomson/DLP-Projection-Television/HDLP50W151-Service-Manual/prod_1663.html
Hope this helps.
Jan 11, 2011 | RCA Televison & Video
Won't Turn on
Check the batteries in the remote 1st. If that don't work, call a TV tech to replace the IR sensor in the TV
Jul 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
MY THOMSON SCENIUM BOARD IS DAMAGED!!
CALL 01245392539 AND THE UK THOMSON SUPPLIER WILL BE ABLE TO TELL YOU IF IT IS STILL AVAILABLE
Feb 11, 2009 | Thomson LCDB 03B 27 in. Television
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
